Help: I need to remove CA from nylon tailwheel bearing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Help: I need to remove CA from nylon tailwheel bearing
Page: [1]
Login
Help: I need to remove CA from nylon tailwheel bearing - 11/17/2012 2:54 PM
bugdr
Score: 100
Last Login: 4/29/2013
Status: offline
Is there anyway to remove CA from a nylon tailwheel bearing? I was installing the rudder and tailwheel into a Pulse XT 40. The epoxy part went fine no glue got into the nylon bearing that is glued into the tail. However when I went to CA the rudder hinges, a little CA ran into the nylon bearing that holds the tailwheel. I should have used vaseline to prevent this. I can move the rudder back and forth but it is still a little sticky. I tried a few drops of oil to the tailwheel bearing and this helped a little. Is there anything else I can do? Would CA debonder work?
Hide Signatures
       Post #: 1
RE: Help: I need to remove CA from nylon tailwheel bearing - 11/17/2012 4:15 PM
Laird SS
Score: 100
Last Login: 5/19/2013
Status: offline
That or acetone might work, however, I would try it on a similar piece of material that isn't part of the plane.
Hide Signatures
(in reply to bugdr)
       Post #: 2
RE: Help: I need to remove CA from nylon tailwheel bearing - 11/18/2012 12:13 AM
lfinney
Score: 105
Last Login: 5/23/2013
Status: offline
CA debonder will work
Hide Signatures
(in reply to Laird SS)
       Post #: 3
RE: Help: I need to remove CA from nylon tailwheel bearing - 11/22/2012 2:56 PM
eagledancer
Score: 110
Status: offline
sometimes heat will also loosen the bond, try a soldering iron on the wire, as you heat the wire work the tailwheel, once it breaks loose remove the heat and add some light oil into the bracket
_____________________________
I once had a drinking problem.....I divorced it, now shes someone else''s problem
waco brotherhood # 140
Hide Signatures
(in reply to lfinney)
       Post #: 4
RE: Help: I need to remove CA from nylon tailwheel bearing - 11/23/2012 6:45 PM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
Just redrill the hole for the wire with the correct size drill bit.
Ken
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to eagledancer)
       Post #: 5
RE: Help: I need to remove CA from nylon tailwheel bearing - 11/23/2012 8:48 PM  1 votes
jaka
Score: 158
Last Login: 5/21/2013
Status: offline
Hi!
I have answered this many times. But here we go again.
There is no better thing to use than pure nitro for loosen Ca glue. Debonder is just a waste of money and aceton takes tooooo long .
Simple as that!
All modelers should have some nitro at home!
Jan Karlsson - Supplier MVVS Products
Hide Signatures
(in reply to bugdr)
       Post #: 6
RE: Help: I need to remove CA from nylon tailwheel bearing - 11/25/2012 5:00 PM
bugdr
Score: 100
Status: offline
Thanks for all of the suggestions. I tried acetone, and CA debonder. I did not have any pure nitro to try. Both helped a lot. I also tried a little light oil. The rudder still slightly binds but there is not much resistance once it starts to move a little. I can't remove the tail wheel wire from the nylon joint to drill it out because of the way the tail wheel unit is made.  I think I will just fly it the way it is for now.
Hide Signatures
(in reply to jaka)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
