Winter builds    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Winter builds
Page: [1]
Login
Winter builds - 11/24/2012 1:12 AM
Rick W
Score: 100
Last Login: 5/20/2013
Status: offline
Hi Guys,
Just woundering what your're building over the winter. I have a P-51d for Class I carrier, designed by John Blum, and a profile Big Tiger stunt, designed by Claus Maikis, on the board.
Rick
Hide Signatures
       Post #: 1
RE: Winter builds - 11/24/2012 1:28 AM
BtnFlyGuy
Score: 105
Status: offline
I have an OTS Ringmaster on the bench and a Goldberg Shoestring and a Sig Twister in the boxes. The Twister is going to be "Fancherized".
BTW, does anybody remember the Johnny Casburn "Lucky Sport"? I had one as my first "big plane" in the '70's and I'd love to get my hands on one again!
_____________________________
Once more... with gusto!
Hide Signatures
(in reply to Rick W)
       Post #: 2
RE: Winter builds - 11/24/2012 2:54 PM
Gungadin
Score: 115
Status: offline
Finishing up a Pathfinder kit, and just purchased a Shark 35 kit that I should be able to start on in the next 3-4 weeks if all goes well.
Hide Signatures
(in reply to BtnFlyGuy)
       Post #: 3
RE: Winter builds - 11/24/2012 5:03 PM
stuntflyr
Score: 137
Status: online
Been working on a UHP Gieseke Nobler for 8 years, can I finish it?
Son has had a Sterling Mr. Mulligan going for 4 years, same question!
Chris...
Hide Signatures
(in reply to Gungadin)
       Post #: 4
RE: Winter builds - 11/24/2012 6:03 PM
BtnFlyGuy
Score: 105
Status: offline
Chris, How about some pics of your Nobler build? I have one in the box that I'm trying to get the nerve to start. I could use some motivation!
Justin
Hide Signatures
(in reply to stuntflyr)
       Post #: 5
RE: Winter builds - 11/25/2012 2:25 AM
stuntflyr
Score: 137
Status: online
Sure!
Hide Signatures
       Post #: 6
RE: Winter builds - 12/25/2012 8:00 PM
GallopingGhostler
Score: 133
Status: offline
When I complete the Gilbert .074 powered Baby Ringmaster Gee Bee Z variant (fuel proof clear coating left), I am considering making a 3/16" (5 mm) thick poster foamboard version of a Ringmaster Jr. reduced to 26" (660 mm) wingspan for my Gilbert .11 Thunderhead engine. Other options are to start on my Testors .40 Black Head powered 42" (1067 mm) wingspan Sterling profile Hellcat or .15 powered 33" (838 mm) Midwest profile P-40 Warhawk. Also still have to repair my damaged OS Max 15FPS powered Ringmaster Jr.
George Hostler
Clovis MADS AMA Club, Vintage R/C Society (VRCS)
Hide Signatures
       Post #: 7
RE: Winter builds - 12/25/2012 8:48 PM
BtnFlyGuy
Score: 105
Status: offline
Chris, That looks so very good! I finished my RIngmaster and the .15 ME-109. The Shoestring is about 95% complete. The 109 needs a new spinner, the right size, but it was only my second build in 35 years, so I'm not too self-critical.
I traded the Nobler kit for a new Nobler ARF to get in the air with a full stunt ship. I'm thinking of taking on a Vector 40 sometime this winter.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Winter builds - 12/26/2012 4:00 AM
GallopingGhostler
Score: 133
Status: offline
Those are really sharp looking airplanes, BtnFlyGuy. BTW, I think I saw the Ringmaster in a recent Ringmaster Brotherhood discussion. Did you post of picture of it there?
George Hostler
Hide Signatures
       Post #: 9
RE: Winter builds - 12/26/2012 5:17 AM
BtnFlyGuy
Score: 105
Status: offline
That's mine, George. I joined the brotherhood some time back and finally got around to building this one. My very first kit was a Baby Ringmaster back in '69. This is also my first try at Monokote and boy did I learn afew things there!
