.40 GP Piper J3 Model Kit    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> .40 GP Piper J3 Model Kit
Page: [1]
Login
.40 GP Piper J3 Model Kit - 11/22/2012 10:57 PM
Wilmer787
Score: 100
Last Login: 11/26/2012
Status: offline
 Hi there Guys Im new on this page and I want to show you my first model kit builded by me,, its a Great Planes .40 Piper Cub J3,  Im using a .65 golden night saito engine on it, never tried a 4stroke before and Im not sure which prop size to use yet, some people told me that I dont need much on this plane because it floats on the air, what do you guys think? Thanks for looking.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: .40 GP Piper J3 Model Kit - 11/23/2012 12:46 AM
biam
Score: 110
Last Login: 5/25/2013
Status: offline
Looking good! Plenty 0f engine for this plane, I'm thinking a 12x6 for the prop, flying it around at half throttleor lower for scale flight. I have one of these with a .52 in it and plenty of power. It goes to the field anytime I go, one of my favorite planes, hope you enjoy yours as muuch as I do mine.
_____________________________
Bill.
It is always better to be under the gun, than in front of it!
Hide Signatures
(in reply to Wilmer787)
       Post #: 2
RE: .40 GP Piper J3 Model Kit - 11/23/2012 2:44 AM
Wilmer787
Score: 100
Status: offline
Niice', I was looking for a .52 engine but  found the .65 for the same price, I will try 12x6 prop and see how it goes now im waiting for a few part to get the plane done and visit the field', Thanks for the reply
Hide Signatures
(in reply to biam)
       Post #: 3
RE: .40 GP Piper J3 Model Kit - 11/23/2012 6:32 AM  1 votes
mike109
Score: 148
Status: offline
G'day
I have had a few Saito 65s and I still have some Saito 62s in my collection of 14 or so Saitos. I would put a 13 x 6 on the 65 as a starting point or better a 13 x 5 if you can find one. The 5 pitch prop will give you plenty of pull while allowing the Cub to slow down for landing.
One of the down sides of having a slightly large engine is that you need a slightly large prop and it will still be producing quite a deal of thrust even with the engine near idle. This can cause floaty planes like the Cub to not want to land. A lower pitch prop gets round this problem.
The other "interesting" thing about Cubs is their tendency to suffer from "adverse yaw". You try to turn the plane to the right with the ailerons and it either goes straight on or it turns wide with its tail hanging down. The cure is to use rudder as well in the turn. If you have a computer radio, you can use a mix to add some aileron to rudder mixing which will help with this. It is best to make it switchable so you can turn it off. Otherwise, if you try to roll the plane, you will get a very nasty and untidy roll at best.
Have fun with your Cub and the Saito.
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
       Post #: 4
RE: .40 GP Piper J3 Model Kit - 11/23/2012 7:40 AM  1 votes
combatpigg
Score: 376
Status: offline
WOW..!!
Gorgeous job..! I'm jealous of both your plane and your engine... !
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
(in reply to mike109)
       Post #: 5
RE: .40 GP Piper J3 Model Kit - 11/24/2012 1:39 AM
Wilmer787
Score: 100
Status: offline
Great info'   it makes sense and  appreciate your help guys, I saw the 13x5 prop on web and thinking of buying one and try all the sizes that you gave me guys and see what happend' also im using a fasst transmitter so I can try the mixing setting with the aileron with the rudder, Dont be jealous my friend haha ha just gota little luck when I was looking for a new plane and engine but I think this is the first and the last kit i gonna build, the next one will prefer an ARF kit cuz the regular kit takes too much time''''  Thanks Again Guys!!!!
Hide Signatures
(in reply to combatpigg)
       Post #: 6
RE: .40 GP Piper J3 Model Kit - 11/24/2012 1:44 AM
Wilmer787
Score: 100
Status: offline
Another thing excuse my english im not good with it yet'
Hide Signatures
       Post #: 7
RE: .40 GP Piper J3 Model Kit - 11/24/2012 2:25 AM
KitBuilder
Score: 131
Last Login: 5/22/2013
Status: offline
I built the clipped version with a magnum 70 4 stroke.. a 14x6 is what I used and it worked great but the 70 is a bit bigger but not much.
I would not mix the aileron and rudder... you will need control of the rudder by itself on takeoff.. as the cub is very squriely. As far as flying.. learn to use the rudder independently...your pilot skills will be much better for it. For example cross wind landings, etc. This cub will groove better with a bit of rudder during a turn.
I routed my exhaust out the bottom with a diverter as well.. left virtually a clean plane end of day.
Click for fullsize
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 8
RE: .40 GP Piper J3 Model Kit - 11/24/2012 3:16 AM
Wilmer787
Score: 100
Status: offline
Cool Thanks'
Hide Signatures
(in reply to KitBuilder)
       Post #: 9
RE: .40 GP Piper J3 Model Kit - 11/24/2012 4:06 PM
jaka
Score: 158
Last Login: 5/24/2013
Status: offline
Hi!
A 13x6 (APC, RAM or Graupner Sonic) is what you should use if you fly at sea level!
12x6 is to small for that engine!
But I hope that isn't the plane you are gooing to learn on?! Get a high winged trainer first!!!!
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 10
RE: .40 GP Piper J3 Model Kit - 11/24/2012 10:50 PM
Wilmer787
Score: 100
Status: offline
No is not my first plane, this is my first model kit builded I have been flying around 8 years but once or twice a month
Hide Signatures
(in reply to jaka)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.766RCU1
