Covering question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Covering question
Page: [1]
Login
Covering question - 11/19/2012 9:49 PM
daytonarc
Score: 100
Last Login: 5/24/2013
Status: offline
This is not a post looking for bashing of Monocoat or Ultracoat, there are plenty of those out there.  I have built and repaired with Ultracoat with sucess but will be using monocoat for the first time due to the availability locally of what I needed.  It will be installed on bals/built up plane.  Just looking for some tips on what may be different as far as application mothods and shrinking etc.
Hide Signatures
       Post #: 1
RE: Covering question - 11/19/2012 9:58 PM
sensei
Score: 176
Last Login: 5/26/2013
Status: offline
Do yourself a favor, get a buddy to assist you in pulling the covering really tight as you iron the edges, work slowly and allow the iron to shrink problem areas out at it's own pace. you are probably not going to like working with Monokote but you can get a superior finish in the end.
Bob
_____________________________
Fly It Like You Stole It!!!
Hide Signatures
(in reply to daytonarc)
       Post #: 2
RE: Covering question - 11/19/2012 10:44 PM
eddieC
Score: 249
Status: offline
Monokote generally has a higher shrink and also has higher temp limits. The Coverite bimetal temp gauge is great to set the iron, or a laser temp device is also great.
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to sensei)
       Post #: 3
RE: Covering question - 11/19/2012 11:09 PM
SunDevilPilot
Score: 147
Status: offline
Monokote seems to shrink as the heat is removed.  Heat an area and move away and watch.  Don't just sit there with the heatgun baking an area and expecting it to shrink.
SunDevilPilot
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
(in reply to eddieC)
       Post #: 4
RE: Covering question - 11/20/2012 12:01 AM
Gray Beard
Score: 314
Status: offline
Just goes on at a higher temp and doesn't shrink as well. Don't hold the heat gun in one spot very long, you can blow a hole in mono faster then Ultra too. Sometimes there is no warning at all, other times it will start to change color a bit then sort of pop.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 5
RE: Covering question - 11/20/2012 12:28 AM
daveopam
Score: 191
Status: offline
More heat, and don't be afraid to pull it as you heat it around wing tips and other round surfaces.
david
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to Gray Beard)
       Post #: 6
RE: Covering question - 11/20/2012 4:13 AM
partisan
Score: 100
Last Login: 5/25/2013
Status: offline
All I have ever used is monokote. I have learned to get the edges sealed down (except for a little spot on fully sheeted surfaces). Then I get the heat gun out to start heating it and the use the hot glove to press it to the sheeting or cap strips. As you heat the covering that is over the sheeting it will wrinkle a little, then with a little more heat, it lays flat. That's when I press it down and stick it.
The cap strips are the same, just need to be more cautious cause too much heat will burn holes in it fast.
Just take your time and it will pay off.
Hide Signatures
(in reply to daveopam)
       Post #: 7
RE: Covering question - 11/20/2012 2:12 PM
daytonarc
Score: 100
Status: offline
Thanks for the suggestions.  I will probably be doing this over the weekend so if anybody else has any suggestions, reccomendations or techniques to share please post them.
Thank you
Hide Signatures
(in reply to partisan)
       Post #: 8
RE: Covering question - 11/20/2012 3:17 PM
sensei
Score: 176
Status: offline
If you normally cover one in Ultra on a weekend, you might be in for a little shocker, but again just take your time and it will look great in the end...
Bob
Hide Signatures
       Post #: 9
RE: Covering question - 11/20/2012 3:28 PM
daveopam
Score: 191
Status: offline
There is one other thing I like to do, no matter the brand of covering. On your smaller items like an ELEV half for example. Take a T pin and make a small hole between each of the open areas and one more hole on the end of one of the same areas. On a small thin area the hot air can and will swell up the covering like a baloon. and makes it nearly impossible to shrink down. If this area is sheeted it makes no difference. This tip is for open bays mostly found on rudders and elevators. This also works well on ARFs. just put the holes in the hinge line where they wont be seen.
