RE: Resin RADIAL ENGINE Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,900.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Resin RADIAL ENGINE Build
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Resin RADIAL ENGINE Build - 11/19/2012 12:30 AM
JRMS
Score: 100
Last Login: 6/18/2013
Status: offline
Looking forward to see how you and others mounted/secured the dummy engine.
Did you make a separate bracket supported to the firewall or is it attached
to the cowling.
I don't what anyone to take there plane apart just to take pictures. But maybe your at that point
in building, maintenance, or repair, you may be able to share a photo.
Thank you.
_____________________________
Murray
Hide Signatures
(in reply to willey)
       Post #: 26
RE: Resin RADIAL ENGINE Build - 11/19/2012 1:22 AM
TKFOKKER
Score: 130
Last Login: 6/13/2013
Status: offline
Murray
I always attach my dummy engines to the firewall using either steel tube or steel strap stock I make.
TK
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JRMS)
       Post #: 27
RE: Resin RADIAL ENGINE Build - 11/19/2012 1:42 AM
Dean rcu
Score: 130
Last Login: 6/19/2013
Status: offline
I bolted my dummy engine to the engine beams.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JRMS)
       Post #: 28
RE: Resin RADIAL ENGINE Build - 11/19/2012 1:40 PM
willey
Score: 100
Last Login: 6/17/2013
Status: offline
thanks again for the comments guy's, those are really some great photos you all are putting on, already I have learned a few things, keep'm coming.
I didn't get squat done on my SRE this weekend, hopefully this week I'll finish up the front?
Warbirds & Classics
Hide Signatures
(in reply to Dean rcu)
       Post #: 29
RE: Resin RADIAL ENGINE Build - 11/20/2012 12:49 AM
willey
Score: 100
Status: offline
Thanks yel914, sure I could do that
Warbirds & Classics
Hide Signatures
(in reply to abufletcher)
       Post #: 30
RE: Resin RADIAL ENGINE Build - 11/20/2012 1:53 AM
JRMS
Score: 100
Status: offline
I hope to get some projects squared away and then pull my 1/6 scale YMF from storage.
It is a pica that my Dad had bought already buildt and some how other planes tool
the spotlight. If I remember right, this plane has the wood egine rails like Deans T-28.
Dean is your dummy engine a Williams Brothers? I can't tell how you have it secured.
TK do you epoxy a tab on the dummy engine so you can bolt the tube or strap to it?
Or do you drill/tap or wood screw into the dummy engine directly?
Murray
Hide Signatures
(in reply to TKFOKKER)
       Post #: 31
RE: Resin RADIAL ENGINE Build - 11/20/2012 2:01 AM
willey
Score: 100
Status: offline
quote:
ORIGINAL: JRMS
and then we'll have a party!!!!
Warbirds & Classics
Hide Signatures
(in reply to JRMS)
       Post #: 32
RE: Resin RADIAL ENGINE Build - 11/20/2012 2:14 AM
Dean rcu
Score: 130
Status: offline
quote:
ORIGINAL: JRMS
Yes it is a Williams Bros. The engine is heald against the end of the engine beams by 2 screws you can see then in the image above.
Dean
Hide Signatures
(in reply to JRMS)
       Post #: 33
RE: Resin RADIAL ENGINE Build - 11/20/2012 4:29 AM
Stickbuilder
Score: 346
Status: offline
Here's a Jacobs 7 cylinder that I built using a set of cylinders from a Top Flite dummy engine kit and the crankcase is a hair spray can. The ignition manifold was built just like the one above. Spark plugs are pieces of brass tubing. I did this one several years ago. Several of the Waco Brothers have duplicated it.
Bill, Waco Brother #1
Click for fullsize
Click for fullsize
Click for fullsize
Its easy, just glue all the pieces together, and sand off everything that doesnt look like an airplane.
