Hyper 7 differentials, questions in need of answers!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> Hyper 7 differentials, questions in need of answers! Page: [1] 2   next >   >>
Login
Hyper 7 differentials, questions in need of answers! - 11/22/2012 11:04 PM
mattster1971
Score: 129
Last Login: 5/18/2013
Status: offline
I have a hyper 7 I acquired used from craigs. While it was a pig as far as being dirty, once I broke it down and cleaned it I only had to replace two suspension pins, a bent front shock tower and a shock bladder. I had it running today a. nd it is amazingly quick and responsive with the. 28 hyper and the larger 17tooth axial clutchbell.
I was wondering when or at what interval should the front/rear and center differentials be broken down, cleaned and repacked with grease? Are you supposed to grease the dogbones? My thought was no because that would trap the dirt in the drive cups, but still wondered. I am not use to a 4 wheel drive setup and so I haven't had to deal with all the differentials and dogbones before. How do you know when this type of maintenance is needed? Thanks
_____________________________
Traxxas Jato 3.3 Custom(2), HoBao Hyper 7(2), Associated MGT 4.6, Kyosho Javelin. Its better to be feared than loved.
Hide Signatures
       Post #: 1
RE: Hyper 7 differentials, questions in need of answers! - 11/23/2012 4:06 PM
Anthoop
Score: 121
Last Login: 5/17/2013
Status: offline
How often you have to service the diffs will depend on how you use the car and the conditions you run in. Servicing too often is obviously more preferable than not often enough but bear in mind that you will be able to feel if they are getting graunchy/loose/etc.
There is no problem at all with using grease for the diffs but you will find that using oil will provide more tuneability.
I would not use any lubricant on the driveshafts, as you thought- dirt will stick and cause wear. Having said that there are dry lubricants that would be appropriate but in my opinion you do not need to worry about lubing these parts, just ensure they are clean/dry.
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
(in reply to mattster1971)
       Post #: 2
RE: Hyper 7 differentials, questions in need of answers! - 11/23/2012 4:14 PM
mattster1971
Score: 129
Status: offline
We are casual runners. Weekends when weather is nice, maybe 3 or 4 tanks. Nothing major. I think the guy I got this from was rough on his stuff. I wish I had taken a before pic so you could see how ridiculous the previous owner left this thing, dirty filthy. If I hadn't driven an hour to buy I may have just said forget it
Hide Signatures
(in reply to Anthoop)
       Post #: 3
RE: Hyper 7 differentials, questions in need of answers! - 11/23/2012 4:31 PM
Anthoop
Score: 121
Status: offline
Yes buying used stuff can be a lottery...hopefully you can forget it now it is fixed up.
With your useage you can probably "forget" about having to service the diffs and as I said you will be able to feel for problems, simple regular checks will give you a feel for good/mmm/bad.
Hide Signatures
       Post #: 4
RE: Hyper 7 differentials, questions in need of answers! - 11/24/2012 1:10 AM
JohnP2
Score: 268
Status: offline
Anthoop made some great points. One thing to think about, of course, if the previous owner sold it in a "pig-like" state, then he or she probably did not take good care of the car. Especially if the owner did not even bother to clean it prior to selling it.
Consquently, I'd recommend to go ahead and check them out (as they might not have ever been touched).
Most folks (including myself) use the following:
5k - front
7k center
3k - rear
Please post pics and/or videos of it (now that it is cleaned up). Would love to see it.
Mugen MBX6R, HB D8T, Losi 8 2.0, Savage X 4.6, Losi 810, Hyper 7, Exceed Forza
http://www.youtube.com/user/NitroRCNerds
Hide Signatures
       Post #: 5
RE: Hyper 7 differentials, questions in need of answers! - 11/24/2012 12:48 PM
mattster1971
Score: 129
Status: offline
I thank you all for your suggestions. I took it apart because grease was splattering on the inside of the plastic body shell in a pattern indicating the center diff was leaking. When I opened it the interior was just coated with a thick black grease, no oil. Is that how this comes from the factory, with. Just grease inside the diffs? What indicates the diff is getting "loose" or in need of change? This leak was my indicator that something, thinking the o ring on the gear side, wasnt fitting tight anymore.
Hide Signatures
(in reply to JohnP2)
       Post #: 6
RE: Hyper 7 differentials, questions in need of answers! - 11/24/2012 7:47 PM
Anthoop
Score: 121
Status: offline
From the factory they are packed with grease. Could well be that the O ring needs replacing...I use a little RTV on the O ring for peace of mind.