Hide Signatures
(in reply to GallopingGhostler)
       Post #: 10
RE: Winter builds - 12/26/2012 5:19 PM
GallopingGhostler
Score: 133
Status: offline
Oh, okay BtnFlyGuy, got it. Monokote is neat stuff although different, AFAIK the best in covering and hence why more expensive. I've got two packages of Dave Brown's Skyloft. It is silkspan like but synthetic so it's strong. Shrinks when wet, so it is applied wet. It is inexpensive, so been thinking about using it on my future CL open frame projects. May try water based PVA drywall primer as a sanding sealer on it. Need to get started on my Ringmaster Jr. repairs, broken wing ribs, needs new rudder, broken stabilizer.
Hope you'll give us a flight report on your CL planes when you get a chance, and I'll give one on mine when I finish repairs and fly it.
George Hostler
Hide Signatures
       Post #: 11
RE: Winter builds - 12/27/2012 1:30 AM
Rubbernecker
Score: 105
Last Login: 5/11/2013
Status: offline
quote:
ORIGINAL: GallopingGhostler
Not trying to be a know it all but will give you 2 recommendations: 1. Skyloft requires an enormous amout of filler. I used about 8 coats of dope to seal and it still had some pin holes. That weave has openings the size of #2 pencil lead. Silk or polyspan in my opinion are much easier. 2. I wouldn't use drywall stuff. What ever goes on the skyloft (silk and polyspan as well) needs to be flexable? Ask me how I know? Found out the hard way using Dupont 30 S primer with a flex agent on Skyloft. Painted it with epoxy paint and after about 10 flights, the covering started cracking very bad. Wound up pulling it all off and Monokoting.
Good luck,
John
Remember, there is a reason Skyloft is so cheap!
Hide Signatures
       Post #: 12
RE: Winter builds - 12/27/2012 2:15 AM
GallopingGhostler
Score: 133
Status: offline
quote:
ORIGINAL: Rubbernecker Not trying to be a know it all but will give you 2 recommendations: 1. Skyloft requires an enormous amout of filler. I used about 8 coats of dope to seal and it still had some pin holes. That weave has openings the size of #2 pencil lead. Silk or polyspan in my opinion are much easier. 2. I wouldn't use drywall stuff. What ever goes on the skyloft (silk and polyspan as well) needs to be flexable? Ask me how I know? Found out the hard way using Dupont 30 S primer with a flex agent on Skyloft. Painted it with epoxy paint and after about 10 flights, the covering started cracking very bad. Wound up pulling it all off and Monokoting. Good luck, John Remember, there is a reason Skyloft is so cheap!
John, I gather that opinions differ, some folks have better luck with it than others. I thought I'd try a test case with PVA primer, because it is water based and an acrylic product, which I believe is more flexible than the standard automotive paints, and should fill with less coats.
Thanks though for the warning note. I found out a silk supplier through the Ringmaster Brotherhood. I've used silk and am quite happy with it. Usually weave was filled with 3 or 4 coats of clear dope. One can put a lighter weight finish lighter than plastic iron ons, which is also very strong and resilient compared with silkspan and attractive, too.
It's just that this hobby has over time become more expensive with the decline in widespread marketing that used to occur when many people participated and there was a local hobby shop within arm's reach.
I'm just trying to have the most bang for the buck. So, I'll pass on a report as to my success or failure with Skyloft.
George Hostler
Hide Signatures
(in reply to Rubbernecker)
       Post #: 13
RE: Winter builds - 12/27/2012 4:16 AM
Rubbernecker
Score: 105
Status: offline
No problem and agree. Here is where I have bought silk from which was great & economical: http://www.dharmatrading.com/fabric/silk/habotai.html
What ever you do, have fun doing it and keep us posted if you go the Skyloft route.
John
Hide Signatures
       Post #: 14
RE: Winter builds - 12/27/2012 5:08 PM
GallopingGhostler
Score: 133
Status: offline
John, that's the same link I've got. Yes, the big thing is having fun, and I'll pick a suitable subject as a test case. It may be a large CL model with alternative construction such as sheet foamboard wing ribs with dowel leading edge, etc. to make life interesting.
George Hostler
Hide Signatures
       Post #: 15
RE: Winter builds - 12/27/2012 5:11 PM
GallopingGhostler
Score: 133
Status: offline
George Hostler
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
