Reload this Page >
Resin RADIAL ENGINE Build
Old 11-16-2012, 08:48 AM
willey
My Feedback: (32)
willey's Avatar
Default Resin RADIAL ENGINE Build
Hello Guys & Gals, wanted to share the latest chapter in my SIG WACO SRE "rebuild" with you all that I think came out pretty cool looking for the time that was put into it. This build is for the beginner to the average builder, a simple way to spice up that Classic or WWII Warbird you have, hell....even hang on your wall.
Painting wise... I wanted to keep it very simple so anybody can do it, I'm not breaking out the airbrush or pastels/chalks just a couple paint brushes and 4 colors, Black, Grey, Chrome Silver & Steel. (I know the steel is a wrong color but it's what I had handy) so you super scale goo-ru's take it easy on me. also on my spelling
The pictures I am hoping will be pretty much self explanatory but if you have any questions feel free to ask or even add additional info/ideas to this thread. Post you radials, how to mount photos, whatever you have regarding a fake radial.
OK, I bought a Nick Ziroli 7 1/4" Dummy Engine FTE Cast Resin, http://www.ziroliplans.com/zirolipla..._frameset.html - some 1/8", 5/32" & 3/16" alum tubing, and I think it was 3/32" for making the ignition ring, or whatever its called?
As received it was 6.5oz. hmmmmmm..... we need to lighten that up a tad, so the first thing I did was get the grinder out and started removing resin, when I finished with that it was came out 3.1oz., could have taken more but I thought that was good enough. The next thing I did I drilled all my holes, when drilling the "push rod holes" start with a smaller bit and work your way up to the the size you need, dont take it all at once or you will not be a happy camper!![:@]
Next I washed/scrubbed the radial with dish soap than with comet cleanser and then wiped it down with lacquer thinner to clean the surface.
ID:	1820863   Click image for larger version
ID:	1820864   Click image for larger version
ID:	1820865   Click image for larger version
ID:	1820866   Click image for larger version
ID:	1820867   Click image for larger version
ID:	1820868   Click image for larger version
ID:	1820869   Click image for larger version
Old 11-16-2012, 09:04 AM
willey
My Feedback: (32)
willey's Avatar
Default RE: Resin RADIAL ENGINE Build
Next I painted, cut spark plugs (golden rod), here the most time consuming part of the whole project but the most important part to have the look, cutting the push rod tubes, cutting the tubes I used a new #11 blade put pressure on your mark and rolled the tube with the blade then broke off with fingers, hown the inside of tube with blade.
ID:	1820875   Click image for larger version
ID:	1820876   Click image for larger version
ID:	1820877   Click image for larger version
ID:	1820878   Click image for larger version
ID:	1820879   Click image for larger version
ID:	1820880   Click image for larger version
ID:	1820881   Click image for larger version
Old 11-16-2012, 09:15 AM
willey
My Feedback: (32)
willey's Avatar
On the "ignition ring" I'll call it?...(jump in and tell us what it's called if you like)... but I forgot to take pics of the one I built so I made up a quick demo picture pack, made smaller but so you can see what I did.
the ring I built for the radial I just bent it around a tin can, the first pic you see I just used a sanding drum, I also ground a flat spot on the outside of the tubing so it would make it easier to drill for the solder (plug wire), the wire I connected the tubing with is music wire.
ID:	1820885   Click image for larger version
ID:	1820886   Click image for larger version
ID:	1820887   Click image for larger version
ID:	1820888   Click image for larger version
ID:	1820889   Click image for larger version
ID:	1820890   Click image for larger version
ID:	1820891   Click image for larger version
ID:	1820893   Click image for larger version
ID:	1820894   Click image for larger version
ID:	1820895   Click image for larger version
Old 11-16-2012, 09:23 AM
willey
My Feedback: (32)
willey's Avatar
always dreaded doing the ring but it's really not that hard to do, lets just see if it holds up under the all the vibration, once it was all installed you would be really surprised how rigid it is when mounted, next time I would probably take more time and use music wire for the plug wires.
ID:	1820897   Click image for larger version
ID:	1820898   Click image for larger version
Old 11-16-2012, 09:33 AM
willey
My Feedback: (32)
willey's Avatar
well here it is put together, cut the back plate out of light 1/8" ply, then CA'd it to the back. I'll post pics of how I mounted it soon, that is were I am at at this point so check back.... Hope you like - talk to you soon.
willey
the windshield you see is just for effect, I will be making an all new with frame after the cowl is mounted... I will be posting a thread on the Waco when I get further along.
ID:	1820903   Click image for larger version
ID:	1820904   Click image for larger version
ID:	1820905   Click image for larger version
ID:	1820906   Click image for larger version
ID:	1820907   Click image for larger version
ID:	1820908   Click image for larger version
ID:	1820909   Click image for larger version
ID:	1820911   Click image for larger version
Old 11-16-2012, 09:38 AM
willey
My Feedback: (32)
willey's Avatar
some examples...
