RE: Hyper 7 differentials, questions in need of answers!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: Hyper 7 differentials, questions in need of answers! Page: <<   < prev  1 [2]
Login
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 3:06 PM
mattster1971
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: proptop
I wonder if maybe there is a manuf. flaw in the plastic cup, or maybe a hairline crack somewhere around the threaded hole?
Silicone RTV sealer would probably work O.K.? I don't think the silicone diff oil would disolve it, once it's had a chance to cure throughly? Let the sealer cure over-night before introducing the diff oil perhaps? (you probably already know that you don't want to use loctite on plastic parts like that? )
Why don't you want to use loctite on plastic. I didn't know that. Sorry I don't know a bunch. I will rebuild with rtv
_____________________________
Traxxas Jato 3.3 Custom(2), HoBao Hyper 7(2), Associated MGT 4.6, Kyosho Javelin. Its better to be feared than loved.
Hide Signatures
(in reply to proptop)
       Post #: 26
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 6:27 PM
proptop
Last Login: 5/9/2013
Status: offline
Yeah, there is a lot to learn...a continuing process...believe it or not, even some of us "older farts" don't know everything...! (major sarcasm here )
The solvents (or also known as the liquid "vehicle" or "carrier" of the solids component ) can eat into a lot of different plastics.
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
(in reply to mattster1971)
       Post #: 27
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 7:26 PM
john josey
Status: offline
Tamiya threadlock is fine with most plastics.
I bought the kit version in 2004 and it's still going strong, even the original Hyper 21 engine. I should really strip it down and check everything is ok.
Is there anything in the build manual that i can post a picture of that may help you ?
Hide Signatures
       Post #: 28
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 10:24 PM
mattster1971
Status: offline
Well before I read the post of not using thread lock I put blue thread lock on it and screwed it back in. That was last night, ran it today and no leaks. I guess we will see if the threadlock holds. It seemed to do the trick today.
Hide Signatures
(in reply to john josey)
       Post #: 29
RE: Hyper 7 differentials, questions in need of answers! - 12/24/2012 11:35 PM
Anthoop
Last Login: 5/17/2013
Status: offline
Anything gummy will block it....but RTV would be more usual.
When I die, I want to go in my sleep like my grandfather,not screaming
like the passengers in his car at the time.
Hide Signatures
       Post #: 30
RE: Hyper 7 differentials, questions in need of answers! - 12/25/2012 12:58 PM
proptop
Status: offline
The whole Loctite thing started years ago... some of us out at the flying field were talking of the (then new ) Hitec servos with Karbonite gears.
Hitec said Do Not use any loctite on the servo arm retaining screw(s ) or failure of the output shaft could result. I don't know why anyone would feel the need to use it with that sort of set-up... that kind of screw threaded into plastic doesn't typically back out easily? But anyway....from then on.........
It's common practice to use it on the output arm screws in metal geared servos though, so the output arm doesn't fall off while you're driving / flying...
The plastic that hitec calls Karbonite is similar to the plastics used in a lot of r/c car chassis, suspension and drive line parts...
Your grub screw should be fine...there's no real stress on it...It's probably partially bonded w/ the diff cup...your leak should be stopped up now! If it ain't...then...hmmmmm....
< Message edited by proptop -- 12/25/2012 1:28 PM >
Hide Signatures
(in reply to Anthoop)
       Post #: 31
RE: Hyper 7 differentials, questions in need of answers! - 12/25/2012 3:33 PM
Anthoop
Status: offline
quote:
ORIGINAL: proptop
Fingers crossed.
Hide Signatures
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
