CA Glue techniques    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> CA Glue techniques
Page: [1] 2   next >   >>
Login
CA Glue techniques - 11/22/2012 6:28 PM
Fxguy
Score: 100
Last Login: 12/3/2012
Status: offline
I'd like to ask the veterans here for their build advice.
1) Aside from being careful, how do you keep from getting the CA all over your finger tips?
2) What do you do once it gets on your finger tips?
3) How do you deal with a gummed up / melted / clogged tip?
4) From lurking I've seen photos of builders using what appears to be a syringe applicator with a thin tip, any advice on where to get these?
On a side note, any recommendations on a good build text or two?
Thanks!
Tim
Hide Signatures
       Post #: 1
RE: CA Glue techniques - 11/22/2012 6:47 PM
OldScaleGuy
Score: 120
Last Login: 5/25/2013
Status: offline
1) Being careful is the most important, keep the hole in the container as small as you can and still get the ca to flow. Keep your fingers out of the path of the ca as much as possible, that is difficult sometimes just be mindful of it.
2) Either acetone or sandpaper to remove it from your fingers. Sometimes i bite it off but annoys the wife.
3) I keep a small sealed container in the workshop partically filled with acetone and soak the glue tips to remove leftover ca or clogged tips. I have enough tips that i can rotate them, leaving one on the bottle and one in the acetone.
4) You can buy the small applicators or extra tips at most hobby stores.
Side notes:
I try to avoid using ca as much as possible. I prefer Titebond II for most building. CA certainly has its place.
I am sure some of the other guys will chime in with additional information.
_____________________________
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
(in reply to Fxguy)
       Post #: 2
RE: CA Glue techniques - 11/23/2012 12:02 AM
karolh
Score: 310
Last Login: 5/26/2013
Status: offline
Like you I seldom use CA and much prefer using Titebond or an equivalent like Elmer's, but have to be careful about warping if gluing large areas.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 3
RE: CA Glue techniques - 11/23/2012 12:13 AM
eddieC
Score: 249
Last Login: 5/23/2013
Status: online
Gloves, but they just get glued together instead of body partz.
Get 1/2 oz. and 2 oz. or larger bottles of whatever CA you use. The big bottle goes in the fridge. When the small bottle is empty, half-fill it from the big bottle.
Ditto on the fine tips available at the LHS. Some vendors give a few away at shows like Toledo or WRAM, good for extras. I've reopened tips with a small drill.
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to karolh)
       Post #: 4
RE: CA Glue techniques - 11/23/2012 12:26 AM
huck1199
Score: 115
Last Login: 5/24/2013
Status: offline
I have found using the BSI IC-GEL ca from hobbyKing makes things neater and easier to control the over use. The gel is thick and stays where put. I spread a little accelerator one on part (and let dry) with a q-tip and smear a little gel on the other part then put the two together.  I wipe the tip of the tube with a paper towel and re-cap it.   This stuff is great and the tube nozzel  stays free if you sqeuze the tube sides to suck air back into the tube before capping it.  This gel does not work well in places where you want to soak the balsa with ca; but where medium or thick ca is called for it is very good.
Hide Signatures
(in reply to eddieC)
       Post #: 5
RE: CA Glue techniques - 11/23/2012 1:24 AM
EscapeFlyer
Score: 120
Status: offline
Use a lot of paper towel to wipe over the freshly glued joint, and keep your fingers out of the glue.
Good Luck!
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to huck1199)
       Post #: 6
RE: CA Glue techniques - 11/23/2012 2:07 AM
BillinIndiana
Score: 100
Status: offline
I use my daughter's fingernail polish remover to get CA off my fingers. Works well
Hide Signatures
(in reply to EscapeFlyer)
       Post #: 7
RE: CA Glue techniques - 11/23/2012 3:36 AM
sensei
Score: 176
Status: online
I use thin and medium CA exclusively when building airplanes, the more you use it the better you will get handling it. Now for those little mishaps; Home Depot and Lowe's sell acetone by the gallon, just keep a small jar filled with acetone to soak those fingers should you get some CA on them. By the way, a gallon will last for years if used only for this purpose.
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to BillinIndiana)
       Post #: 8
RE: CA Glue techniques - 11/23/2012 5:41 AM
GaryHarris
Score: 168
Last Login: 5/19/2013
Status: offline
I'm the only one that actually enjoys gluing body parts together?
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
(in reply to sensei)
       Post #: 9
RE: CA Glue techniques - 11/23/2012 8:17 AM
CARS II
Score: 110
Status: online
Second, the more you use it the better you become at it.
I'm building a CG Piper Cub fuselage to replace the 17 year old broken one and this time I just used mid-CA to put it thogether, I will use Taidbond to complete the gluing on this one.
< Message edited by CARS II -- 11/23/2012 6:29 PM >
CARS II
Go fly a Jet today.
Hide Signatures
(in reply to GaryHarris)
       Post #: 10
RE: CA Glue techniques - 11/23/2012 1:48 PM
Top_Gunn
Score: 134
Status: offline
When using thin CA on tight-fitting joints, it's useful to sop up any excess with a Q-tip immediately after the application.
Al Gunn
Ultra Sport Brotherhood No. 9
Hide Signatures
(in reply to CARS II)
       Post #: 11
RE: CA Glue techniques - 11/23/2012 2:56 PM
daytonarc
Score: 100
Status: offline
I really did mean to glue the plane to my hand so I wouldn't drop it on the floor.
