Resin coating a arf ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Resin coating a arf ?
Page: [1] 2   next >   >>
Login
Resin coating a arf ? - 11/24/2012 1:26 AM
darth heli
Score: 100
Last Login: 4/19/2013
Status: offline
Hello,
I have a arf that I stripped the covering on. I want to cover it with aluminum tape. So I need to smooth out the surface before applying the aluminum covering tape. Can I get away with just appling a coat of resin to the fuse and sand to fill the wood grain and get a smooth surface, or do I need to use fiberglass with resin?
I'm thinking that the covering I took off didn't provide much strength, so I wanted to just fill and smooth out the wood before I applied the metal skin tape.
Any advise would be great
Jb
Hide Signatures
       Post #: 1
RE: Resin coating a arf ? - 11/24/2012 2:08 AM
huck1199
Score: 115
Last Login: 5/18/2013
Status: offline
Hmmm; Where will you put your rx antenna?
Hide Signatures
(in reply to darth heli)
       Post #: 2
RE: Resin coating a arf ? - 11/24/2012 2:16 AM
darth heli
Score: 100
Status: offline
I was thinking I would wrap it around the prop. Anyways, any real advise? Is this a dumb question?
Jb
Hide Signatures
(in reply to huck1199)
       Post #: 3
RE: Resin coating a arf ? - 11/24/2012 3:05 AM
DJFOURSON
Score: 100
Last Login: 5/14/2013
Status: offline
quote:
ORIGINAL: darth heli
Jb
I wouldn't suggest you do it. Wrapping the antenna around the prop is a bad idea.
Hide Signatures
       Post #: 4
RE: Resin coating a arf ? - 11/24/2012 4:02 AM
frets24
Score: 148
Last Login: 5/19/2013
Status: offline
Since no-one wants to give you a serious reply, I'll chime in here.
If you are going to use flight metal or equivalent, you'll want to glass the bare wood. The resin will give you a smooth and relatively hard surface , but over time the grain in the balsa will statrt to split or open up and the thin flightmetal will tear or crease at these places. If you are already contemplating a resin covering, the fiberglass cloth is really an inexpensive addition, negligible weight addition, and not really worth mentioning as far as extra hassel, so why not glass it?
Good luck and happy modeling.
Whatcha workin' on?
_____________________________
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
       Post #: 5
RE: Resin coating a arf ? - 11/24/2012 4:10 AM
darth heli
Score: 100
Status: offline
I am comverting an old trusty great planes cessna 182 46 to electric. Im gonna add flaps and cover it with flite metal. Any better ways to get this thing ready to use the flite metal?
Jb
Hide Signatures
(in reply to frets24)
       Post #: 6
RE: Resin coating a arf ? - 11/24/2012 4:16 AM
darth heli
Score: 100
Status: offline
Weight. I wanted to keep it as light as possible. Plus I never done it, so it seemed easier. You do make a point. Thanks
Hide Signatures
       Post #: 7
RE: Resin coating a arf ? - 11/24/2012 2:56 PM
ARUP
Score: 134
Status: offline
Jb
WOW! What a response! Here is my advice and advise you to contemplate the effort involved: metal can shield your Rx from the Tx. Carbon fibre can do the same. Glass cloth and resin creates a stable hard surface for paint or whatever. You have to make it really smooth or every irregularity will show. I've not done foils as you desire but have applied litho plate to glassed surfaces.
Hide Signatures
       Post #: 8
RE: Resin coating a arf ? - 11/24/2012 6:23 PM
LargeScale88
Score: 125
Last Login: 5/13/2013
Status: offline
Its not a bad idea, I have put coats of straight resin on alot of airplanes I have, but I would say use .75 oz cloth. You will not add much thickness and I don't care about weight, so i would use the cloth also.
Hide Signatures
(in reply to ARUP)
       Post #: 9
RE: Resin coating a arf ? - 11/24/2012 6:46 PM
sensei
Score: 176
Status: offline
You should always care about weight on an airplane. There is an old saying that goes like this; looks like a piano and flies like one too...
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to LargeScale88)
       Post #: 10
RE: Resin coating a arf ? - 11/24/2012 8:11 PM
jaka
Score: 158
Status: offline
Hi!
