RE: Waltersons 105mm Sherman    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: Waltersons 105mm Sherman
Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Login
RE: Waltersons 105mm Sherman - 11/26/2012 11:22 PM
sassgrunt
Score: 100
Last Login: 6/18/2013
Status: offline
I love the way this suspension looks. I noticed a couple of things when looking at the closeup pictures of the bogie units. First, there is an odd-looking piece in the middle of the housing. I'm guessing it's some kind of plug to cover a screw - either one that holds the bogie together, or maybe that holds it to the hull. Second, the roadwheels don't have that "crowded" look like the Mato ones do - it looks like they reduced the diameter of them somewhat, and they can travel without hitting each other. Last, the idler wheel appears to have a rubber tire on it. I am hoping that this is just painted and can be cleaned off, because the idler wheel has a solid steel rim. All in all, a GREAT looking basis for some new Shermans!!
Hide Signatures
(in reply to no12skyline)
       Post #: 76
RE: Waltersons 105mm Sherman - 11/26/2012 11:24 PM
jeanluc07
Score: 100
Last Login: 2/5/2013
Status: offline
Wow, since I am new and have zero tanks and this fit the bill, I DEFINITELY want one - metal and IR version.
When and how to order?
Hide Signatures
       Post #: 77
RE: Waltersons 105mm Sherman - 11/27/2012 12:06 AM
yellowshaker
Score: 188
Status: offline
rd, look at the interior pics. The mato suspension mounts different than this HL tank. I do not believe they are interchangeable...
_____________________________
Armorcreations.weebly.com
Hide Signatures
       Post #: 78
RE: Waltersons 105mm Sherman - 11/27/2012 12:29 AM
YHR
Score: 209
Status: online
Yes I agree, This tank has a cover piece over the suspension. Not ideal.
Dan
Battle Armor R C
Hide Signatures
(in reply to yellowshaker)
       Post #: 79
RE: Waltersons 105mm Sherman - 11/27/2012 12:58 AM
no12skyline
Score: 100
Last Login: 6/14/2013
Status: offline
quote:
ORIGINAL: YHR
...... and the diameter for the headlight guards are too thick......
but then again, nothing a bit of filler, a hammer, or a cutter wouldn't fix! At about half the price of a Tamiya, I don't mind putting some work into it.
Hide Signatures
(in reply to YHR)
       Post #: 80
RE: Waltersons 105mm Sherman - 11/27/2012 1:11 AM
Panther F
Score: 135
Status: offline
It's a hell of a lot better looking than the MATO A1.
~ Jeff
Hide Signatures
       Post #: 81
RE: Waltersons 105mm Sherman - 11/27/2012 1:14 AM
FreakyDude
Score: 107
Status: offline
I am sorry I do not have a delivery date yet but trust me I want one as much as everybody else. It should get wrinkled out shortly.
Tks Curtis
quote:
ORIGINAL: jeanluc07
www.immortalhobbies.com
Hide Signatures
(in reply to jeanluc07)
       Post #: 82
RE: Waltersons 105mm Sherman - 11/27/2012 2:01 AM
Airbrushler
Score: 112
Status: online
they look like they need lots of paint and weathering i want one to i think just basic don't care about metal anything just want one...lol
http://s1009.photobucket.com/user/airbrushler/media/Soviet_Tank_Battle_zps9b2ee783.gif.html
Hide Signatures
(in reply to FreakyDude)
       Post #: 83
RE: Waltersons 105mm Sherman - 11/27/2012 3:21 AM
YHR
Score: 209
Status: online
quote:
ORIGINAL: Panther F
~ Jeff
Agreed, The transmission is way better. It looks like a really good tank, but they should have copied Mato's method of installing the bogies. That insert on the bogies is going to be an eyesore, unless it is filled and sanded, which then creates a major problem if you have to service the suspension. Doesn't mean I don't think this is a good tank, I am just saying.