Hide Signatures
(in reply to Top_Gunn)
       Post #: 12
RE: CA Glue techniques - 11/23/2012 4:31 PM
eddieC
Score: 249
Status: online
There's nothing quite like absentmindedly picking up a tissue or paper towel with a glob of medium or thick CA on it, and having it 'cook off' on your fingers. By the time the heat hits, it's already stuck to you!
Hide Signatures
(in reply to daytonarc)
       Post #: 13
RE: CA Glue techniques - 11/23/2012 4:49 PM
harlanb
Score: 105
Status: offline
With experience, you will get better at not getting ca glue on your fingers.
I would NOT use acetone on your hands. your boddy can soak up acetone and cause health problems later.
It does not take long for CA to wear off body parts. When I epoxy and sometimes when I CA, I use cheap latex gloves.
My LHS sells long tips that fit on to CA bottles for about $0.25. After using the CA I will hold the CA bottle up and sqeeze the bottle a little to clear glue from the tip.
This usually works well. some times the tip gets gummed up any way. I just cut a small part off of the long tip.
Ex-Long CA Ex-Tips (1pc)
Hide Signatures
       Post #: 14
RE: CA Glue techniques - 11/23/2012 5:03 PM
airega1
Score: 108
Last Login: 5/20/2013
Status: offline
If you have a loose fitting joint you can push some baking soda into it and drop thin CA on it, must be thin CA med will not work!" watch out for the fumes
Man! that thing does not like Dwayne!
Hide Signatures
(in reply to harlanb)
       Post #: 15
RE: CA Glue techniques - 11/23/2012 5:11 PM
sensei
Score: 176
Status: online
quote:
ORIGINAL: eddieC
Yah, that is sure an intense 2 seconds isn't it!!! LOL
Bob
Hide Signatures
       Post #: 16
RE: CA Glue techniques - 11/23/2012 5:52 PM
eddieC
Score: 249
Status: online
About as much fun as dropping an X-Acto on your leg or foot! Yeow!
Hide Signatures
       Post #: 17
RE: CA Glue techniques - 11/23/2012 6:34 PM
CARS II
Score: 110
Status: online
X-acto knife?? done that been there, ouch!! I got me a nice clean cut on my leg the other day Now days if the knife it coming down the first thing to runaway are my legs, oh yeah I close my eyes too
CARS II
Go fly a Jet today.
Hide Signatures
       Post #: 18
RE: CA Glue techniques - 11/23/2012 7:13 PM
Fxguy
Score: 100
Status: offline
Love the responses! Especially as I am typing with the band-aided index finger that got caught in the X-acto crossfire last night! I think my CA bottle is just to the point where I'd be better to start fresh with a new bottle because the tip is so crudded up its almost impossible to get any control of the glue comming out of the tip.
What is the difference between CA, Epoxy, and Tightbond? I like the CA because I am impatient and like being able to move on to the next step of a project without having to wait 2-24 hours for the glue to dry before moving on. Does Epoxy or Tightbond have a similar cure time?
Hide Signatures
       Post #: 19
RE: CA Glue techniques - 11/23/2012 7:47 PM
PLANE JIM
Score: 171
Status: offline
CA gets really hot especially with a little kicker on your finger-and ditto to the exacto knife-why do they keep making the handle round? I like playing hop scotch in front of my building board at midnite when trying to avoid the 3 foot knife drop.
"IF YOU HAVE TOO MANY AIRPLANES -FLY BOLDLY AND REDUCE YOUR NUMBER"
Hide Signatures
(in reply to Fxguy)
       Post #: 20
RE: CA Glue techniques - 11/23/2012 7:50 PM
karolh
Score: 310
Status: offline
Sometimes I use a combination of CA and carpenters's glue such as Titebond or Elmers, where the CA sets up quickly and provides the clamping force to hold the pieces being joined together while the glue dries.
Karol
Hide Signatures
(in reply to Fxguy)
       Post #: 21
RE: CA Glue techniques - 11/23/2012 9:21 PM
daisy shoot
Score: 105
Last Login: 5/13/2013
Status: offline
Guys,
For the love of god, put one of those black paper clip thingies on the end of your exacto. No more rolling around or cuts!
Hide Signatures
       Post #: 22
RE: CA Glue techniques - 11/24/2012 12:09 AM
sensei
Score: 176
Status: online
quote:
ORIGINAL: Fxguy
CA is the very fastest adhesive to build with, hands down. There are going to be those that tell you it's fast to build with but epoxy, or Tightbond are much stronger, better, Bla, Bla, Bla, to build your airframes with. So when you hear that line; just know that it is so not true and you can bet they are in most cases repeating only what they have heard or read from someone else and are not really qualified to be making any statement on the subject at all.
Bob
Hide Signatures
(in reply to Fxguy)
       Post #: 23
RE: CA Glue techniques - 11/24/2012 12:17 AM
N1EDM
Score: 125
Status: offline
Just a quick comment about soaking the CA tips in Acetone. I do that too, but when you take them out, make sure that you get ALL the Acetone out of the inside before you put it on the bottle. If there are traces of acetone in that tip and it gets into the glue, you can spoil the CA.
I also squeeze out a little air from the container first so that, once I put down the glue, I can suck what's left in the tip back into the bottle. Sometimes I will 'burp' the glue container (be careful where you point it) to get rid of that little droplet that seems to always clog the tip.
Just my $.02
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
       Post #: 24
RE: CA Glue techniques - 11/24/2012 12:55 AM
mike31
Score: 114
Last Login: 5/22/2013
Status: offline
There are little triangle widgets that are made for pens and pencils that keep them from rolling off the desk. Will work for exacto knives as well. Staples, KMart or wherever office supplies are sold.
Hide Signatures
(in reply to PLANE JIM)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