Hide Signatures
       Post #: 34
RE: Resin RADIAL ENGINE Build - 11/20/2012 4:34 AM
Stickbuilder
Score: 346
Status: offline
While I was at it I built a scale bucket seat out of aluminum tubing, card stock and aluminum sheet. Came out pretty close too. It is painted with DupliColor Chrome paint. Here is another shot of the Jake too.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Stickbuilder)
       Post #: 35
RE: Resin RADIAL ENGINE Build - 11/20/2012 11:37 AM
TKFOKKER
Score: 130
Status: offline
I drill and tap directly to the resin.
quote:
ORIGINAL: JRMS
Hide Signatures
(in reply to JRMS)
       Post #: 36
RE: Resin RADIAL ENGINE Build - 11/21/2012 3:45 AM
willey
Score: 100
Status: offline
Hi Bill, nice looking engine and seat, do you more pics of the seat? post if you do, like to see.
Warbirds & Classics
Hide Signatures
       Post #: 37
RE: Resin RADIAL ENGINE Build - 11/21/2012 4:01 AM
willey
Score: 100
Status: offline
well... I finished up mounting the radial tonight, I drilled and tapped the motor mount with 4/40s, very solid. this is the second radial I have mounted this way seams to work pretty good. Now onto mounting cowl and continue finishing the SRE, as I said before I will be posting semi-build thread of what changes I did/doing, nothing real deep but just a few details to make it look a little better than the basic Sig WACO SRE ARF. I will post here with a link when I do.
please feel free to post any dummy engines you have built or seen at a scale meet, this could turn into a very handy thread for the scale builder.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by willey -- 11/21/2012 5:21 AM >
Warbirds & Classics
Hide Signatures
       Post #: 38
RE: Resin RADIAL ENGINE Build - 11/22/2012 12:15 AM
JRMS
Score: 100
Status: offline
To Cool
Looks like you trimmed the rocker covers.
I hope more people post what they have too.
Murray
Hide Signatures
       Post #: 39
RE: Resin RADIAL ENGINE Build - 11/22/2012 4:09 PM
R/C Art
Score: 100
Status: offline
quote:
ORIGINAL: willey
well...... thanks guy's, appreciate the compliments, there's probably other threads like this but wanted to share mine with other modelers. I showed the wife... and she said..... that's nice honey, you know where the remote is?... I just laughed and said ''I think I seen the dog take it outside'' and went back down stairs. LOL!!
Now that was funny! I laughed until I had tears in my eyes! I showed it to my wife and she got a good laugh out of it, too.
I admire all you guys who have the patience and the skill to produce great details for your models. Nicely done Mr. Willey!
On my last project I actually made an attempt to make a 3 dimensional dummy engine. I got some left over, end of the run cast resin cylinders that had a lot of flaws becuse the mold was worn out from Barry Vogel........since they were flawed and I knew I couldn't make them look any worse I got over my intimidation complex and gave it a shot.
All I did was clean up the casting as best I could, then mounted them to a piece of steel, painted it black first, then sprayed silver at an angle, let it dry and then bolted them to the case of my G-62. I had flown for more than a year without any dummy engine at all. So this feeble attmpt at a dummy engine made a marked improvement in the scale outline.
The point here is that a poorly made dummy engine is better than none at all. Give it a shot - you have to start somewhere!
Click for fullsize
Hide Signatures
       Post #: 40
RE: Resin RADIAL ENGINE Build - 11/22/2012 4:24 PM
JRMS
Score: 100
Status: offline
That's the Spirit!!
Murray
Hide Signatures
(in reply to R/C Art)
       Post #: 41
RE: Resin RADIAL ENGINE Build - 11/22/2012 4:42 PM
abufletcher
Score: 1576
Status: offline
Actually, Art, those castings look pretty clean in the photo! The resin cylinders I made for my Benz had flaws all over them, since that was the first time I had ever done a two-part mold and the first time I had used resin. But once they were painted a scale black (since they aren't really "cylinders" but rather "water jackets") and hidden behind a mound of rockers rods, tappets, springs, fuel pipes, exhaust pipes, spar plugs, water hoses, electrical wires, etc., the casting flaws just disappear.
