Help: anyway to remove CA from nylon tailwheel bearing?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Help: anyway to remove CA from nylon tailwheel bearing?
Page: [1]
Login
Help: anyway to remove CA from nylon tailwheel bearing? - 11/17/2012 3:05 PM
bugdr
Score: 100
Last Login: 4/29/2013
Status: offline
I accidentally got a little CA into the nylon tailwheel bearing of a pulse xt 40 when I was gluing the rudder hinges. I should have used vaseline around the hinge to prevent this. I can move the rudder back and forth, but it is still binding in the nylon bearing that holds the tailwheel assembly. I tried adding a few drops of oil to the bearing and this helped a little. Should I try CA debonder?
Hide Signatures
       Post #: 1
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/17/2012 3:07 PM
LesUyeda
Score: 151
Last Login: 5/22/2013
Status: offline
"Should I try CA debonder? "
Yes. You don't have much to loose, and the debonder should not even touch nylon.
Les
Hide Signatures
(in reply to bugdr)
       Post #: 2
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/17/2012 3:14 PM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
You will have to work with it still. the debonder does not just melt away the CA. But it will slowly loosen it till the rudder turns freely.
David
_____________________________
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to LesUyeda)
       Post #: 3
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/17/2012 4:58 PM
Gray Beard
Score: 314
Status: offline
Isn't debonder just acetone? That's all I use, I always have acetone in my shop but I have never bought kicker or debonder.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to daveopam)
       Post #: 4
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/17/2012 5:02 PM
bugdr
Score: 100
Status: offline
quote:
ORIGINAL: Gray Beard
I checked the msds for various debonders and some are acetone, but others (like super solvent) are a mix of nitro alkanes. These are supposed to work slightly better than straight acetone.
Hide Signatures
(in reply to Gray Beard)
       Post #: 5
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/19/2012 4:24 AM
johndavis
Score: 107
Last Login: 5/4/2013
Status: offline
if the debonder dont work  try a drop of brake fluid  but not much though
Hide Signatures
(in reply to bugdr)
       Post #: 6
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/19/2012 5:14 PM
jessiej
Score: 144
Last Login: 5/23/2013
Status: offline
Fastest thing Ihave used is straight nitromethane.
Jess
Hide Signatures
(in reply to bugdr)
       Post #: 7
RE: Help: anyway to remove CA from nylon tailwheel bear... - 11/19/2012 5:17 PM
bugdr
Score: 100
Status: offline
I tried straight acetone. It helped a lot. The rudder is still not completely smooth, but the servo seems to handle it fine. Once the rudder starts to move there is not much friction.
Thanks for all the advice!
Hide Signatures
(in reply to jessiej)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.235RCU1