If it's a small.46 plane forget about covering with flitemetal! It will be too much weight!
a much better way is to cover the plane with 25g glas and 24 hour epoxy and use chrome Oracover,wet sanded to an aluminium look on piece of glass. Or just use Oracover!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jan Karlsson - Supplier MVVS Products
Hide Signatures
(in reply to sensei)
       Post #: 11
RE: Resin coating a arf ? - 11/24/2012 11:35 PM
LargeScale88
Score: 125
Status: offline
quote:
ORIGINAL: sensei
Bob
I care about the weight, but I've built small Sig airplanes that came out 5 pounds over the weight range and they flew just fine, so I don't let the small stuff get to me on weight. If it gets too light than a small breeze would cancel out your day of flying. A little heavier airplane handles more wind.
Hide Signatures
       Post #: 12
RE: Resin coating a arf ? - 11/25/2012 12:42 AM
sensei
Score: 176
Status: offline
OK, here we go LOL. Your 5 lb. airplane can easily be built ready to fly at around 3 lbs. your current 5 lb. airplane at 3 lbs. would fly like nothing you have experienced before. I have already done this for others. Lighter flies better have no mistake about it. If you are having trouble flying a light airplane in the wind then you just need more practice, it's really that simple. Heavier airplanes flying better in the wind is just a myth, and I have spent years proving that fact to thousands in my build threads and in many videos over the years.
Here is a old video of my 40% Carden competition airplane built back in a time that everyone was building them at a weight of 38-46 lbs. Mine came in at 28 lbs. ready to fly and when it did it created huge wave in the modeling community. anyway it's all ancient history now. Please keep in mind that this is not my video, it is just one of many out there on this airplane and several other of my hyper light airplanes.
http://www.google.com/url?sa=t&rct=j&q=bob%20sensei%20sawyer&source=web&cd=3&sqi=2&ved=0CDoQtwIwAg&url=http%3A%2F%2Fvimeo.com%2F9748163&ei=bWKxUNXFA6me2wX07IDgAg&usg=AFQjCNE-UtOHPEqa89Yc9AJqSqAAwuZPNQ
Hide Signatures
       Post #: 13
RE: Resin coating a arf ? - 11/25/2012 12:48 AM
oliveDrab
Score: 105
Status: offline
quote:
ORIGINAL: LargeScale88
I covered a Top Flite T34B with .75 oz fiberglass cloth and oil-based polyurethane. It produced a strong, extremely smooth finish but got heavy. It ended up being 18+ lbs. I kept adding coats of polyurethane to get it perfect. Lotsa fun but.............heavy.
"Gentlemen please! There''''s to be no fighting in the war room!" - from Dr. Strangelove
Hide Signatures
       Post #: 14
RE: Resin coating a arf ? - 11/25/2012 1:26 AM
sensei
Score: 176
Status: offline
I don't think anyone has mentioned it but if you are really planning on going electric, weight reduction should be your primary consideration.
Bob
Hide Signatures
(in reply to oliveDrab)
       Post #: 15
RE: Resin coating a arf ? - 11/25/2012 4:00 AM
LargeScale88
Score: 125
Status: offline
quote:
ORIGINAL: sensei
Bob
+1
Hide Signatures
       Post #: 16
RE: Resin coating a arf ? - 11/25/2012 5:58 AM  1 votes
Zor
Score: 181
Status: offline
I am trying hard in my mind to compare a 3 or 5 lbs model to a 28 or 36 to 48 lbs model flying in a wind blowing at 15 to 30 mph and perhaps being gusty.
I just think it cannot be compared.
Please do no tell me to try it; I do not have any models heavier than 11 lbs.
I also do not fly like what I saw in the link.
That type of flying with an engine-prop combination producing thrust may be twice or more the model weight has no appeal to me at all.
I am glad some fellows enjoy this.
Zor
Hide Signatures
       Post #: 17
RE: Resin coating a arf ? - 11/25/2012 6:57 AM
kochj
Score: 143
Status: offline
One would think there is a-bit of a dif when comparing 4-6 lbs planes to a 30-40-lb plane... Just like a 10oz plane to a 40oz plane..
3-4lbs added to a 5lb plane is huge.... I think this would make a dif. in it's ablity to fly when lighter planes are grounded do to 15mph winds..
I can't argue either way, because I don't have any personal experience on the subject matter...
I am only speculating...
Here is a good question:
Is weight a consideration, or is it the overall aircraft shape (including wing profile) that makes the dif. in wind penitration and stabilization?
Or a combination between the 2?
Wouldn't one be able to mix micro balloons/ or sim., in with the epoxy to reduce weight gain? rather than heavy bondo filler???
Also, does anyone know what all the ARF manufactures use ontop of there fiberglass cowls, pants ect?
It is a lightweight coat, that is bonded to the fiberglass, and is painted. It is White in color.
This dosn't fill the weave, but rather is a layer that is flat bonded to the fiberglass, and gives it it's strength.