And I agree, a "chin dummy" is better than no dummy at all. And no dummy is almost as bad as no pilot. Almost.
Hide Signatures
(in reply to JRMS)
       Post #: 42
RE: Resin RADIAL ENGINE Build - 11/22/2012 4:53 PM
abufletcher
Score: 1576
Status: offline
Here's a couple of photos showing the dummy for my 1/6 scale EIII. It's just a modified WB LeRhone kit. I added a few bit of styrene to lengthen the cylinders, create the rocker arms, and make a new "two-step" crankcase using the kit's rear face on the front. It didn't take much to make it look like an Oberursel.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 43
RE: Resin RADIAL ENGINE Build - 11/22/2012 5:34 PM
R/C Art
Score: 100
Status: offline
without dummy engine and with dummy engine
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 44
RE: Resin RADIAL ENGINE Build - 11/23/2012 2:17 PM
willey
Score: 100
Status: offline
Hi Art, that looks great what you did, post a few close ups some if you get a chance, thanks for sharing, I have to do something very similar for my DR1
Murrrrrrrrrrrrrrrrrrry... check your inventory...
Click for fullsize
Click for fullsize
Click for fullsize
Warbirds & Classics
Hide Signatures
       Post #: 45
RE: Resin RADIAL ENGINE Build - 11/23/2012 2:22 PM
willey
Score: 100
Status: offline
quote:
ORIGINAL: abufletcher
Here's a couple of photos showing the dummy for my 1/6 scale EIII. It's just a modified WB LeRhone kit. I added a few bit of styrene to lengthen the cylinders, create the rocker arms, and make a new ''two-step'' crankcase using the kit's rear face on the front. It didn't take much to make it look like an Oberursel.
Wow! that sure looks sweeeeeet! if it wasn't for the prop nut & washer you'd think it was real.... well done abufletcher
Warbirds & Classics
Hide Signatures
       Post #: 46
RE: Resin RADIAL ENGINE Build - 11/24/2012 3:47 AM
R/C Art
Score: 100
Status: offline
quote:
ORIGINAL: willey
The materials are cast resin cylinders, mild steel, and lite ply. The cylinders were cast from a worn out mold and I cleaned them up as best I could. I then cut the metal to fit the bottom two bolts on the front crankcase and shaped to give the cylinders the proper spacing. I slotted the cylinders and mounted them to the steel with JB Weld. There was a fourth cylinder but the cut out for the coil left too little material to hold up to the engine vibration and it was lost on one of my flights at this year's Scale Masters Champoinships. I think it is somewhere in a corn field in Southern Indiana. Anywhooooo.....it was painted flat black and the silver was sprayed on at an angle, leaving the black showing on most of the low points and silver showing on most of the high points. Then a small piece of lite ply was shaped to represent the engine case. From the 15 feet judging distance it completes the scale outline as viewed from side or the front.
Relatively quick and easy to accomplish.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 47
RE: Resin RADIAL ENGINE Build - 11/24/2012 3:53 AM
willey
Score: 100
Status: offline
well done art, love the plane too, is that a 1/3rd scale?
Warbirds & Classics
Hide Signatures
       Post #: 48
RE: Resin RADIAL ENGINE Build - 11/24/2012 3:56 AM
willey
Score: 100
Status: offline
nice pics art, didn't see them until after I posted above, thanks for sharing
well, tonight were getting our first snow
Click for fullsize
Warbirds & Classics
Hide Signatures
       Post #: 49
RE: Resin RADIAL ENGINE Build - 11/24/2012 4:04 AM
R/C Art
Score: 100
Status: offline
Thanks Willey. Yes, it is 1/3 scale and of my own design. I have plans available on disk........this is my first attempt at drawing plans and they're not the best there is out there, but they are usable.
In fact I have blown them up to half scale.......the wing ribs need some finessing at this size but the fuse pretty much translates to half scale with little fuss.
The N-11 flys great and I have 2 seasons on it now. The one weak spot on the design was the tail skid. The rest of it has held up very well.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
3.236RCU1
