OS10LA rear to front carb    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> OS10LA rear to front carb Page: [1]
Login
OS10LA rear to front carb - 11/22/2012 1:16 AM
AMB
Score: 110
Last Login: 5/25/2013
Status: online
Not being fond of the rear carb setup on the LA 10 an ASP `12 carb was installed just had to take a little off the body so it would slip in drilled and tapped for retaining screw also for a tight in cowl installation the thumb screw was replaced with an allen one so I could insert a allen wrench
the title should read rear to front carb typo) It does now
Click to see fullsize image.
Click for fullsize
< Message edited by Hobbsy -- 11/26/2012 12:50 PM >
Hide Signatures
       Post #: 1
RE: OS10LA rear to front carb - 11/27/2012 12:39 AM
Hobbsy
Score: 650
Status: online
I did same on my LA .10, replaced the thumb screw that is. I like the rear needle though.
Click for fullsize
_____________________________
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to AMB)
       Post #: 2
RE: OS10LA rear to front carb - 11/27/2012 1:16 AM
AMB
Score: 110
Status: online
Hobbsy my rear needle was very tight and hard to adjust, on the glow site there was a post the the rear needle set up was prone to bubbles to the front throttle maybe fiction
I like the fuel direct to the front no second line martin
Hide Signatures
(in reply to Hobbsy)
       Post #: 3
RE: OS10LA rear to front carb - 11/27/2012 1:48 AM
AMB
Score: 110
Status: online
A word on caution on this modification all Davis heads allen or thumb have a fail/safe feature ( length) to prevent lowering the contra too far even when screwed all the waydown
the length on mine was cut with a washer under the allen and spring I made sure this did not exceed the orginal Davis one when all the way in ,I also finished the end of the allen so it was nice and smooth with a nice convex shape martin
Other diesel heads do not have this important feature If you notice mine has a flat on on screw that holds the washer and the spring is under not a regular allen
Hide Signatures
(in reply to AMB)
       Post #: 4
RE: OS10LA rear to front carb - 11/27/2012 2:57 PM
AMB
Score: 110
Status: online
Hobbsy looks like your LA a plain crankcase not blue, is this an early one?? or maybe does not show in the picture martin
Hide Signatures
       Post #: 5
RE: OS10LA rear to front carb - 11/27/2012 4:26 PM
Hobbsy
Score: 650
Status: online
I called my friend at Apex Hobbies and that is what he sent, I didn't care one way or the other. My .65 and both .46s are blue though.
Click for fullsize
Hide Signatures
(in reply to AMB)
       Post #: 6
RE: OS10LA rear to front carb - 11/27/2012 5:34 PM
AMB
Score: 110
Status: online
well LAs are LAs they all run well color not important martin
as we know with the mild porting fair power output on glow, but really come alive as a diesel conversion
Hide Signatures
       Post #: 7
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> OS10LA rear to front carb
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
