Power Supply    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> Power Supply
Page: [1]
Login
Power Supply - 11/19/2012 1:13 PM
alis902
Score: 100
Last Login: 4/7/2013
Status: offline
Hi
To those who are using the - "(50amp 24VDC) Turnigy 1200W 100 ~ 120V Power Supply"
I have a question.
While thinking about buying, I want to know the capacity.
If the battery of the class "5S 4500mAh35 ~ 70C Lipo Pack. The battery is"
Can you charge what outdoors pack?
About three times? (3 minutes flight?)
Hide Signatures
       Post #: 1
RE: Power Supply - 11/20/2012 8:31 AM
PatternFlyer
Score: 100
Last Login: 5/18/2013
Status: offline
A little confused.
Your question is asking about the capacity of a pack to charge?
It started with power supply for charger.
What charger do you use? Size of a pack you can charge depends on charger & input that the charger can hadle.
_____________________________
Hide Signatures
(in reply to alis902)
       Post #: 2
RE: Power Supply - 11/21/2012 5:26 AM
alis902
Score: 100
Status: offline
 Hi
Charger to use is "Hyperion HP-EOS0720iNET3-AD".
Hide Signatures
(in reply to PatternFlyer)
       Post #: 3
RE: Power Supply - 11/21/2012 6:03 AM
PatternFlyer
Score: 100
Status: offline
720iNET3 AD is AC/DC charger. It looks to have maximum charge capacity of 250 Watts. 20Amp max.
Nominal voltage of 5S is 18.5V. 250 / 18.5 is 13.51A. So your charger will not do any higher than 13.51amp on 5S packs
Your power supply will handle up to 3 of these charger charging 5S packs.
You may want to look at Thunder Power 820, 1430 or Revolectrix/FMA PowerLab8 for higher charging capability.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.141RCU1
