Ace Simple Extra 230    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Ace Simple Extra 230 Page: [1]
Login
Ace Simple Extra 230 - 11/21/2012 5:27 AM
Tee Bee
Score: 100
Last Login: 5/23/2013
Status: offline
I got a good deal on this bird from a local club member recently. He won the kit at a fly-in raffle and built it for electric power. I was at the field when another friend performed the maiden on it for the builder. It seemed to fly well enough but the owner was intimidated by it's small size and agile behavior. He's been moving back to the "slow flyer" types lately as his eyes have been giving him trouble. After watching me fly my 1/2A planes all morning, he decided that I would enjoy it more than he would. I got it for $80 with all new electronic equipment including a Spektrum rx. It's now programmed to my radio and ready for a re-maiden.
The Extra is pictured next to my .049 powered Scalpel that also uses the Ace tapered foam wing cores. The Extra tapers on the trailing edge whereas I cut the root ends of the cores to taper the leading edge of the Scalpel wing. The Scalpel is sleek and thin by comparison and weighs just under 12oz while the portly little Extra weighs in around 22-24oz depending on the LiPo battery used. Same wing area on both.
I will probably leave this one electrified due to the way it was built and set up internally. I have to admit that I've been thinking about building up another one with a tank and glow engine. Looks like a good candidate for an OS .10LA?
Have any of you guys built/flown one of these and how did you like them?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Tee Bee
Hide Signatures
       Post #: 1
RE: Ace Simple Extra 230 - 11/22/2012 12:51 AM
hllywdb
Score: 118
Last Login: 5/24/2013
Status: offline
Did Tee Bee just pee on Leroy Cox's grave and actually post a leekie in this forum? We all love Tee Bee, but if we let one of them in..........
Hide Signatures
(in reply to Tee Bee)
       Post #: 2
RE: Ace Simple Extra 230 - 11/22/2012 1:00 AM
Rubbernecker
Score: 105
Status: offline
Go for it Tee Bee, it's not what they are powered by it's that they are built and small errrrrrr, well it is what they are powered by, but a leekie here and there as long as it's balsa built (by the owner) is o.k. in my book. Just remember where your roots are!
John
Hide Signatures
(in reply to hllywdb)
       Post #: 3
RE: Ace Simple Extra 230 - 11/22/2012 1:33 AM
Tee Bee
Score: 100
Status: offline
Yep. Guilty as charged. I hesitated to post it here but was interested in hearing others' experiences with the plane with a glow engine up front(Particularly an OS .10). I flew it today and it's a fun little bird. Changes directions quickly, snap rolls fast, and spins readily. Doesn't fly on rails like a pattern ship and needs constant attention to keep it pointed where you want it to go. Lands a bit hot. Overall, just challenging enough to keep things interesting. Kind of reminds me of Ken Willard's Top Dawg. I like it.
Don't worry about me forgetting my roots, Rubbernecker. I've been doing a bit of 1/2A flying lately. That's how I ran across this airplane. I haven't built any planes since springtime but as soon as I get caught up with some "non-modeling" projects(Motorcycles), I'll have a new Cox powered toy on the board. Hint: It's name starts with an "S". Stay tuned.
Tee Bee
Hide Signatures
(in reply to Rubbernecker)
       Post #: 4
RE: Ace Simple Extra 230 - 11/22/2012 1:34 AM
Tee Bee
Score: 100
Status: offline
Tee Bee
Hide Signatures
       Post #: 5
RE: Ace Simple Extra 230 - 11/22/2012 3:01 AM
small_rcer
Score: 100
Last Login: 12/4/2012
Status: offline
I would build it with 1/16th balsa sides with partial doublers from the trailing edge forward. A good 049 product engine will make it fly well, a TD 049 will make it hot. I feel the OS 10LA would make it too heavy and it would glide very fast or like a brick.
My Mach None knock off weighs 18 Oz with a TD, 2 oz tank and 3 servos It almost goes vertical with a TD. A simple series built light with 2 servos and 1 oz tank should get down to about 15 to 15 1/2 oz and be a fantastic performer.
Hide Signatures
       Post #: 6
RE: Ace Simple Extra 230 - 11/22/2012 3:27 PM
hllywdb
Score: 118
Status: offline
I have to go more with small_rcer on this one. I have found the OS 10 and the Enya 09 need a bit more wing to keep them from becoming a brick. I have also found that at 1/2a size, the electric to nitro is usually a trade off of thrust vs speed. The TD will have more speed, but a lot less thrust just because of the rpm where they make power. My choice would be a Cox 09 if you need that kind of thrust and power, or a Norvel .074 if you want throttle.
The simple has a lot smaller wing than the Herr, which will carry the 10 or 15 ok, so you need to think a better weight/power ratio motor like the Cox or Norvel. A diesel may give you the thrust you want, but probably not the speed and throttle response you would like.
