boring carbon prop    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> boring carbon prop
Page: [1]
Login
boring carbon prop - 11/19/2012 2:30 AM
Rudy
Score: 101
Last Login: 6/19/2013
Status: offline
fficedocumentsettings> fficedocumentsettings>
What have you done? I have a couple of PT carbon props and need to enlarge center hole from 6mm to 8mm. I’ve never drilled in carbon before and better safe than sorry. I have an 8mm drill and always use a backing board for drill through most materials. verridetablestylehps> verridetablestylehps>
Hide Signatures
       Post #: 1
RE: boring carbon prop - 11/19/2012 2:35 AM
Rudy
Score: 101
Status: offline
fficedocumentsettings> fficedocumentsettings> verridetablestylehps> verridetablestylehps>
Hide Signatures
(in reply to Rudy)
       Post #: 2
RE: boring carbon prop - 11/19/2012 2:51 AM
wyowindworks
Score: 113
Last Login: 6/18/2013
Status: offline
You can drill carbon fiber with just a regular drill bit used to drill metal.  Backing the hole is always a good idea.
< Message edited by wyowindworks -- 11/19/2012 6:06 AM >
Hide Signatures
(in reply to Rudy)
       Post #: 3
RE: boring carbon prop - 11/19/2012 5:33 AM
yojoelay
Score: 105
Last Login: 6/15/2013
Status: offline
Why would you not use a prop reamer? I drill bit isn't going to center the hole as well as a prop reamer would.
Joel
_____________________________
Maker of fine kindling
Hide Signatures
(in reply to wyowindworks)
       Post #: 4
RE: boring carbon prop - 11/19/2012 3:57 PM
MTK
Score: 203
Status: online
quote:
ORIGINAL: yojoelay
Joel
Either a prop reamer or drill press and drill bit work fine. Even a hand drill and drill bit work fine since the bit will self center on an existing hole. The better method is the drill press  assuming the stage is square to the drill bit. Windyworks is correct on the type of drill bit....a standard high speed drill bit works fine
Regards,
MattK
Hide Signatures
(in reply to yojoelay)
       Post #: 5
RE: boring carbon prop - 11/19/2012 10:11 PM
combatpigg
Score: 381
Status: offline
A drill bit can "walk" off center, especially in really hard material. Thankfully, model engine props aren't that hard to drill. I have alot of oddball sized prop shafts on various engines. There are times at the field where I have taken a drill bit, held it firmly with a pair of pliers and then rotated the prop by hand down the drill bit. Usually the application is for the odd sized little engines that have no true standard shaft sizes.
No doubt that a reamer is the most fool proof way to go, but I can not think of any time that using a drill bit has failed me..
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to MTK)
       Post #: 6
RE: boring carbon prop - 11/21/2012 12:10 AM
Ed Smith
Score: 113
Last Login: 6/17/2013
Status: offline
If ypu have to drill out the hole in any prop may I suggest you do the following. Grind the sharp edge off the cutting edge of the prop. This will prevent the drill from"grabbing" and drilling off centre.
Ed S
Hide Signatures
(in reply to combatpigg)
       Post #: 7
RE: boring carbon prop - 11/21/2012 5:47 PM
dbsonic
Score: 100
Status: offline
But it is going to dull the bit like no other material. Bit will probably still be usable for wood probably.
Hide Signatures
(in reply to Ed Smith)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