You see this materal everytime you bust up the fiberglass on the ARF's....
The paint will flake off it very easily once the crack or break occurs...????
Any ideas????
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to Zor)
       Post #: 18
RE: Resin coating a arf ? - 11/25/2012 3:06 PM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: Zor
Zor
It all has to do with wing loading/cubed loading and of course those Reynolds numbers and the smaller the platform is, the more critical weight becomes, and one other little fact; lighter flies better in all around conditions.
It is the assumption by many that a heavier airplane has better penetration qualities, well guess what; a lighter airplane will dampen out the effects of wind/gusts faster than a heavy airplane, so what does this mean; two identical airplanes flying side by side in the wind, one heavy, one light, you will not see the lighter version bouncing around more than its porky counterpart, but from your post I am thinking most of what I am stating is falling on deaf ears.
Not that you probably noticed or even care but that 40 % airplane was performing on a 100 cc power plant, the norm is 150cc-170cc, also you did not notice how easily the airplane was back on the wing at very slow speeds. Now just because I was asked to abuse the airplane in flight for that video does not mean it can't be flown precision or in just circles if that is your flying style.
Here is another video of the ultra light 260 in 30 mph+ wind, nothing but fun.
http://www.icanflyrc.com/JRFlyin/JH_Rice_2008/slides/Bob260.html
Bob
< Message edited by sensei -- 11/25/2012 10:10 PM >
Hide Signatures
(in reply to Zor)
       Post #: 19
RE: Resin coating a arf ? - 11/25/2012 3:13 PM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: kochj
Any ideas????
Yes both are considerations, everything you do in an airplane is a trade off.
Bob
Hide Signatures
(in reply to kochj)
       Post #: 20
RE: Resin coating a arf ? - 11/25/2012 4:09 PM
rgburrill
Score: 126
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: Zor
Zor
+1
Hide Signatures
(in reply to Zor)
       Post #: 21
RE: Resin coating a arf ? - 11/25/2012 4:16 PM
rgburrill
Score: 126
Status: offline
quote:
ORIGINAL: sensei
Not that you probably noticed or even care but that 40 % airplane was performing on a 100 cc power plant, the norn is 150cc-170cc, also you did not notice how easily the airplane was back the wing at very slow speeds. Now just because I was asked to abuse the airplane in flight for that video does not mean it can't be flown precision or in just circles if that is your flying style.
Bob
Sure, and a fully loaded 747 gets tossed around in a thuderstorm as much as a Cessna 150.
Hide Signatures
       Post #: 22
RE: Resin coating a arf ? - 11/25/2012 5:04 PM
kochj
Score: 143
Status: offline
I have huge respect of Bob.... and would take his word as scripture in this matter....
I am trying to learn as much as possible about planes and I don't think there is a subject matter that
wouldn't be benificial to learn about, when it involves planes.
I have wanted to purchase that hyperlite 50% edge for some time now...
Unfortuniately, I do not have the time to build one right now....
Hide Signatures
(in reply to rgburrill)
       Post #: 23
RE: Resin coating a arf ? - 11/25/2012 5:05 PM
Gray Beard
Score: 314
Status: offline
For those that have followed my dribble over the years know I'm not a weight watcher but that just means I don't worry about grams and depending on the planes size ounces. However when it comes to electrics I do start watching the grams. I don't worry about it but I always try to build my electrics as light as I can make them without building them too flimsy. I haven't gotten to use the flight metal so haven't a clue as to the added weight but I have built small planes using chrome and aluminum covering and in this case I think it would be a good way to go.
To glass a plane I fully sheet and glass, that adds quite a bit of extra weight but not as much as most people think. I don't use resin and I use nothing heavier then 3/4 ounce glass. To just cover the wood grain I would give the planes structure several coats of Deft sanding Sealer then sand smooth. Not the water based but the good old chemical based, it gasses off and looses about 80% of it's weight. Sanding smooth removes even more.
Just using one of the good plastic silver coverings would probably be the easiest way to accomplish what the OP is trying to do.
Hope this helps a little but there are several ways to get that aluminum look on a plane. It's also one of the few times I use Mono instead of Ultra. I have had problems with my old stand by Ultra in there silvers and had better luck with mono.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 24
RE: Resin coating a arf ? - 11/25/2012 11:10 PM
oliveDrab
Score: 105
Status: offline
quote:
ORIGINAL: sensei
Bob
Amen to that. If going electric do not put cloth/resin/paint because it could end up weighing too much. I would suggest using Ultracoat. It produces a great looking finish, easy to work with, and not too heavy.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.827RCU1