David
Hide Signatures
       Post #: 10
RE: Covering question - 11/20/2012 3:55 PM
EscapeFlyer
Score: 120
Status: offline
david
Make sure the edges are completely sealed!!!! YES YES YES!!!
If you are using Monokote, shoot the entire frame with a cheap hairspray. I use Aquanet....
The hairspray will seal the wood, but also helps the Monokote adhere to the frame.
My .02 cents.
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
       Post #: 11
RE: Covering question - 11/20/2012 8:27 PM
wickedpissa
Score: 110
Status: offline
quote:
ORIGINAL: SunDevilPilot
SunDevilPilot
this is is a great tip it took me a while to figure that out,
when I to wing tips I pull real tight tack in place with iron then seal edges,  heat with real high heat from gun the let cool then hit it again always letting cool and never holding the gun wating for it to shrink, as it will do that when it cools
Hide Signatures
       Post #: 12
RE: Covering question - 11/20/2012 8:38 PM
daytonarc
Score: 100
Status: offline
quote:
ORIGINAL: wickedpissa
SunDevilPilot
Thanks guys, I never would have known this untill I ruined my project.  I heat the Ultracoat till I see it shrinking.
Hide Signatures
(in reply to wickedpissa)
       Post #: 13
RE: Covering question - 11/20/2012 9:26 PM
bjbellino
Score: 100
Status: offline
daytona, all of the above are great suggestions. If you don't have a temp gauge. I've found that when you touch the covering with the iron, if the temp is close, covering will turn just a little darker, if there is a big color change, iron is too hot. Same with the gun, big color change, you are about to burn a hole in the covering. Naturally this doesn't work with clear. But once you have found that sweet spot with your iron, you will remember it. Monokote always came with good photo instructions, hope they still do. You will use a lot of single edge razor blades, cause monokote dulls them fast, but a sharp cutter is essential to a good job, enjoy.
Hide Signatures
       Post #: 14
RE: Covering question - 11/20/2012 10:01 PM
jetmaven
Score: 100
Status: offline
Alternatively , you can move closer to an Ultracoat dealer , I would
Hide Signatures
(in reply to bjbellino)
       Post #: 15
RE: Covering question - 11/20/2012 10:34 PM
daytonarc
Score: 100
Status: offline
quote:
ORIGINAL: jetmaven
LOL.  Actually my LHS carries both.  He didn't have what I needed in stock for either Monocoat or Ultracoat.  I was placing an order for some parts for an O.S. Engine I needed with Tower Hobbies because I had a coupon code so I added the covering to the order and they don't carry Ultracoat.  I could have ordered it from somewhere else but I didn't want to pay another shipping charge.  I enjoy learning new things anyways so trying Monocoat will be an experience.  Thanks to everybody for the tips.  Please keep them coming.  Hopefully with the experience of others as a guide my project will work out.
Hide Signatures
(in reply to jetmaven)
       Post #: 16
RE: Covering question - 11/20/2012 11:03 PM
jetmaven
Score: 100
Status: offline
I actually have some left over Monokote that's fine , it is however , over 20 years old and I treasure it because I still fly planes that were originally covered with it and as you know #%£! happens .
There has been a lot written about whatever happened to the "old Monokote " but that's rhetoric . I exclusively use Ultracoat and have said goodbye to sags , bubbles , blisters and the need to fix them every time I come home from the field after a nice steamy day in the Florida sun .
And yes , even the transparent green is flawless
Hide Signatures
       Post #: 17
RE: Covering question - 11/20/2012 11:34 PM
tony0707
Score: 115
Last Login: 5/23/2013
Status: offline
All the old transparent monocoats are excellent and have stayed stuck down on my planes for 15 years in more than one case
One of the best monocoats for staying put for a long time
Not sure about any newer formulas
The transparent is also lighter by a little
The color of the film covering will have some effect on how well the covering deals with the heat applyed and its workability
Some colors work better than others
Click to see fullsize image.
Click for fullsize
Click for fullsize
" The power and performance glo fuel , 15 % Morgan Omega "
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
