EasyTiger Models SBD Dauntless 100"ws    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> EasyTiger Models SBD Dauntless 100"ws
Page: [1] 2   next >   >>
Login
EasyTiger Models SBD Dauntless 100"ws - 11/20/2012 12:44 AM
uncljoe
Score: 160
Last Login: 5/18/2013
Status: offline
Just started to get things in order befor I start . I got this arf on the "Sandy Sale " or "First Bus out of the Big Apple"  . I'm am not a shill and I will give you an honest assesment of the kit .  After its 5 day trip it arrived by grayhound, condition of the two boxes were great, no problems ..I wanted to make an 1939 paint ( chrome yellow wings, red stabs,red/white/blue fin,etc) scheme , so the first thing I did was to fill the GIANT rivit holes( about 3/16" so say 1.75' full scale)  and first coat of silver.
 More photo's later
 I plan on powering it with a DA 85   ......
  Semper Fi
 Joe
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by uncljoe -- 12/15/2012 6:46 PM >
_____________________________
Look towards the Horizon......your death awaits you there
Hide Signatures
       Post #: 1
RE: EasyTiger Models SBD Dauntless 100"ws - 11/20/2012 5:22 AM
77chickenhawk
Score: 105
Status: offline
What is your inside cowl diameter please. Thank you very much
Just Make It Look Real !!!
Hide Signatures
(in reply to uncljoe)
       Post #: 2
RE: EasyTiger Models SBD Dauntless 100"ws - 11/20/2012 3:09 PM
uncljoe
Score: 160
Status: offline
quote:
ORIGINAL: 77chickenhawk
  Its 11.00"  x  12.25 "
Semper Fi
< Message edited by uncljoe -- 11/20/2012 3:49 PM >
Hide Signatures
(in reply to 77chickenhawk)
       Post #: 3
RE: EasyTiger Models SBD Dauntless 100"ws - 11/20/2012 11:45 PM
uncljoe
Score: 160
Status: offline
 Landing gear arrived today and it impressive .. all that is needed is a servo yo operate the value .
 TodayI went through all the areas I could see to see just how the glue joints looked ,Overall Not too bad, few areas I ran another bead of aero poxey ( actually its a lot better constructed that I've seen on a few hi dollars jet kits from chineese mfg.)
Semper Fi
  Joe
Click for fullsize
< Message edited by uncljoe -- 11/21/2012 5:32 PM >
Hide Signatures
       Post #: 4
RE: EasyTiger Models SBD Dauntless 100"ws - 11/21/2012 5:32 PM
uncljoe
Score: 160
Status: offline
I did not like the way the tourque rod for the rudder is secured.just glue the rod into the rudder, so I drilled a hole thru the rudder and tourque rod and pined its place in the rudder.
Semper Fi
 Joe
Click for fullsize
Hide Signatures
       Post #: 5
RE: EasyTiger Models SBD Dauntless 100"ws - 12/2/2012 7:42 PM
lrb75
Score: 100
Last Login: 5/19/2013
Status: offline
Most people call vallawyer a shill because he says he has multiple easytiger planes for years but never posts a single picture. If you post pictures, like you are doing, showing the good points and bad points of the model people will just thank you.
Hide Signatures
(in reply to umitv)
       Post #: 6
RE: EasyTiger Models SBD Dauntless 100"ws - 12/2/2012 9:56 PM
DavidAgar
Score: 146
Status: offline
Okay guys, this started of as a build thread on a Dauntless. We are not going to over take the intent of this thread with the pro's and con's of Easy Tiger, nor are we going to discuss shills for Easy Tiger. Thanks for your understanding, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to lrb75)
       Post #: 7
RE: EasyTiger Models SBD Dauntless 100"ws - 12/3/2012 12:47 AM
uncljoe
Score: 160
Status: offline
Guys if you have a problem with ET take it up with him don't polute this thread. I am pretty pleased with the kit .,been slowed down by a health problems and  Just finished the servo installation & linkage on the stabs,& ailerons ,BTW the hardware is great.and all present in the kit . So far the only problem has been with the dive brakes . two were warpped ,used steam and a heat gun to reform them .Monday I plan on finishing the dive brakes (linkage and servos)   Again I'm NO Shill just someone who likes unusal kits and willing to do some quality control, IMO this kit is as good as some of the preimer MFG .
Semper Fi
 Joe
Hide Signatures
(in reply to DavidAgar)
       Post #: 8
RE: EasyTiger Models SBD Dauntless 100"ws - 12/3/2012 2:24 AM
Chad Veich
Score: 265
Status: offline
Lookin' good Joe. I've already got the artwork drawn up for the pre-war American insignia so all I need to know is what diameter you need and I will get some paint stencils cut for you.
Hide Signatures
       Post #: 9
RE: EasyTiger Models SBD Dauntless 100"ws - 12/14/2012 6:10 PM
uncljoe
Score: 160
Status: offline
 Few shots of my progress .  a few issues .. the axels provided are either too short (Approx 1/4 ") or the tires are too wide . Had to make a stand off 7/16" to put on axel to keep the tire from hitting the strut . Also cut down the strut lenght by approx 3/8 " so that it would seat in the trundem along with filing a flat spot in the strut to keep the strut from turning (small grub screw on trunden), These are NOT real issues just things a model builder should be aware of . Where the plans call for holes to be drilled (rear of center section ) will not go thru the bering blocks in the wing ,so drill them where they will go thru the blocks .  The only BITC* I have is that,the Chineese plastic parts are REAL BRITTLE not enough flexable stuff made in the plastic ,causing the plactic to crack when cutting . This is a mfg problem which the importer has no control over .  I'll post more photos of my final assembly
 Semper Fi
  Joe
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Chad Veich)
       Post #: 10
RE: EasyTiger Models SBD Dauntless 100"ws - 12/14/2012 6:18 PM
glazier808
Score: 291
Status: offline
Looks good uncljoe. Like the new paint.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 11
RE: EasyTiger Models SBD Dauntless 100"ws - 12/14/2012 6:26 PM
uncljoe
Score: 160
Status: offline
quote:
ORIGINAL: glazier808
Casey
Casey
  My eyes are NOT what they once were & Need all the help I can get . need the stars & dots (coming)
 While I'm thinking about it the servo mount tray need to have some horizonal stiffiners it flexes as the rudder / tail wheel moves ( I'm using CF fiber push rods and I don't really care for the push/pull  provided) Hopefully I'm read for the maiden flight around the first of the year.