< Message edited by YHR -- 11/27/2012 4:28 PM >
Dan
Battle Armor R C
Hide Signatures
(in reply to Panther F)
       Post #: 84
RE: Waltersons 105mm Sherman - 11/27/2012 1:28 PM
Panther F
Score: 135
Status: offline
quote:
ORIGINAL: YHR
quote:
ORIGINAL: Panther F
~ Jeff
Agreed, The transmission is way better. It looks like a really good tank, but the they should have copied Mato's method of installing the bogies. That insert on the bogies is going to be an eyesore, unless it is filled and sanded, which then creates a major problem if you have to service the suspension. Doesn't mean I don't think this is a good tank, I am just saying.
Well, it's better than having a Philips head screw sticking out, huh.
I'm thinking they will not need servicing once you paint it up so a little filling in with putty and sanding won't trip me up. I've been dying for a REAL Sherman to make all my variants I have lined up.
PLUS the JS2... I think we all went through a little "phoney war" here for a while with not much to get excited about and now the time has come.
~ Jeff
Hide Signatures
(in reply to YHR)
       Post #: 85
RE: Waltersons 105mm Sherman - 11/27/2012 2:03 PM
YHR
Score: 209
Status: online
Yes, we seem to be in an up phase. All good.
Dan
Battle Armor R C
Hide Signatures
       Post #: 86
RE: Waltersons 105mm Sherman - 11/27/2012 3:26 PM
karel47
Score: 149
Last Login: 6/17/2013
Status: offline
am eager to one in real life could be the beginning of endless modifications onto the sherman range, who knows over a year there are more sherman onto the battlefield just as in WOII Battles in real
PanzVI-J,ShermanM4A4,PershingM26,KTPorsche2x,KTHenshel Late3x-Early1x,TigerI 3x,JP,Panther,Jagdtiger;PantherIIta;PanthHL;Stu
Hide Signatures
(in reply to YHR)
       Post #: 87
RE: Waltersons 105mm Sherman - 11/27/2012 4:26 PM
Panther F
Score: 135
Status: offline
Yep, I have the immediate need for 2 RTR's right now.
A Maxx Traxx M36 turret to make a M36B1 and an Early M4A3. I also want to build a wader Sherman too and the M36 Jackson also.
I need to find a way to duplicate myself with all these Shermans to build.
~ Jeff
Hide Signatures
(in reply to karel47)
       Post #: 88
RE: Waltersons 105mm Sherman - 11/27/2012 4:29 PM
tisaksen
Score: 100
Last Login: 6/15/2013
Status: offline
quote:
ORIGINAL: Panther F
Lets try a 3D printer to duplicate you :-)
Hide Signatures
       Post #: 89
RE: Waltersons 105mm Sherman - 11/27/2012 4:35 PM
YHR
Score: 209
Status: online
quote:
ORIGINAL: Panther F
quote:
ORIGINAL: YHR
quote:
ORIGINAL: Panther F
~ Jeff
PLUS the JS2... I think we all went through a little ''phoney war'' here for a while with not much to get excited about and now the time has come.
~ Jeff
When I modded the metal FOV Sherman, this is how I mounted the front bogies on it. I had to fill and sand the holes, and then make a mental note that if I wanted to remove them I would have to drill out the fill to get to the screws. So I agree, it can be done, and shouldn't present a huge problem. However Mato has presented a design that is easy and functional. They have no problems copying everything else, so I am a loss to explain why they didn't copy this good idea.
Oh well, it the prices the Freaky quoted are right, this won't prevent me from buying a couple.
There still is the All Mato M4A3 coming as well, not to mention the metal stug or the metal PZIII that was just released. No one but modern tankers should be complaining about the 1/16 tank releases now.
Dan
Battle Armor R C
Hide Signatures
       Post #: 90
RE: Waltersons 105mm Sherman - 11/27/2012 4:42 PM
Panther G
Score: 116
Status: offline
What  would be a real nice choice of upgrades would be the different turrets and guns/ mantlets that where used on the different variants of these tanks.
