old styleRCMK s520    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> old styleRCMK s520
Page: [1]
Login
old styleRCMK s520 - 11/18/2012 5:22 PM
Jackal1983
Score: 105
Last Login: 5/24/2013
Status: offline
Hi Guys,
Anyone running the old style RCMK S520 bottom end??? with the split crank and coupler??? i know they where recalled when they first come out.
what was happening to them when they broke? snapping crank????
jack
_____________________________
MillPond Models
Hide Signatures
       Post #: 1
RE: old styleRCMK s520 - 11/19/2012 5:02 AM
Ron Olson
Score: 1175
Last Login: 5/25/2013
Status: offline
Bearing issues mostly. The crank wasn't the brightest idea in the world either which didn't help matters.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to Jackal1983)
       Post #: 2
RE: old styleRCMK s520 - 11/19/2012 10:54 PM
Boss 330
Score: 100
Last Login: 1/2/2013
Status: offline
quote:
ORIGINAL: Jackal1983
Hi Guys,
jack
The first version bottom ends are junk. The crankshaft was made up from two single cyl.cranks. I broke two before the boat made it off the bench. the cranks break at the center.  Only a small number were sold . Two months later Mr Park released a new design that has a single piece crank. The second version is a great engine. I have 4 and run 2-3 times a week.
Hide Signatures
       Post #: 3
RE: old styleRCMK s520 - 11/20/2012 5:12 PM
V8Rider
Score: 100
Status: offline
Hey Al,
I know you run your inlines a lot. So what is the trick to keeping the flywheel from coming loose? Are you using an EZ Start? I just ordered the EZ Start with the steel starter pawl that Gizmo sells along with flywheel #3! I am hoping the steel pawl will hold better than the aluminum one from the first EZ Starter.
Rick
Hide Signatures
(in reply to Boss 330)
       Post #: 4
RE: old styleRCMK s520 - 11/21/2012 12:10 AM
Boss 330
Score: 100
Status: offline
quote:
ORIGINAL: V8Rider
Hey Al,
Rick
Use a steel nut to seat the flywheel, Piston stop is a no no. I put the flywheel on before the pistons/cylinders on. Use a plastic screwdriver handle to wedge the crank and seat the flywheel with a steel nut (Tight) remove the steel nut then install the EZ start pawl using red Loctite on the threads.If you are using a thin front mount the pawl can contact  the starter with enough force to unscrew the pawl.
Hide Signatures
(in reply to V8Rider)
       Post #: 5
RE: old styleRCMK s520 - 11/21/2012 7:59 PM
V8Rider
Score: 100
Status: offline
The steel nut sounds like a good idea. I am using a Gizmomotors motor mount set up. It does not look to be thin but I will check for clearance between the pawl and starter just to be sure. Thanks for yor help.
Rick
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
