Problem with Tornado S30 Motor.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Problem with Tornado S30 Motor.
Page: [1]
Login
Problem with Tornado S30 Motor. - 11/19/2012 11:26 PM
Torch39
Score: 100
Last Login: 5/21/2013
Status: offline
Ok so I have not been able to get my RC car running in a long time. I have noticed in some attempts to get it started gas coming out between the head and the bottom end of the motor.. I pretty sure that means air is defentaly getting in there and no way it will start.. Question is if I replace that copper shim thing that is in there will it fix it?? Or should i replace the motor?
Hide Signatures
       Post #: 1
RE: Problem with Tornado S30 Motor. - 11/19/2012 11:39 PM
nitrosportsandrunner
Score: 296
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Torch39
if the motor still has pinch (compresion) then its worth replacing a seal or a shim to see if that fixes the situation.
also, check the bolts holding the cooling head to the motor. they may have just come loose.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to Torch39)
       Post #: 2
RE: Problem with Tornado S30 Motor. - 11/19/2012 11:48 PM
Torch39
Score: 100
Status: offline
How do I know if it has compression? I ran a out 2 and half gallons of gas through the motor.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: Problem with Tornado S30 Motor. - 11/20/2012 12:52 AM
Score: 296
Status: offline
quote:
ORIGINAL: Torch39
2.5 gallons is a fair bit of runtime. but if its taken good care of it should still have life left.
compression is felt buy how hard it is to pull over the motor. when the piston hits top dead center it should snug against the wall of the cylinder. that feeling is called "pinch". on a fresh motor, the pinch can be strong enough that its hard to pull over the motor.
you can also get a feel for the pinch by pulling the glow plug out and turning the motor over by hand (via the flywheel) you should be able to feel the pistion "stick" slightly at the top. You should also be able to hear it suck air.
As well, you can pull off the cooling head and put a finger into the cylinder. at the top, you should feel a slight ridge. if you dont...if the top of the inside feels very smooth then the pinch may be gone and it wont run well (if at all)
but since you have fuel being sucked into the motor, its more likely you have an air leak, then a junk motor.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
