ESM Retract Issues    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Lavochkin LA-7
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> ESM Retract Issues
    Page: [1]
    Login
    ESM Retract Issues - 11/18/2012 4:57 AM
    rcfan450
    Score: 100
    Last Login: 4/17/2013
    Status: offline
    I just installed a brand new air retract system and am having issues with them retracting. They pop out and lock ok, but do not go back in with any authority at all - they don't lock. Even when I take the struts off, they don't go back in and lock.
    I've check for binding issues and I can easily move the retract hinge all the way in and out (when not under pressure). When it is under pressure I can feel pressure pushing it out, but in the other direction there just isn't good pressure if any at all.
    I have the red Robart Valve - started at 2 turns out on the needles and from there went all over, not much difference.
    I have a Robart pressure gauge which told me the pressure was always good between 80-100, mostly right around 100 though as I kept pumping it back up thinking it just wasn't pumped up enough.
    So if there are no binding issues and pressure is good - where am I going wrong?
    Wish I had the cash to just buy electric retracts....
    Hide Signatures
           Post #: 1
    RE: ESM Retract Issues - 11/18/2012 11:12 AM
    Lifer
    Score: 148
    Last Login: 5/23/2013
    Status: offline
    Check for any debris or obstruction in the lines for the retract cycle.
    Hide Signatures
    (in reply to rcfan450)
           Post #: 2
    RE: ESM Retract Issues - 11/18/2012 12:15 PM
    VIRGINIA MODEL BUILDERS
    Score: 105
    Last Login: 4/7/2013
    Status: offline
    Most of us have moved on and use the ESM electric retracts
    _____________________________
    VAMODELBUILDERS
    http://vamodelbuilders.com/
    Hide Signatures
           Post #: 3
    RE: ESM Retract Issues - 11/18/2012 5:02 PM
    rcfan450
    Score: 100
    Status: offline
    quote:
    ORIGINAL: VIRGINIA MODEL BUILDERS
    Hence my statement... Wish I had the cash to just buy electric retracts....
    I will check for debri. Any other ideas?
    Hide Signatures
    (in reply to VIRGINIA MODEL BUILDERS)
           Post #: 4
    RE: ESM Retract Issues - 11/18/2012 5:26 PM
    Lifer
    Score: 148
    Status: offline
    Double check the valve for normal function as well. Best of luck.
    Hide Signatures
           Post #: 5
    RE: ESM Retract Issues - 11/19/2012 4:14 AM
    rcfan450
    Score: 100
    Status: offline
    Figured it out. The ESM quick couplers I got are way too restrictive. I took them off and put the valve directly to the in/out lines and it worked great. So I ordered some Robart quick release connectors, I'll give them a try I guess.
    Hide Signatures
    (in reply to Lifer)
           Post #: 6
    RE: ESM Retract Issues - 11/19/2012 11:14 AM
    Lifer
    Score: 148
    Status: offline
    Good job! Glad you were able to fix them rather than bearing the expense of electrics. A lot of the problems with discounted products is their failure to clean the components prior to assembly. After a while, disassembly and cleaning becomes a routine after purchase.
    Hide Signatures
           Post #: 7
    Page:   [1]
    Page: [1]
    Lavochkin LA-7
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    3.473RCU1
