controlling a 540 edge those throws    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> controlling a 540 edge those throws Page: [1]
Login
controlling a 540 edge those throws - 11/17/2012 11:43 AM
suzonka
Score: 100
Last Login: 5/14/2013
Status: offline
I have a first for me 540 edge electric arf , and I set the aileron and all the rest of the throws to hi and low according to instructions, so when I did my flight it took off smooth as I circled around the field , and on low rates I was trimming it out elevator only as needed and I turned it with the ailerons and it went into a snap and Didn't have enough time to recover it had snapped so fast on low rates, that it went down so I'm repairing the nose and motor mount , what I experienced was a very sensitive control rate , so is this common on this type of model,because i have a typhoon foam model with the same barn door type ailerons and it fly's very well on both low and high rates and one problem is my futaba radio does not have exponential? so should I lower the rates even more , now as per instruction ailerons are set to 1.25" low and 2.25" high rate settings any suggestions ?
Hide Signatures
       Post #: 1
RE: controlling a 540 edge those throws - 11/17/2012 1:13 PM
BarracudaHockey
Score: 280
Last Login: 5/25/2013
Status: offline
Its pretty simple, if its too sensitive for you then yes lower the rates.
I can tell you that flying small aerobatic models like that, with large surfaces and a lot of throw, without expo is a handful even for experienced pilots
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to suzonka)
       Post #: 2
RE: controlling a 540 edge those throws - 11/18/2012 4:51 AM
suzonka
Score: 100
Status: offline
quote:
ORIGINAL: BarracudaHockey
THANKS FOR THE INPUT ,Ill reduce the throws to 50% less
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: controlling a 540 edge those throws - 11/19/2012 3:47 AM
Charley
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: suzonka
Don't forget to put in a bunch of Expo into the elevator and aileron channels.
CR
Charley
ccrobins@ktc.com
Hide Signatures
       Post #: 4
RE: controlling a 540 edge those throws - 11/19/2012 10:14 AM
suzonka
Score: 100
Status: offline
quote:
ORIGINAL: Charley
quote:
ORIGINAL: suzonka
CR
in my post its stated that [ radio does not have exponential? ]
Hide Signatures
(in reply to Charley)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
