YAK-23 Flora "Як-23" build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> YAK-23 Flora "Як-23" build
Page: [1] 2   next >   >>
Login
YAK-23 Flora "Як-23" build - 11/21/2012 6:41 PM
czirh
Score: 100
Last Login: 5/11/2013
Status: offline
My new Project: YAK-23 flora Яковлев Як-23
Click to see fullsize image.
Click for fullsize
< Message edited by czirh -- 11/27/2012 9:26 AM >
Hide Signatures
       Post #: 1
RE: YAK-23 Flora "Як-23" build - 11/21/2012 6:46 PM
czirh
Score: 100
Status: offline
Drawings,,
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to czirh)
       Post #: 2
RE: YAK-23 Flora "Як-23" build - 11/21/2012 6:59 PM
ByLoudDesign
Score: 105
Last Login: 5/21/2013
Status: offline
Cool project, what scale. Is it going to br EDF or turbine? I love to see designers doing the not so common models. I shy away from models that have been done before unless I am taking them to a larger scale! Hope to see more as you progress. My projects currently are Bell Boeing V-22 Osprey [1:6 scale] and the F + W C3603 Firefly [1:5 scale]
_____________________________
Kits: F11C-2 1:4, Do-24T 1:8, P-3 1:10, Howard 500 1:5, XFY-1 1:4, SR-9 1:4, V-22 1/6, B-25J 1:4, F+W C3603 1:5
Hide Signatures
(in reply to czirh)
       Post #: 3
dubd
Score: 135
Status: offline
That is one very interesting looking plane. What scale will yours be?
Hide Signatures
(in reply to czirh)
       Post #: 4
RE: YAK-23 Flora "Як-23" build - 11/21/2012 11:26 PM
Nhalyn
Score: 115
Last Login: 5/19/2013
Status: offline
This a great subject and a winner in flight !
Please have a look at this one :
This one was made by a good friend, full scratch build, full molded (fiberglass + herex), Jetcat P140RX inside, and I can't remember the scale but its around 2.20m wingspan.
This is a real winner and a real trainer in flight.
"You''''ve never been lost until you''''ve been lost at mach 3 !" (a test pilot of the SR-71)
Hide Signatures
(in reply to dubd)
       Post #: 5
RE: YAK-23 Flora "Як-23" build - 11/21/2012 11:52 PM
Ram-bro
Score: 156
Status: offline
nice Gen 1 jet and lousy photography....lol. I think I remember a set of plans in MAN at one time
Hide Signatures
(in reply to Nhalyn)
       Post #: 6
RE: YAK-23 Flora "Як-23" build - 11/22/2012 12:14 AM
Nhalyn
Score: 115
Status: offline
Yeah, I know, it's a poor video , but it was the first flight and last of thing we were concentrated on was the video and the new camcorder...
Hide Signatures
(in reply to Ram-bro)
       Post #: 7
RE: YAK-23 Flora "Як-23" build - 11/22/2012 1:04 AM
Knock
Score: 100
Last Login: 5/6/2013
Status: offline
Crack cocaine and video cameras ....never a good mix.
Hide Signatures
       Post #: 8
RE: YAK-23 Flora "Як-23" build - 11/22/2012 2:09 AM
Ram-bro
Score: 156
Status: offline
hey its not a problem with the video, rather have something raher than nothing
Hide Signatures
(in reply to Knock)
       Post #: 9
RE: YAK-23 Flora "Як-23" build - 11/22/2012 3:45 AM
Mark 5
Score: 100
Status: online
Great flying airplane, but it sure is fugly!
Hide Signatures
       Post #: 10
RE: YAK-23 Flora "Як-23" build - 11/22/2012 8:59 PM
czirh
Score: 100
Status: offline
Thank you all comments.. :-)
Engine: P-100
I think ws: 230 - 240cm ?
construction fuselage: balsa, polywood, fiber+epoxy ; wings: foam+balsa+fiber and epoxy
Cem
Hide Signatures
(in reply to Mark 5)
       Post #: 11
RE: YAK-23 Flora "Як-23" build - 11/22/2012 9:01 PM
czirh
Score: 100
Status: offline
quote:
ORIGINAL: Nhalyn
Thank you for the commend and video.. :-)
Have a second video?
Cem
Hide Signatures
       Post #: 12
RE: YAK-23 Flora "Як-23" build - 11/22/2012 11:47 PM
Nhalyn
Score: 115
Status: offline
No sorry, we do not have make an other video, but the plane is still flying faboulousely !
