Solidworks- is it possible to "bend" during assembling?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Solidworks- is it possible to "bend" during assembling?
Page: [1]
Login
Solidworks- is it possible to "bend" during assembling? - 11/19/2012 4:38 PM
ArneK
Score: 100
Last Login: 5/4/2013
Status: offline
Hi,
I'm a total beginner and I have an Autocad drawing I would like to convert into Solidworks to see if the parts fit.
I drew the parts and now I'm trying to make an assembly.
The formers now in place have the same size outside so to mate was quite easy... ;-)
But... more to the nose of the back of the fuselage the former are getting smaller (red arrow) and I don't know how to continue.
As a beginner I would say I have to "bend" the outsides a little more inwards (green arrows) to make the next part fit.
Could someone please point me in the right direction?
Kind regards,
Arne.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Solidworks- is it possible to - 11/19/2012 5:57 PM
aymodeler
Score: 100
Last Login: 5/25/2013
Status: offline
If you are asking if it is OK to bend the fuselage sides inward as it tapers towards the tail, then the answer is yes, that is very typical. Of course, the amount of "bend" your part can withstand will be a function of the material and the thickness. The only other caution being that if you have a flat side (like you show in your picture) that you are only bending in one direction. If you have a compound bend, then you would typically just use stringers and then cover (either with balsa sheeting/planking or with some other covering material).
_____________________________
Please check out my rc airplane blog at http://arcplane.wordpress.com
Hide Signatures
(in reply to ArneK)
       Post #: 2
RE: Solidworks- is it possible to - 11/19/2012 6:32 PM
Laird SS
Score: 100
Last Login: 5/19/2013
Status: offline
In my experience with SolidWorks, I have not found a way to "bend" a part. It would be nice, and if it exists, I haven't found it. I would model the part with the bend in it. Since the material is uniform in its properties and tangent to the straight portion at one end, I would suspect that bend would in the shape of an arc that is tangent to the straight side and also to some portion of the nose. What version of SW are you using?
Hide Signatures
(in reply to aymodeler)
       Post #: 3
RE: Solidworks- is it possible to - 11/19/2012 6:37 PM
ArneK
Score: 100
Status: offline
Thanks!
I do have a good idea how to build this fuselage and your right, it will taper to the front and to the rear.
But my question is, how to do this in Solidworks...
How do I bend the 2 outer parts inwards to let the new part fit and mate?
In practice the material that should bend is 1,5mm plywood so that shouldn't be a problem.
Them mean problem now is my lack of knowledge... ;-)
Hide Signatures
       Post #: 4
RE: Solidworks- is it possible to - 11/19/2012 6:44 PM
ArneK
Score: 100
Status: offline
I'm using version 2010... ;-)
Hide Signatures
(in reply to ArneK)
       Post #: 5
RE: Solidworks- is it possible to - 11/19/2012 10:00 PM
aymodeler
Score: 100
Status: offline
Can't help you there ...
Hide Signatures
(in reply to ArneK)
       Post #: 6
RE: Solidworks- is it possible to - 11/20/2012 2:17 AM
R_G
Score: 135
Last Login: 5/26/2013
Status: offline
In SolidWorks 2011 it can be done with the "Flex" feature. I'm guessing that 2010 also has this feature.
The "Deform" feature might also work.
RG
Click for fullsize
Ralph Geese, AMA 36403, NECPO #2
Wanna hover? Fly a heli!
Hide Signatures
       Post #: 7
RE: Solidworks- is it possible to - 11/20/2012 4:15 AM
haikt
Score: 110
Last Login: 4/6/2013
Status: offline
You can do this couple of ways one as stated above is by flex function which should work the best.
You can always design (loft) the part from the start.
You can also try to convert the part to sheet metal and use bend, flange on your part. This will also help you to unfold the part (flat pattern) for laser cutter
Hide Signatures
(in reply to R_G)
       Post #: 8
RE: Solidworks- is it possible to - 11/20/2012 9:23 PM
Hemikiller
Score: 100
Status: offline
quote:
ORIGINAL: haikt
I was thinking the same thing on converting it to a sheetmetal part. You would just need to use a very large radius for the "bend".
Hide Signatures
(in reply to haikt)
       Post #: 9
RE: Solidworks- is it possible to - 11/20/2012 11:55 PM
grh_70
Score: 100
Status: offline
The Flex feature is included in SW 2010.
Hide Signatures
(in reply to R_G)
       Post #: 10
RE: Solidworks- is it possible to - 11/22/2012 8:07 AM
ArneK
Score: 100
Status: offline
I want to thank you all for reponding...
Using the flex feature I got the parts into the right shape, more or less.
Now I'm trying to mate the "flexed" parts which is not that easy...
Hide Signatures
(in reply to grh_70)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.532RCU1