Semper Fi
Joe
Hide Signatures
(in reply to glazier808)
       Post #: 12
RE: EasyTiger Models SBD Dauntless 100"ws - 12/14/2012 6:57 PM
Alain RONK
Score: 100
Last Login: 1/8/2013
Status: offline
 Hello !
Your Dauntless is very great !
In French, we also build Dauntless :
http://www.modelisme-racer.fr/ceux-des-copains/en-photos/
Best regards !
Alain
Best regards
Alain
Hide Signatures
       Post #: 13
RE: EasyTiger Models SBD Dauntless 100"ws - 12/14/2012 9:26 PM
uncljoe
Score: 160
Status: offline
Hello Alain
  You SBD has the same scheme I will be using,USMC bombing 2  BTW you have some great looking aircraft on that page
Semper Fi
 Joe
Hide Signatures
(in reply to Alain RONK)
       Post #: 14
RE: EasyTiger Models SBD Dauntless 100"ws - 12/15/2012 4:02 AM
FireBee
Score: 100
Status: offline
Joe,
I love the fact as a scale nut, within 10 minutes you are already sanding and filling to make this your one of a kind paint scheme.
The new Dauntless is looking very nice.
Mike P.
Hide Signatures
       Post #: 15
RE: EasyTiger Models SBD Dauntless 100"ws - 12/15/2012 6:40 AM
Alain RONK
Score: 100
Status: offline
Hello Joe
Thank you for your replie, it's cool !
Best regards !
Alain
My french website : www.modelisme-racer.fr
Best regards
Alain
Hide Signatures
       Post #: 16
RE: EasyTiger Models SBD Dauntless 100 - 12/15/2012 10:10 PM
WhoDaMan
Score: 850
Status: offline
Joe she looks sweet
Doesn''t "expecting the unexpected"
Make the unexpected expected?
Hide Signatures
       Post #: 17
RE: EasyTiger Models SBD Dauntless 100 - 1/5/2013 4:28 PM
Texastbird
Score: 150
Status: offline
What are you planning for a power plant, Joe?
Hide Signatures
(in reply to WhoDaMan)
       Post #: 18
RE: EasyTiger Models SBD Dauntless 100 - 1/5/2013 7:31 PM
lrb75
Score: 100
Status: offline
Uncle Joe, For the brittle plastic parts the ESM warbirds have the same issue with their canopies. I read in another thread if you do the cutting under hot water they won't crack. It worked great on my P-40. Looking forward to a maiden flight video.
Hide Signatures
(in reply to Texastbird)
       Post #: 19
RE: EasyTiger Models SBD Dauntless 100 - 1/6/2013 12:37 AM
Capt G
Score: 100
Status: offline
Can you please tell me what silver paint you are using? Thanks
Also what red?
Hide Signatures
(in reply to lrb75)
       Post #: 20
RE: EasyTiger Models SBD Dauntless 100 - 1/6/2013 1:10 AM
SrTelemaster150
Score: 229
Status: online
My very 1st powered aircraft was a C/L 1/2A SBD Dauntless W/an .049 Wen Mac engine.
That was my Christmas present in 1963.
It even had a bomb drop feature that was controlled by a 3rd line attached to the U-Control Handle just above the "UP" cable..
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 21
RE: EasyTiger Models SBD Dauntless 100 - 1/8/2013 8:00 PM
uncljoe
Score: 160
Status: offline
Texastbird  a DA 85  26/10 pro[,  6 pound of ballast ..UG ! to CG.....
CaptG  Dulpli-color  chrysler color red
                                     Toyota Silvermist
                                     Ford chrome yellow
  Irb75         Thank you  for the tip on the brittle plastic parts I will use your warm water method
         I think the ziroli sbd canopy just might br the soluation to cloudiness of the clear plastic,and easy of cutting...
Semper Fi,Mac
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 22
RE: EasyTiger Models SBD Dauntless 100 - 1/8/2013 8:45 PM
Mpizpilot
Score: 100
Status: online
Following with great interest. I'm considering giving the LA-7 a try myself.
Hide Signatures
       Post #: 23
RE: EasyTiger Models SBD Dauntless 100 - 1/8/2013 8:52 PM
Texastbird
Score: 150
Status: offline
Missed the engine size in your first post. I was too distracted by the pictures! If the Ziroli canopy is the right size, that would be a great backup or replacement.
A Gt 80 might be a little heavier and be smoother running since its a twin. Just a thought.
Hide Signatures
       Post #: 24
RE: EasyTiger Models SBD Dauntless 100 - 1/8/2013 10:15 PM
uncljoe
Score: 160
Status: offline
 Gotta use what I have on handf....my next will be Moki 150 .. a purfffffffffect   power plant
Semper Fi Mac.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