Hide Signatures
(in reply to czirh)
       Post #: 13
RE: YAK-23 Flora "Як-23" build - 11/26/2012 6:50 AM
czirh
Score: 100
Status: offline
quote:
ORIGINAL: Nhalyn
Good morning,
I am also building the same model. İs it possible to contact your friend about some questions :
1. CG?
2. Any additional suggestions/warnings about maiden flight (trim) and building process?
Merci beaucoup
Cem
Hide Signatures
       Post #: 14
RE: YAK-23 Flora "Як-23" build - 11/26/2012 8:52 AM
Nhalyn
Score: 115
Status: offline
Hi Czirh,
I have your informations.
CoG is as usual for this plane : its a no-sweep back wing, with correct sized horizontal stabilizer with correct fuselage length. So no particularity here, there is lots of calculation tables to ensure a correct CoG. You can use the same % values than other "look like" jets.
For tips about this plane I see at least two of them:
- ensure a correct heat protection of the down surface of the fuselage. It's hot here during startup and engine stop procedure.
- be aware of a pitchup effect when applying full power, as the engine is way below the CoG. On this plane we have a mix engine to elevator to control that (10% down elevator by memory) Changing the angle of the engine in the plane should have very low effect to change that, so we kept the engine with 0° angle.
- this plane should not be overpowered for the very same reason of engine effects. It's an old classic jet from the same time of MIG 15, MIG 17, and other that were very low powered. This is not a problem as the plane is very stable and simply to fly, but you have to be aware of that.
Hide Signatures
(in reply to czirh)
       Post #: 15
RE: YAK-23 Flora "Як-23" build - 11/26/2012 11:26 AM
F86_SABRE
Score: 100
Status: offline
Would be interesting to know if the turbine will be angled or not.
Hide Signatures
       Post #: 16
RE: YAK-23 Flora "Як-23" build - 11/27/2012 9:14 AM
czirh
Score: 100
Status: offline
quote:
ORIGINAL: F86_SABRE
I am planning 1,5-2 degrees angled.
My design trainer jet Canary is 2 degrees turbine down angled.
https://www.youtube.com/watch?feature=player_embedded&v=gL3-J23wx_k#!
Click for fullsize
Hide Signatures
(in reply to F86_SABRE)
       Post #: 17
RE: YAK-23 Flora "Як-23" build - 11/27/2012 9:20 AM
czirh
Score: 100
Status: offline
quote:
ORIGINAL: Nhalyn
Hi Czirh,
CoG is as usual for this plane : its a no-sweep back wing, with correct sized horizontal stabilizer with correct fuselage length. So no particularity here, there is lots of calculation tables to ensure a correct CoG. You can use the same % values than other ''look like'' jets.
Thank you very much for your time and hints..
Salut :-)
Cem
Hide Signatures
       Post #: 18
RE: YAK-23 Flora - 11/27/2012 10:16 AM
F86_SABRE
Score: 100
Status: offline
Hi Czirh,
Thanks for the explanation. Do you see any difference in pitch angles when you increase or decrease power?
Reuben
Hide Signatures
(in reply to czirh)
       Post #: 19
RE: YAK-23 Flora - 11/27/2012 10:40 AM
Nhalyn
Score: 115
Status: offline
As the engine axis is far below the vertical position of CoG (around 10cm or 4in) , you can't avoid to be subject to "effect" when you apply or reduce power, whatever is the angle of the engine.
There is the very same problem with gliders, jet powered or electric powered over the wing with retracting pylon : you have always a great pitch down effect when applying power, whatever the angle. You can only reduce the effect, not make it dissapear...
Salut !
Hide Signatures
       Post #: 20
RE: YAK-23 Flora - 11/29/2012 5:18 PM
czirh
Score: 100
Status: offline
My workshop, Pinto and my new runway.. :-)
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 21
RE: YAK-23 Flora - 11/29/2012 5:43 PM
czirh
Score: 100
Status: offline
My turbine p-100..
Click for fullsize
Hide Signatures
(in reply to czirh)
       Post #: 22
RE: YAK-23 Flora - 12/1/2012 3:20 PM
czirh
Score: 100
Status: offline
Fuselage formers..
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to czirh)
       Post #: 23
RE: YAK-23 Flora - 12/5/2012 7:48 PM
czirh
Score: 100
Status: offline
YAK-23 flora, F-9 Panther and Pinto..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to czirh)
       Post #: 24
RE: YAK-23 Flora - 12/6/2012 6:46 PM
czirh
Score: 100
Status: offline
Does this aircaraft have airbreak?
Thank you.
Cem
Hide Signatures
(in reply to czirh)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
