How to Balance?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> How to Balance?
Page: [1]
Login
How to Balance? - 11/16/2012 8:34 PM
csandt051196
Score: 100
Last Login: 5/21/2013
Status: online
Is it best to balance a plane right side up or upside down? Why?
Scott
Hide Signatures
       Post #: 1
RE: How to Balance? - 11/16/2012 10:10 PM
BarracudaHockey
Score: 280
Status: offline
High wing = right side up
Mid wing = either way
Low wing = you guessed it, upside down
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to csandt051196)
       Post #: 2
RE: How to Balance? - 11/17/2012 1:28 AM
tailskid
Score: 199
Status: offline
+1
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: How to Balance? - 11/17/2012 1:49 AM
jetmech05
Score: 133
Last Login: 5/22/2013
Status: offline
Why you asked because you want the weight down....it makes it easier... take a high wing...right side up all the weight is below the balance point upside down and now the weight is above the balance point and it will be impossible
Hide Signatures
(in reply to tailskid)
       Post #: 4
RE: How to Balance? - 11/17/2012 1:50 AM
JohnBuckner
Score: 342
Status: offline
BaracudaHockeys list is right on and the reason is that to be able to find that balance point there must be sufficient weight below the
point of contact (balance pins) that the model can be stabile otherwise you can just keep readjusting and never find the real point.
Some airplanes ya just gotta experiment to find that stabile point. Look at it this way picture what would happen if you tried to balance a high wing airplane upside down, you would just not be able to find the balance point.
John
"Keep your controllines tight"
Hide Signatures
       Post #: 5
RE: How to Balance? - 11/17/2012 2:19 PM
jaka
Score: 158
Status: offline
Hi!
I just hold the plane as it is. Two fingers under the wing and top of plane pointing up.
Come on guys this isn't Rocket Science!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 6
RE: How to Balance? - 11/17/2012 2:25 PM
smithcreek
Score: 159
Status: online
quote:
ORIGINAL: jaka
No, you're right, it's physics 101. Holding a low wing plane right side up is not, by a long shot, the best method.
For a kit you are, and to a kit you shall return.
Hide Signatures
(in reply to jaka)
       Post #: 7
RE: How to Balance? - 11/17/2012 3:47 PM
jaka
Score: 158
Status: offline
Hi!
But It's enough! Then I fly test my planes several times and move around the servos and battery untill I obtain a perfect C of G!
Hide Signatures
(in reply to smithcreek)
       Post #: 8
RE: How to Balance? - 11/19/2012 1:09 AM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: csandt051196
Scott,
This great article will respond your question much better than I would do:
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=601
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
       Post #: 9
RE: How to Balance? - 11/20/2012 7:55 AM
evabuick
Score: 100
Last Login: 12/17/2012
Status: offline
got it
Hide Signatures
(in reply to Lnewqban)
       Post #: 10
RE: How to Balance? - 11/21/2012 4:34 PM
skeeter_ca
Score: 121
Last Login: 3/6/2013
Status: offline
quote:
ORIGINAL: Lnewqban
Scott,
I think this article is a very simple way to explain it but really does not give a proper answer as to why it is easier to balance it upside down.
Place a low wing plane on a balance stand/finger tips right side up and say it is nose heavy. As the nose starts to dip down because of the nose heavy condition the large mass of the planes fuselage above the balancing point begins to move forward making it even more nose heavy. As the plane tilts forward even more the nose heavy condition gets worse and worse until the plane hit a stop or falls of the stand.
If the same plane is place upside down on the balance stand it reacts differently. As the nose drops forward the mass of the fuselage then moves backward like a pendulum. This offsets the nose heavy condition and if within certain limits will equal itself out and not fall of the stand.
Hope this is helpful.
skeeter
"It is easier to ask for forgiveness than permission".
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
