Best for racing?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Best for racing?
Page: [1]
Login
Best for racing? - 11/17/2012 2:03 AM
airraptor
Score: 130
Last Login: 5/20/2013
Status: offline
Between these two engines which is best for speed the DA 60 or the Evo 58? warbird type plane like say a mustang around 18 lbs or so.
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 1
RE: Best for racing? - 11/17/2012 11:48 AM  1 votes
kmtranmd
Score: 120
Last Login: 5/13/2013
Status: offline
How about the G62 old horse,now with electronic ignition called the Platinum series? Just got one in and looks great.
Engine alone weighs only 3 lbs 14 oz.
It's cheaper, indestructable, and super reliable.
DA 60 is more torque engine for 3D flying IMO.
I've flown warbirds with both DA 50 and G62, and there's no comparison.
Go Ducks
Hide Signatures
(in reply to airraptor)
       Post #: 2
RE: Best for racing? - 11/17/2012 4:38 PM
airraptor
Score: 130
Status: offline
Yes I amy have to look at that one. I wonder what the 50 cc warbird racers use?
AMA # 186123
Hide Signatures
(in reply to kmtranmd)
       Post #: 3
RE: Best for racing? - 11/17/2012 6:41 PM
w8ye
Score: 318
Status: offline
The AT-6 Texan racers use the Zenoah G-62
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 4
RE: Best for racing? - 11/17/2012 7:30 PM
closetguy
Score: 166
Status: offline
Evolution 58,if that is the engine you are talking about.hands down the best speed engine you can get when run on a pipe,it will spank that DA60.
i had one on a ES pipe it would spin a Xoar 24-8 at 7500+,just gobs of instant HP and throttle response.
if you have the need for speed this one is it.
you might be better off looking into a MVVS58,same engine but put together with a little more care.
Hide Signatures
(in reply to w8ye)
       Post #: 5
RE: Best for racing? - 11/18/2012 1:53 AM
airraptor
Score: 130
Status: offline
quote:
ORIGINAL: closetguy
Thanks do you think a 20x18 or 20x20 prop would be too much for it?
AMA # 186123
Hide Signatures
(in reply to closetguy)
       Post #: 6
RE: Best for racing? - 11/18/2012 2:00 AM
mikes68charger
Score: 106
Status: offline
Thats a lot of pich, and I can tell you that on most bigger birds thrust is just as important as pich speed.
But if you turn a smaller prop faster / higher rpm you will get your thrust back.
Hide Signatures
       Post #: 7
RE: Best for racing? - 11/18/2012 2:52 AM
closetguy
Score: 166
Status: offline
i have not done much with speed props, so i can't help you out there.
you need to talk to Pe Reivers.just google MVVS he will turn up some where,don't know the web link.
Hide Signatures
(in reply to mikes68charger)
       Post #: 8
RE: Best for racing? - 11/18/2012 4:00 AM
apalsson
Score: 168
Status: offline
quote:
ORIGINAL: airraptor
20x18 should be fine.
I tried a 22x14 on a 58cc for racing in my Top Flite P47 and did quite well as a racing setup. In our class, we are not allowed any mufflers "outside the cowling" which rules out pipes or canisters. My solution was the side dump MVVS muffler
If you can fit the INT58 canister (MVVS canister), you will gain a couple of hundred RPM on top of what any side dump or Pitts muffler will give you
Prop the engine for some 6400 - 6500RPM static. This will unload to around 7800 - 8000 in flight and give you some very good speed.
MVVS Australia
MVVS Engines, Mejzlik Props, Accessories.
www.mvvs-australia.com.au
Hide Signatures
       Post #: 9
RE: Best for racing? - 11/21/2012 11:42 PM  1 votes
kmtranmd
Score: 120
Status: offline
I slapped a DA85 in my TF P47 and did not see impressive speed out of that Jug. Too much drag on that bulky airframe.
My TF P51 with DA 50 and Keleo scale exhaust swinging the T6 racing prop (APC 20x12 special order from Tower) put a smile on my face for years now.
If doing it over, I would put the Zenoah ZP 62 with same P51 airframe and T6 racing prop for speed warbird set up.
Go Ducks
Hide Signatures
(in reply to apalsson)
       Post #: 10
RE: Best for racing? - 11/27/2012 8:09 PM
flygilmore
Score: 128
Last Login: 5/16/2013
Status: offline
I would def. look at the G62 and prop it to spin up.........most guys really underprop this great engine!
I didn''''t choose Mojo, Mojo chose me PRO BRO #1963
Hide Signatures
       Post #: 11
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Best for racing?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
