lipo battery suddenly died, then restored itself back **** ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> lipo battery suddenly died, then restored itself back **** ? Page: [1]
Login
lipo battery suddenly died, then restored itself back *... - 11/20/2012 10:59 AM
ollie1
Score: 100
Last Login: 4/9/2013
Status: offline
hey all was driving my traxxas summit, i have 2 voltage displays on it so i can keep an eye on the voltage.
i was driving it today and suddenly the lights turned off and lost power. running 2 2s lipos 1 side went down to 7.0 volts but the other side was 5.2 volts it dropped so fast before i even got to check it. on the way home i checked it again and it was slowly going up, eventually going back up to 6.4. why did it do that ? is the battery still okay or what ? its charging now but dont know if it will be any goood or not. any advice would be appreciated as im a complete beginner
Hide Signatures
       Post #: 1
RE: lipo battery suddenly died, then restored itself ba... - 11/20/2012 11:39 AM
Goldenduff
Score: 114
Last Login: 5/24/2013
Status: offline
It should be fine. Balance charge at a sympathetic rate (0.8C). When the motor is drawing current the voltage can sag. This can slowly recover. It might be a sign that that lipo is on the way out or is not up to the job.
What capacity (mah) is the lipo, what C rating is it and do you know what max current your truck draws?>
_____________________________
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to ollie1)
       Post #: 2
RE: lipo battery suddenly died, then restored itself ba... - 11/20/2012 11:49 AM
ollie1
Score: 100
Status: offline
its pretty much brand new, its only had 2 cycles, its a 5000mah 30 - 40c turnigy, i have a cheapo lipo charger it takes around 12 hours to charge
Hide Signatures
(in reply to Goldenduff)
       Post #: 3
RE: lipo battery suddenly died, then restored itself ba... - 11/20/2012 12:09 PM
ollie1
Score: 100
Status: offline
so is the battery pretty much stuffed because it discharged so much quicker then the other one ?
Hide Signatures
       Post #: 4
RE: lipo battery suddenly died, then restored itself ba... - 11/20/2012 12:18 PM
Goldenduff
Score: 114
Status: offline
In my opinion it depends. As long as the voltage per cell doesnt go bellow 3v it should be fine. Balance charge it at 0.8C and see if it comes up.
The truck probably cut out because at full throttle the voltage sags so if running a bit low it can be enough to trigger low voltage cut off with your ESC. 5000mah at 30C is realistically more like max sustainable amp out put of 100amps per lipo. Do you know what the truck draws amp wise?
Hide Signatures
       Post #: 5
RE: lipo battery suddenly died, then restored itself ba... - 11/21/2012 1:25 AM
ollie1
Score: 100
Status: offline
thats the thing tho it doesnt have a lipo cutoff its a brushed one, and it was 5.2 when i first checked it so it would have dropped to 2.6 per cell but then it stared increasing. im not sure what you ment about max sustainable amps ? and i have absoloutley no idea but i will try find out
Hide Signatures
       Post #: 6
RE: lipo battery suddenly died, then restored itself ba... - 11/21/2012 6:15 AM
Goldenduff
Score: 114
Status: offline
The battery can only deliver a certain amount of amps. Capacity x c rating. Always exaggerated so divide this number by 0.85. If the motor draws more than this battery will get damaged. Brushed motors can still cause voltage sag.
Hide Signatures
       Post #: 7
RE: lipo battery suddenly died, then restored itself ba... - 11/21/2012 10:10 AM
trax de max
Score: 114
Last Login: 5/25/2013
Status: offline
I'd get a new charger if it takes 12hours to charge. You want something that takes an hour to charge.Is that per battery or 6 hours each.
To have packs that far apart i'd guess one pack wasn't charged fully and would ditch both as ideally they need to be matched packs. You want something that takes an hour to charge.
To save money buying a cheap charger will cost you more money as now you need to replace the batteries. You maybe could replace one, but I wouldn't not knowing the history of the other.
And buy an LVA.
Sorry officer i thought the speed limit only applied to people with driving licenses.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