 I'm a little puzzled as to why the howitzer version. Seems even the 75 would have been more practical.
 I'm a 76 version guy myself.
Tamiya Panther G, HL/Tamiya TigerI, WSN/HL T-34/85, WSN/Tamiya T-34/85, WSN/HL DBCRC2 T-34/85, HL/Tamiya Pershing, Mato/Tamiya Sherman,HL KV-1, HL Pz III, HL/Custom scratch JP, HE/Tamiya Abrams, HE/Tamiya LEO 2A5, Vs Abrams M1A1, Vs T-72, HL Bergepanthe
Hide Signatures
       Post #: 91
RE: Waltersons 105mm Sherman - 11/27/2012 5:13 PM
Panther F
Score: 135
Status: offline
quote:
ORIGINAL: Panther G
Because it's easier to copy something that's already out there.
Plus, only Nick makes a correct M34, M34A1 and the gun shield for the T23.
~ Jeff
Hide Signatures
(in reply to Panther G)
       Post #: 92
RE: Waltersons 105mm Sherman - 11/27/2012 6:33 PM
yellowshaker
Score: 188
Status: offline
Sorry, did I miss the pricing on these Shermans?
Hide Signatures
       Post #: 93
RE: Waltersons 105mm Sherman - 11/27/2012 7:01 PM
MAUS45
Score: 100
Status: offline
Yes, on page 2 of this thread Freakdude gave us the pricing.
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
       Post #: 94
RE: Waltersons 105mm Sherman - 11/27/2012 7:05 PM
Panther F
Score: 135
Status: offline
Plus, basic pricing is on the website too.
I'm doing some searches on the M4A3 with the 105 and am coming up with them as waders too. Looks like an easy conversion right out of the box.
Looks like I'll need 3 of them.
~ Jeff
Hide Signatures
(in reply to MAUS45)
       Post #: 95
RE: Waltersons 105mm Sherman - 11/30/2012 10:44 PM
FreakyDude
Score: 107
Status: offline
Great news guys, I'll have tanks on the water very very shortly. Supposed to be loaded this week. A limited air shipment is coming as well but i put my money into the tanks and not into shipping.
Hide Signatures
       Post #: 96
RE: Waltersons 105mm Sherman - 11/30/2012 11:46 PM
jeanluc07
Score: 100
Status: offline
Mr Freakydude (santa)
I love to have an ir metal version . Will it get here for Xmas?
Hide Signatures
       Post #: 97
RE: Waltersons 105mm Sherman - 12/1/2012 1:38 AM
Jumbo123
Score: 100
Last Login: 1/16/2013
Status: offline
Hello
I here Mato will have a new shipment come out this January.  Is this a new tank than the one that was produced a few years ago?  If so, how would the new Walterson compare?  The HL looks great.  How easy would it be to put the 76mm gun and turret on the Walterson A3?
Do not have any tanks yet.  Plus this is my first post!
Regards
John
Hide Signatures
       Post #: 98
RE: Waltersons 105mm Sherman - 12/1/2012 2:06 AM
FreakyDude
Score: 107
Status: offline
Jeanluc  if you want one for Christmas cross your fingers or tell me you will pick up the EMS from China. I will have 3 Tanks that are smoke and sound, IR plastic track versions.
I will have 1 Metal version but that may be spoken for to the first person that sent me an e-mail requesting one. The catch to her will be that I can take it apart and do a full review to post here so we can all see the value the tank has, if she says no to that I may go down the list or I might just put everybodies name in a hat and pick one.
It won't be long before they get here.
quote:
ORIGINAL: jeanluc07
Hide Signatures
       Post #: 99
RE: Waltersons 105mm Sherman - 12/1/2012 2:24 AM
edoubleaz
Score: 233
Status: online
quote:
ORIGINAL: Panther G
I think the Airsoft nature of these tanks strikes again.
check out www.desertarmor.com for all our work.
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.422RCU1
