Propeller position gas engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Propeller position gas engines
Page: [1]
Login
Propeller position gas engines - 11/21/2012 3:49 AM
larryak
Score: 105
Last Login: 3/24/2013
Status: offline
I have been setting up my propeller position for hand propping on a gas BME 44 as follows: Top blade at position 45 d right of center with the magnet on the hub at approximately 45d prior to the magnetic sensor on the compression stroke.  I seem to be having fair but not great success on fast starts. Takes 4 handprops to fire with the choke on and then 7-8 handprops to fire. Seems like a lot of handpropping. Am I missing something here???
Hide Signatures
       Post #: 1
RE: Propeller position gas engines - 11/21/2012 4:52 AM
Gray Beard
Score: 314
Last Login: 6/17/2013
Status: offline
Some engines just require more flipping then others. I set mine at 10 O'Clock when the piston is at just on compression. One flip after the pop on choke usually fires my Brison and RCS. My Zinoah G-62 never did like to hand start so I put a spring starter on it and it popped on choke first spin and fired on one spin after that. All the gas engines I have ever owned liked a few drips of gas to drip out the carb before I wasted my time flipping.
_____________________________
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to larryak)
       Post #: 2
RE: Propeller position gas engines - 11/21/2012 11:54 AM
Luchnia
Score: 193
Last Login: 6/18/2013
Status: offline
I drill mine at about 1 to 2 o'clock which is just before compression and they start very nicely. Sometimes some engines start a little differently than others. I think 3 or 4 pops on choke is about the norm and about 3 or 4 off choke is normal. I have one that starts with less and one that takes a tad more. My observations of other flyers has shown about the same.
Hide Signatures
       Post #: 3
RE: Propeller position gas engines - 11/21/2012 12:31 PM
flyinwalenda
Score: 167
Status: offline
I also put the prop on at TDC around 2&8 /3&9 o'clock for starting and also for dead sticks so it's not pointed toward the ground. If they have a choke then they will usually pop on or before 3 flips and off choke usually start on or before 4 flips. If no choke I manually choke it by having full throttle ,kill on,  finger in/over carb, rocking the prop back&forth until my finger gets wet. Then it usually fires right away.
Check to make sure fuel is being drawn on choke and after choke. Maybe you are getting not enough or too much fuel and it's getting flooded. You can tell when it's just right by rocking the engine (kill on) and listen for a slight squishing sound.
A trick to use if you think it's flooded is to rotate or flip the engine backwards(kill on) a few times and that usually cleans out enough fuel so it will start.
Brian Ray
Hide Signatures
(in reply to Luchnia)
       Post #: 4
RE: Propeller position gas engines - 11/21/2012 3:49 PM
Gray Beard
Score: 314
Status: offline
I meant 2 o'clock!! Dumbass, I have a doctors appointment today at 10 o'clock and it's on my mind!! I was even looking at the grandfather clock when I said 10 o'clock. Another senior moment or brain fart. Dumbassdumbassdumbass!!!! This crap isw happening more and more.
Hide Signatures
(in reply to flyinwalenda)
       Post #: 5
RE: Propeller position gas engines - 11/21/2012 5:10 PM
scale only 4 me
Score: 329
Status: offline
you spelled Zenoah wrong too,, we still love ya Gene,, Chilax a little A>G>E> is creeping up on all of us
Hide Signatures
(in reply to Gray Beard)
       Post #: 6
RE: Propeller position gas engines - 11/21/2012 7:46 PM
larryak
Score: 105
Status: offline
Your still our Main man Gene. Keep it coming .
Hide Signatures
(in reply to scale only 4 me)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