Hide Signatures
       Post #: 7
RE: Hyper 7 differentials, questions in need of answers! - 11/25/2012 2:02 AM
mattster1971
Score: 129
Status: offline
How do you use rtv on the o ring? Wouldn't that bind it up? I got all the different weights of oil today, the lady at the hobby store is nice.
Hide Signatures
       Post #: 8
RE: Hyper 7 differentials, questions in need of answers! - 11/25/2012 6:58 PM
Anthoop
Score: 121
Status: offline
Nevermind the lady in the store.
I am talking about the large O ring on the casing (where it meets the spur/crown gear), not the smaller O rings on the outputs.
Hide Signatures
       Post #: 9
RE: Hyper 7 differentials, questions in need of answers! - 11/25/2012 9:48 PM
mattster1971
Score: 129
Status: offline
Well I changed it and put it all back together today. That 7k is like the thickness of honey, so thick. Put it back together and it is super stiff, guess that's what was intended. I may tackle the front and rear soon too, but want to run this a little to see what I think. Too cold today and I want to put up a pic but I am usually posting from my phone. I didn't zip tie the pipe manifold tight enough and got some blow back on the pipe so while I had all those parts off I used some alloy polish and shined that baby up like new. I don't like how the body hits the pipe in the front so I trimmed up the body a little more in that area since it melted to the pipe on the front recently.
Hide Signatures
       Post #: 10
RE: Hyper 7 differentials, questions in need of answers! - 12/5/2012 3:56 PM
mattster1971
Score: 129
Status: offline
How do you think the hyper 7 stacks up against other 1/8 scale buggies in its class? I know its on the lower cost side but from my limited experience it seems quite rigid and well handling. Is there an official hyper 7 Thread on here?
Hide Signatures
       Post #: 11
RE: Hyper 7 differentials, questions in need of answers! - 12/5/2012 6:19 PM
Anthoop
Score: 121
Status: offline
It depends what class you put it in I guess......but yes it is a great buggy. I will always recommend it to anyone asking (whether they are new to the hobby or not), it has been around for more than a few years in many different forms, it is well proven/known.
Of course if you are going racing then in the end the Hyper7 is not going to be the best choice.
There maybe an Official Hyper7" thread somewhere (?) , I do not know.....but you can be sure there are plenty of Hyper threads found by searching....
Hide Signatures
       Post #: 12
RE: Hyper 7 differentials, questions in need of answers! - 12/9/2012 3:53 AM
JohnP2
Score: 268
Status: offline
quote:
ORIGINAL: Anthoop
Agreed. The Hyper 7 is a mid-market RTR buggy for those wanting a hobby-grade buggy that does a little bit of everything. It's known more for its durability than its racing prowess (i.e. it's built to be a basher). Definitely one of the most popular nitro vehicles on the market today, so you'll have no problems finding information on it. Note there are different "flavors" of it ranging from a .21 engine to a .28 engine. I don't believe there is an "official Hyper 7" thread on this forum, but imagine there would be solid activity if one were started (hint-hint). ;-)
Hide Signatures
       Post #: 13
RE: Hyper 7 differentials, questions in need of answers! - 12/9/2012 8:03 AM
Anthoop
Score: 121
Status: offline
quote:
ORIGINAL: JohnP2
I don't believe there is an ''official Hyper 7'' thread on this forum, but imagine there would be solid activity if one were started (hint-hint). ;-)
Personally I do not like those "Official" type threads. If it is a popular item then the thread can go on for many pages meaning that a lot of the information will be forgotten/never read and also questions can easily go un-answered. Many times in the past I have researched some item in threads that are over 50 pages long and after reading the whole thread I find that the useful information I have gained would condense down to less than a page.
Besides that, I think that the guys who knew all about the H7 no longer frequent the forum, however their thoughts are recorded here and can be found by searching. Once you have searched a few old threads you become familiar with the usernames that are dealing out the gold, then you can search their post history.
Just my little rant (8am here and I am grumpy in the mornings). I am sure if someone started a thread now I would participate...along with you John...and...mmmm.
Hide Signatures
       Post #: 14
RE: Hyper 7 differentials, questions in need of answers! - 12/15/2012 10:44 PM
mattster1971
Score: 129
Status: offline
Ok, I had it all rebuilt just as it should be with new seals and ran one tank today and there was a fluid all over the diff and housing.. what gives???
Hide Signatures
       Post #: 15
RE: Hyper 7 differentials, questions in need of answers! - 12/16/2012 12:34 AM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
First thing that comes to mind is...it might have been over filled...sometimes when over filled, the excess will find it's way out when things warm up and expand.