ID:	1820914   Click image for larger version
ID:	1820915   Click image for larger version
ID:	1820916   Click image for larger version
ID:	1820917   Click image for larger version
ID:	1820918   Click image for larger version
ID:	1820919   Click image for larger version
ID:	1820920   Click image for larger version
ID:	1820922   Click image for larger version
ID:	1820923   Click image for larger version
Old 11-16-2012, 09:40 AM
willey
My Feedback: (32)
willey's Avatar
some more, please add more or any info you like.
ID:	1820925   Click image for larger version
ID:	1820926   Click image for larger version
ID:	1820927   Click image for larger version
ID:	1820928   Click image for larger version
ID:	1820929   Click image for larger version
ID:	1820930   Click image for larger version
ID:	1820931   Click image for larger version
ID:	1820933   Click image for larger version
ID:	1820934   Click image for larger version
ID:	1820935   Click image for larger version
Old 11-16-2012, 09:53 AM
AnthonyW
AnthonyW's Avatar
I used one of these in my Ziroli P-47, but I needed the nose weight, so i did not lighten it. You are right about the ring and vibration. Mine has come loose again and needs to be reglued. I may use a more flexible glue or even silicone. With a little doctoring (like yours) they are a very realistic looking engine.
Old 11-16-2012, 11:27 AM
Mein Duff
Mein Duff's Avatar
Great Job Willey... looks excellent.. hard to distinguish from the orig pics of the Wasp engine.
Old 11-16-2012, 05:29 PM
JRMS
JRMS's Avatar
Nice Job Willey,
You have been a busy Boy!
I see you have changed your avitar to the SRE.
Again nice!
Looking forward to seeing more.
Old 11-16-2012, 05:54 PM
abufletcher
abufletcher's Avatar
OUT-STANDING!!! And a perfect example of how a really well made and highly detailed scale feature doesn't have to add a lot of weight! Well done, sir! Well done!
Old 11-16-2012, 07:54 PM
ps2727
Nice!
Old 11-17-2012, 05:09 AM
OldScaleGuy
OldScaleGuy's Avatar
Very nicely done. We need more posts like this. Thank you!
Old 11-17-2012, 05:43 AM
TKFOKKER
Awesome work Mr. Willey!
I too used the same engine on my 1/4 scale Stinson Reliant. You do fantastic work. Now seeing yours I have to revisit my work and polish out my aluminum push rods.
Thanks for sharing your skills.
TK
ID:	1821173   Click image for larger version
ID:	1821174   Click image for larger version
ID:	1821175   Click image for larger version
ID:	1821176   Click image for larger version
Old 11-17-2012, 06:55 AM
willey
My Feedback: (32)
willey's Avatar
well...... thanks guy's, appreciate the compliments, there's probably other threads like this but wanted to share mine with other modelers. I showed the wife... and she said..... that's nice honey, you know where the remote is?...[X(][X(][X(][X(] I just laughed and said "I think I seen the dog take it outside" and went back down stairs. LOL!!
Yea JR I thought I'd change the Avatar to the whatever project I'm working on, trying to stay focused on one project.
TK, WOW! that's one fine looking Reliant really like that front plate u used I have to make one of those, I do have a gap and that would work perfect! thanks for posting it. Looks like you were at Rienbeck? had to be a big hit there?
Thanks again, Hope more guys post there's
Old 11-17-2012, 07:01 AM
willey
My Feedback: (32)
willey's Avatar
TK, forgot to mention, after you polish and make nice & shiny, take some clear and put on, works great!!
Old 11-17-2012, 07:09 AM
abufletcher
ORIGINAL: willey
I got about the same reaction from the guys at my flying field when I showed 'em my dummy of a Benz IIIa.
Old 11-17-2012, 07:16 AM
TKFOKKER
Very, Very Nice Don!!
TK
Old 11-17-2012, 07:17 AM
willey
My Feedback: (32)
willey's Avatar
That looks awesome! I have seen other photos of yours, you do great work.
On the show n' tell subject....well I guess if we are happy with it that is all that matters LOL!!
Old 11-17-2012, 07:32 AM
willey
My Feedback: (32)
willey's Avatar
Yea Guy's, please post any dummy engine you like, I'm sure all would want to see, I have a few others I have built that I will post but I need to get down there and take some pics.
Old 11-17-2012, 09:41 AM
Kmot
My Feedback: (24)
Kmot's Avatar
willey: You did an absolutely fabulous job on that radial!! All it needs now is some oil dripping from it!
Here is a TopFlite version I did a while back.
ID:	1821222   Click image for larger version
Old 11-17-2012, 01:25 PM
Mustang1971
My Feedback: (30)
Mustang1971's Avatar
Excellent job!
Old 11-17-2012, 06:40 PM
Dean rcu
Excellent work Willey. Here is one I did using Williams Brothers Scale Radial Engine Cylinders for a 1/6th scale T-28.
Old 11-17-2012, 07:17 PM
yel914
yel914's Avatar
Willey, some really great workmanship here. I would suggest that you post a couple of pics in the Golden Age and Vintage section here on RCU. There's a very large thread on the Waco YMF in various forms and sizes. This thread is very serious about scale Waco stuff and this engine, and your workmanship, will fit right in
Old 11-17-2012, 07:58 PM
abufletcher
Dean, that's a great dummy...and in fact a great photo...you even have scale oil stains on the ground!
