LRP 28    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> LRP 28 Page: [1]
Login
LRP 28 - 11/16/2012 5:06 AM
PrjctStrtFrce
Score: 115
Last Login: 12/9/2012
Status: offline
I have a newer LRP28 that has the XTEC case, and an older LRP28 VTEC case. Are there any differences between the cases or is it just the different stamp on the case??
Also, I purchased a motor parts lot recently and the LRP28 was modded by TNT MODS; only that the crankshaft was modded. I assume that just using the modded shaft in an otherwise non-modded LRP28 would be okay?? What does a modded crankshaft provide? I know that a modded sleeve has better intake and exhaust flow.
_____________________________
Keep your RCs, get rid of the wife. -bigwaltc-
SFGP,HPIX4.6,XL,RS4 3,MERV,Kyosho IGT2RS
Hide Signatures
       Post #: 1
RE: LRP 28 - 11/16/2012 3:47 PM
Anthoop
Score: 121
Last Login: 6/19/2013
Status: offline
I can not answer the different case question but I am interested to know, I have a Nosram 28 with VTEC on the side. (I expect HerrSavage will know the answer).
Using the modded crank in another engine will be fine, as for benefits of the modded crank, that will depend on what has been done.
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to PrjctStrtFrce)
       Post #: 2
RE: LRP 28 - 11/16/2012 3:51 PM
HerrSavage
Score: 318
Last Login: 5/23/2013
Status: offline
I don't know anything about mods of course.. But afaik, the only difference between VTEC and XTEC is the first letter. The reason it changed was a legal/trademark/whatever issue with Honda.. I.e. no difference.. The VTEC's are just older, from before the change was forced through.
I don't know that %100 btw. Just seem to recall reading it somewhere..
Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
Hide Signatures
(in reply to Anthoop)
       Post #: 3
RE: LRP 28 - 11/17/2012 7:15 AM
PrjctStrtFrce
Score: 115
Status: offline
Yeah, I laughed when I saw the used motor that had VTEC on it because it brought back memories of when Honda was in the middle of that "legal" matter.
The crank was just bored/polished on the intake and back area, where the pin is for the back-plate.
I have yet to disassemble the XTEC motor so that I can compare them side by side. I wasn't sure if one or the other may have had better bearings, stronger material, etc.
Oddly enough, I purchased this motor lot so that I could get the carb pinch bolt from the LRP28, and I ended up getting quite a few Mach427 and Mach454 pieces in great shape as well.
Hide Signatures
(in reply to HerrSavage)
       Post #: 4
RE: LRP 28 - 11/17/2012 2:13 PM
1QwkSport2.5r
Score: 155
Last Login: 6/20/2013
Status: offline
If you have a vernier caliper, just measure a few things to compare. ie: distance from the cylinder deck (top of crankcase with head removed) to the top of the various ports in the crankcase, etc. You could degree the engine as well, but that is a little more involved. Degreeing would only show the timing of when the ports open and close, and duration. This might be different, but I doubt it.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 5
RE: LRP 28 - 4/1/2013 4:18 AM
mianne
Score: 100
Last Login: 5/1/2013
Status: offline
the cases are the same.a modded crank if done right provides more fuel to the sleve ports however if the sleve is not moded it  wont give u more horsepower they are done together.port and polish the sleve and crank.some modders do the head button to
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