OR
You HAD it rebuilt, or did you rebuild it yourself?
Just askin', because if you did it yourself, then you'll be more familiar w/ what I'm gonna say...
There are typically 4 places where it will leak...(unless there is a crack somewhere )
2 red O rings, where the output cap joints come out...(to the drive shafts )
The gasket between gear and plastic case...
The small access hole plug, screw (grub screw ) that plugs the cap joint drive pin access hole on the plastic case.
Sounds like something is either missing or not installed properly?
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
       Post #: 16
RE: Hyper 7 differentials, questions in need of answers! - 12/16/2012 1:16 AM
mattster1971
Score: 129
Status: offline
I rebuilt it myself. I definitely put it back together exactly as it was dismantled. Shims and all, maybe I did put a little too much in but it wasn't running over when I screwed the spur on, nothing oozed out. Its just all over the darn thing and the grub is in fine I guess. Doesn't it just screw in? You don't want to put the grub in too far it will hit the gears wont it? I think its coming from the end opposite the spur.. very frustrated.
Hide Signatures
(in reply to proptop)
       Post #: 17
RE: Hyper 7 differentials, questions in need of answers! - 12/16/2012 4:28 AM
nitroexpress
Score: 150
Status: offline
quote:
ORIGINAL: mattster1971
Since you bought it used, the diff cups and/or the outdrives could be original or just plain worn out.  If the outdrives have too much wobble, nothing will seal them.  Buy a diff cup and some outdrives and compare with what you have.
Hide Signatures
       Post #: 18
RE: Hyper 7 differentials, questions in need of answers! - 12/16/2012 2:24 PM
mattster1971
Score: 129
Status: offline
quote:
ORIGINAL: nitroexpress
I thank you all for your suggestions. I took it apart because grease was splattering on the inside of the plastic body shell in a pattern indicating the center diff was leaking. When I opened it the interior was just coated with a thick black grease, no oil. Is that how this comes from the factory, with. Just grease inside the diffs? What indicates the diff is getting ''loose'' or in need of change? This leak was my indicator that something, thinking the o ring on the gear side, wasnt fitting tight anymore.
That was my thought, the out drives. The diff cup is new also, I got it with the seals in one package.
Hide Signatures
(in reply to nitroexpress)
       Post #: 19
RE: Hyper 7 differentials, questions in need of answers! - 12/16/2012 4:05 PM
proptop
Score: 130
Status: offline
I changed the fluid in the center diff in one of my X1-CR's and re-used the brake cap joints (just changed the O-rings )...the shafts are a bit worn, but not excessively. It seeped a bit for a little while, because I think I over filled it a little bit, but it stopped after a few tanks. (I'm using 7K in it )
The new O rings will help a lot...IMO I would just wipe it off good, and watch it for a few more tanks to see if it continues...
Hide Signatures
       Post #: 20
RE: Hyper 7 differentials, questions in need of answers! - 12/19/2012 6:13 PM
mattster1971
Score: 129
Status: offline
How full should you fill the diff when you are changing it?
Hide Signatures
       Post #: 21
RE: Hyper 7 differentials, questions in need of answers! - 12/19/2012 6:29 PM
Anthoop
Score: 121
Status: offline
Over half is plenty.
Hide Signatures
       Post #: 22
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 1:27 AM
mattster1971
Score: 129
Status: offline
Okay so after several more tanks it continues to leak, it does appear to be around the grub screw. I wondering just how much has come out at this point and if I should tear down and do over. I am considering using a small piece of plumbers tape on the grub screw or some loctite on it to try and seal it off. Odd to me because this was a new cup and I believe the grub screw was new too with the set. What do you all think? Should I rebuild it and worry about lost oil or just do something to seal the grub? If seal would my suggestions be adequate? Thanks
Hide Signatures
       Post #: 23
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 7:18 AM
proptop
Score: 130
Status: offline
I wonder if maybe there is a manuf. flaw in the plastic cup, or maybe a hairline crack somewhere around the threaded hole?
Silicone RTV sealer would probably work O.K.? I don't think the silicone diff oil would disolve it, once it's had a chance to cure throughly? Let the sealer cure over-night before introducing the diff oil perhaps? (you probably already know that you don't want to use loctite on plastic parts like that? )
Hide Signatures
       Post #: 24
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 9:13 AM
Anthoop
Score: 121
Status: offline
Yes, RTV.
Remove the screw and degrease it and use a cotton bud to degrease the thread in the housing, apply little RTV to screw then wind it in until level with the housing.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
