had my revo 3.3 tuned up now wont start    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> had my revo 3.3 tuned up now wont start
Page: [1]
Login
had my revo 3.3 tuned up now wont start - 11/16/2012 11:14 PM
Harley1997z28
Score: 100
Last Login: 11/19/2012
Status: offline
 so my revo 3.3 wasnt ran for a couple years so i took it to a hobby shop were i bought it to get it running again. i also had it converted to a pull start. picked it up today, the guy started it in front of me in the store and it started quick and easy. i drive 30 minutes back home and the thing wont even start. i called the guy at the hobby shop and he had me take the glow plug out and turn it upside down and pull the starter a few time till no fuel came out. still wont start. then the guy tells me when i took it from inside the store to the outside it flooded the car and i need to bring it back so he can get it running. at this point im beyond pissed i spent 87 bucks to have this engine flushed and tuned and converted to pull start  then get it home after he just started it and cant get it going. i threw the glow plug wand thing i bought and busted it i was so pissed
whats going on what do i need to do to get this running. i know it runs why would it flood out just by taking it outside the store and going home?
Hide Signatures
       Post #: 1
RE: had my revo 3.3 tuned up now wont start - 11/16/2012 11:25 PM
fizzwater2
Score: 124
Last Login: 5/19/2013
Status: offline
just a guess, but it's either
a: Bad Fuel - if it's set around for a while, it might not be any good.
b: Bad plug driver - the plug has to get orange hot to work.
c: Bad plug.
_____________________________
No matter where you go, there you are!
Hide Signatures
(in reply to Harley1997z28)
       Post #: 2
RE: had my revo 3.3 tuned up now wont start - 11/17/2012 2:13 AM
Harley1997z28
Score: 100
Status: offline
 the hobby shop flushed out old fuel and put new in. i did test and see if the gloplug wasglowing orange and it was. like i said when i picked it up he pull started it and it fired right up, somehow it flooded between the hobby shop and home. like i mentioned i tried taking the plug out and turning car upside down and pulling it a few times and that didnt work.
Hide Signatures
(in reply to fizzwater2)
       Post #: 3
RE: had my revo 3.3 tuned up now wont start - 11/17/2012 5:01 AM
mopartybob
Score: 106
Status: offline
quote:
ORIGINAL: fizzwater2
c: Bad plug.
reprime it ...... pull, if it floods,clear the flood,check glo-igniter on plug,re-install plug,......... pull, if still no start,refer to a. b, or c, remember, it's supposed to be FUN ............ mpb
.....If I had a plan,I''''''''''''''''d be screwed....
Hide Signatures
       Post #: 4
RE: had my revo 3.3 tuned up now wont start - 11/17/2012 1:59 PM
Ttowntoolman
Score: 159
Last Login: 5/16/2013
Status: offline
Maybe your glow plug wand thingy is too week to properly ignite your engine. Did the hobby store use yours or thiers to start your engine while you were there? Hang in there, you will figure it out......
Hide Signatures
(in reply to mopartybob)
       Post #: 5
RE: had my revo 3.3 tuned up now wont start - 11/17/2012 2:24 PM
1QwkSport2.5r
Score: 155
Status: offline
If the fuel tank is in front of the engine and you carried the truck out of the store by the front bumper, thats how it may have flooded. If turning the truck upside down with the glow plug removed did not spit any fuel out of through the glow plug hole, its not flooded. If fuel did come out, usually replacing the plug and just trying to start it will get it to fire. If after several pulls of the pullstart it doesnt fire or even pop, check the glow plug again and make sure the glow plug isnt full of fuel. If it isnt full of fuel, and glows with no effort with the glow driver, then I would resort to repriming the engine. I would plug the exhaust and turn the engine over slowly until fuel reaches the carb and then give it just a little more and re-try firing it up.
Most glow engines need a pretty "wet" or "fat" prime to get fired up from dead cold. If the engine is cold (below 60°F) then it will be a bit harder to get started without an electric starter and even then it might be stubborn. If it is cold, try heating it up with a hair dryer and try again. Methanol based fuel doesnt like to burn when its cold, although I rarely have trouble getting an engine started even when the engine is 40°F, though I use electric starters on most of my engines.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to Ttowntoolman)
       Post #: 6
RE: had my revo 3.3 tuned up now wont start - 11/25/2012 4:58 AM
Quickywd01
Score: 100
Last Login: 3/16/2013
Status: offline
Try to be patient. Make sure your glow plug is getting nice and hot because I bet that is your problem. Either your ez-start battery is low/dead or the glow plug is dead. When I bought my first nitro rc which happens to by my 2.5R revo when they first came out I took it home, read all the stuff, watched the dvd, put fuel in it, loaded it on a little cargo dolly and pulled it behind me all the way to an empty parking lot which took me like half an hour lol and when I got there my ten year old battery didn't work so well so I hauled it back home and took it back to the rc shop. Well it's a good thing I hauled the revo like I did because it flooded the motor and lubed it before I broke it in. Everyone loves to drive a nitro but only a few like it enough to maintain it and learn about it. Hope you get it running like I did. I now have a .26 red dot in that same revo. Also picked up a revo platinum that I plan to race and I also have a slash and nitro touring car that I got from friends that gave up on their cars. I'm still helping two other friends, one with a revo 3.3 which broke it's connecting rod (I can't believe traxxas dropped the ball on that) and the other with a jato who wanted a faster engine so he put 30% nitro in it and leaned it out because it was fast until it popped. Gotta pay to play...
Proud owner of TRX 2.5R powered REVO Custom Flex Header AE 60wt + LT springs 20% S&W Ofna FS
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
