Can I fast charge NiMh batteries ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Can I fast charge NiMh batteries ? Page: [1]
Login
Can I fast charge NiMh batteries ? - 11/19/2012 2:13 AM
Ed
Score: 121
Last Login: 6/20/2013
Status: offline
I have a Peak Electronics Sirius Charge Pro Series field charger. It has 250, 500, and 1000 mah settings. I want to charge my Sanyo 1650 mah NiMh batteries with it. Will this fast charger damage my NiMh batteries ? It charges my NiCds just fine, but I am told that NiMh shouldn't be fast charged ? ? ?
Thank's for your help. - Ed
Hide Signatures
       Post #: 1
RE: Can I fast charge NiMh batteries ? - 11/19/2012 8:14 AM
Goldenduff
Score: 114
Last Login: 6/19/2013
Status: online
In my opionion any battery can be charged at 0.8C so even your fastest setting should be okay. That said you may get more cycles if you charge at 500mah when you are not in a hurry. Anyhone else?!......
_____________________________
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to Ed)
       Post #: 2
RE: Can I fast charge NiMh batteries ? - 11/19/2012 6:16 PM
Four Stroker
Score: 104
Last Login: 6/10/2013
Status: offline
The Sirius charger charges all batteries at 500 mA. The TX side assumes 500 mAh cells and may time out before reaching 1650. Mine will put only about 1200 in on the TX side.
Hide Signatures
(in reply to Goldenduff)
       Post #: 3
RE: Can I fast charge NiMh batteries ? - 11/19/2012 6:28 PM
flyinwalenda
Score: 167
Status: offline
NiMh batteries can and will become damaged if charged at too high an amperage where NiCd's can take it.  It is the heat generated during charging that can cause the damage(actually too much heat can damage any chemistry battery). I would charge it  at the  0.5 amp setting  for about 3.5 hours max .
Brian Ray
Hide Signatures
(in reply to Four Stroker)
       Post #: 4
RE: Can I fast charge NiMh batteries ? - 11/19/2012 6:52 PM
Goldenduff
Score: 114
Status: online
3.5hrsx 500mah= 1750mah. If charging from flat I don't think that's long enough given the inefficiency of charging and that the charge reduces as the battery approaches full.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 5
RE: Can I fast charge NiMh batteries ? - 11/19/2012 8:08 PM
Ed
Score: 121
Status: offline
The Sirius charger that I am using doesn't have a timed option, it's a "peak" charger. It stops charging when it estimates the batteries are fully charged. So is there a chance that it will not fully charge my NiMh's ? I'm also concerned about them over heating if charged too fast. Is there anyone out there who is using this charger to successfully charge 1650 mah NiMh's ?
Hide Signatures
       Post #: 6
RE: Can I fast charge NiMh batteries ? - 11/19/2012 9:49 PM
Goldenduff
Score: 114
Status: online
Don't worry about it. That chemistry is relatively stable. Put them on to charge when you know you will be about. When they are slightly warm they are done!
Hide Signatures
(in reply to Ed)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.125RCU1