Hide Signatures
(in reply to small_rcer)
       Post #: 7
RE: Ace Simple Extra 230 - 11/22/2012 4:54 PM
Tee Bee
Score: 100
Status: offline
Thanks for the feedback. I tend to agree. I have a Herr Little Extra that does very well with an OS .15LA. That plane is larger and has lots more wing area and carties the extra weight well. Guess I'll leave well enough alone. Ya see, I have an OS .10LA and really like it but just haven't found the perfect plane for it. It's currently mounted on a Great Planes Electrifly Fokker DVII that I modified extensively for a glow installation. Under full power, it will barely climb and is a real handful. It's a nice looker but it seems like something breaks on the plane everytime I fly it. It has become a hangar queen and I would like to mount the engine on something that will fly well with it.
Tee Bee
Hide Signatures
       Post #: 8
RE: Ace Simple Extra 230 - 11/22/2012 5:02 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: Tee Bee
Yep. Guilty as charged. I hesitated to post it here ........
That's OK, Tee Bee - I know you're still in the fold. I just think of it as highly muffled rotary engine.
For power to weight ratios, ease of use and seamless throttle control, the electrics are getting hard to beat. I must confess that I've been converting my transmitters to a smooth throttle configuration and dropping the ratchet because I can tell a difference in speed moving from one detent position to another. Most of my wet engines were never quite that sensitive.
I agree that the .10 may have too much weight for good flying characteristics. A NORVEL .061 or .074 might be just the ticket, however. You have the TT .07 available; it's very well behaved with good throttling, but a little anemic and a bit porky, so I'm sticking with the NORVEL.
Compared with the Scalpel, the Extra really looks boxey and the Scalpel is really slick.
andrew
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 9
RE: Ace Simple Extra 230 - 11/22/2012 5:18 PM
Tee Bee
Score: 100
Status: offline
"Scalpel is really slick"
....and goes nicely. On rails.
Tee Bee
Hide Signatures
(in reply to Andrew)
       Post #: 10
RE: Ace Simple Extra 230 - 11/22/2012 6:08 PM
hllywdb
Score: 118
Status: offline
Since if you are thinking of building anyway, why don't you scale the simple up to 1/2 way between the original and the Herr? I had an Ace Whizzard that was painfully anemic with a cox 049. So I built one with a built up wing and increased the span from 42 to 45, added a little more cord and ailerons. I flew that for years with an Enya 09 and had a blast.
Hide Signatures
       Post #: 11
RE: Ace Simple Extra 230 - 11/22/2012 6:21 PM
Tee Bee
Score: 100
Status: offline
So many options....
Tee Bee
Hide Signatures
       Post #: 12
RE: Ace Simple Extra 230 - 11/22/2012 6:48 PM
mtntopgeo
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: hllywdb
(quote)tee bee
I've used the Enya .09 on a number of "conversions", & pretty much agree with you guys. At the small end of the scale, I tried a "Simple 400". It was a rocket, & would glide like a brick. The Lil' Extra (big end of the scale) would fly nice, but carried way too much weight. My preference is a plane with a wing area of near 300 sq. in. with a target weight of 21 OZs. The SURGE 400, TIGER 400, & MINI SUPER SPORTSTER are all good flyers, & meet my criteria. I managed to grab 4 Mini Super Sportsters (NIB) after they were closed out, but it's been impossible to find any Tiger 400 ARFs. Too bad, because the 09 just nearly "drops in" that plane. ....................... George K.
Hide Signatures
       Post #: 13
RE: Ace Simple Extra 230 - 11/22/2012 7:11 PM
hllywdb
Score: 118
Status: offline
I once bought one of the early Super Sporter EP ARF's used without the motor, it was the 20 sized one. Anyway I dropped a Norvel 40 in the nose (weighs about the same as a 25FX) It was quite impressive right up until the elevator hinges ripped out
Hide Signatures
(in reply to mtntopgeo)
       Post #: 14
RE: Ace Simple Extra 230 - 11/22/2012 8:30 PM
mtntopgeo
Score: 100
Status: offline
quote:
ORIGINAL: hllywdb
I think that "quite impressive" is probably a bit of an understatement.!!! . ................... George K.
Hide Signatures
       Post #: 15
RE: Ace Simple Extra 230 - 11/22/2012 9:35 PM
hllywdb
Score: 118
Status: offline
I built one of the 20 size Super Sportsters when they first came out and powered it with an FP40. It was nice, but the Norvel one was quite a bit "nicer." After the 1st SS, I built a 29 size Rimfire, fully sheeted the wing and dropped an SF61 with a tuned pipe into it. That one lasted quite a while before it shredded in mid air. At full throttle, by the time you actually hear the flutter, you might as well just start looking for a garbage bag, as there is no time to react. With the light gear and building today along with the nice selection of available performance engines today, you don't have to do that stuff so much anymore.
Hide Signatures
       Post #: 16
RE: Ace Simple Extra 230 - 11/23/2012 6:45 PM
rrragmanliam
Score: 111
Status: offline
Just my opinion the .10 would be total overkill on this plane. I powered mine with a Norvel .061 and it had plenty of power. Keep in mind I fly in the Denver area a 5200-ft elevation so my engines are already a little down on power. If you wanted more engine I think the Norvel .074 would be a better choice. Same power as the OS.10 and A LOT lighter.
It’s a great little ½ A plane, a real nice flyer.
Darren
"Half a bee, philosophically, must ipso facto half not be. But half the bee has got to be, vis-à-vis its entity - d''you se
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
