My hobby back from the dead !    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> My hobby back from the dead !
Page: [1]
Login
My hobby back from the dead ! - 11/24/2012 3:55 PM
nickpetri
Score: 100
Last Login: 12/10/2012
Status: offline
Ok, hi all. I have flown planes for years back in the day. I remeber when My father had to send in out Kraft radios to have them gold stickered. In the 90's we kinda stopped flying when i found out about girls. Well, now im married and have 3 kids, i bought us and airhogs glider to throw around the yard and it sparked the fire again. So, I went to my parents and blew some dust off the transmitters and cycled some batteries. The only TX that was good was for a Giant Stinger with a Zenoah G62, well, it still flies like it always did! I was suprised that once you can fly you dont forget. I have several other planes to pull from the archives, but batteries have been neglected for so long im afraid they have been expired. NOW the reason for my post:::: I have several hitec RX's from focus 4 TX's, some JR Some Futaba, all different channels for the most part. I know there is 2.4 stuff now, but i have no idea what the hell that even means! What it comes down to is i want to use all my recievers and, if its possible, get 1 New TX that mabybe will work with all the models, brands of recievers or channels??? I tried to search but i just dont understand what is compatible anymore, things have changed A LOT! So, if you guys could direct me on what my options are, it would be very greatly appreciated! I dont want to buy batteries for a ton of TX's. But one TX with a high mah pack that will store several planes or atleast 5 models. Thanks in advance!
Hide Signatures
       Post #: 1
RE: My hobby back from the dead ! - 11/24/2012 5:17 PM
Scar
Score: 126
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: nickpetri
I did that with my Polk's Hobby transmitter. I can select any receiver made for FM 72MHz, any channel, as long as the receiver isn't PCM. (Or AM) I had the Tracker II and loved it, when they brought out the Tracker III with the rx select feature, I bought two of them. Still use them.
Some places require 2.4 GHz radios, but I don't fly there.
Good luck
Dave Olson
_____________________________
The true soldier fights not because he hates what is in front of him, but because he loves what is behind him GKChesterton
Hide Signatures
(in reply to nickpetri)
       Post #: 2
RE: My hobby back from the dead ! - 11/24/2012 5:53 PM
BuschBarber
Score: 104
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: nickpetri
First of all, 2.4 means no more Frequency Pin and little or no interference. You do have to deal eith the fact that all 2.4 Rx's are proprietary. The Rx has to be the same mfg as the Tx. There are some Chinese orange Rx's that are Futaba or Spektrum compatible. JR DSM2/DSMX is Spektrum compatible. JR DMSS is not.
If you buy a Modular Tx, you can use Modules compatable with other mfg,
's Rx's. Hitec Aurora 9 is an example. You can hack some Tx's to support other mfg's Rx's. I have a JR XP9303 which is modular. With a Spektrum module, it is only DMS2 compatible, but I have had no issues.
You could look at sone Hobby King offerings. FRSKY, etc..
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 3
RE: My hobby back from the dead ! - 11/24/2012 6:25 PM
nickpetri
Score: 100
Status: offline
Where can i get a tracker 3, that seems to be what i need. Can i still get a new one? Thanks for the reply. "Some feilds require 2.4" that would really stink! I know the feild i fly at has only a handful of guys on 72mhz, but i always flew on it and never had a problem. Now there should be less of a problem that no one uses it, right?
Hide Signatures
(in reply to Scar)
       Post #: 4
RE: My hobby back from the dead ! - 11/24/2012 7:42 PM
TFF
Score: 148
Status: offline
72 mhz stuff is so cheap, get some receivers to help out the situation now, and maybe a good used TX like a 9C futaba. Then save for the 2.4 you want. I still fly 72 and even have some legal Krafts! but in the market for 2.4.
Hide Signatures
       Post #: 5
RE: My hobby back from the dead ! - 11/24/2012 8:58 PM
nickpetri
Score: 100
Status: offline
quote:
ORIGINAL: TFF
i have a ton of recievers. I just want a transmitter that will work with all of them. I do not want to go 2.4, I have so much stuff from my dad you wouldnt even believe me if i made a list! Will a 9c work with hitec recievers, i dont know how that works. we always had a tx for each plane.
Hide Signatures
(in reply to TFF)
       Post #: 6
RE: My hobby back from the dead ! - 11/24/2012 9:32 PM
Scar
Score: 126
Status: offline
quote:
ORIGINAL: nickpetri
Where can i get a tracker 3, that seems to be what i need. Can i still get a new one? Thanks for the reply. ''Some feilds require 2.4'' that would really stink! I know the feild i fly at has only a handful of guys on 72mhz, but i always flew on it and never had a problem. Now there should be less of a problem that no one uses it, right?
http://www.polkshobby.com/index1.html
That's the link, heres more
POLK'S HOBBY/LMP, INC.
698 S. 21ST STREET
IRVINGTON, NJ 07111
PH# 973-351-9800 FAX#973-351-9700
e-mail:sales@polkshobby.com
I'm with you 100%, won't be switching to 2.4 until they outlaw 72 MHz
Best wishes
Dave Olson
Hide Signatures
       Post #: 7
RE: My hobby back from the dead ! - 11/25/2012 4:42 AM
TFF
Score: 148
Status: offline
Futaba stuff will not work Jr stuff and the other way but some Hitec receivers will switch or can be switched between Futaba and JR. I think some of the later Hitec transmitters can switch shift and maybe some Airtronics. I too have tons of stuff too; I have 7 legal Kraft radios ready to go. Day to day is the 9C and the only reason I am in the market for 2.4 is I do some travel to scale contests, and my 9C is about 10 years old now and I if it packs it in someday I dont want it to be something too good. I too will fly 72 until FCC police come stop me. Like I said 72 stuff is so cheap you can get a both Futaba 9Z and a JR 10X, arguably better TXs than they make today for less than a midrange 2.4 set and have the best, period.
Hide Signatures
(in reply to Scar)
       Post #: 8
RE: My hobby back from the dead ! - 11/25/2012 11:48 PM
prichiuso
Score: 100
Last Login: 4/15/2013
Status: offline
If you're going to stay on 72 MHz (I still am) the Polk Tracker III is probably the best deal around. I think Polk sells them for about $99 dollars now. You sometimes can find them cheaper on e-Bay, but most people like me are loath to give them up. They will work with any 72 MHz FM receiver. The shift can be programmed into the model memory. It has a 99 model memory and the synthesized frequency is internal to the radio; no switches to switch. It also has a frequency scanner built in, and scans the band before it turns on, so it won't turn on if the channel is in use. It has a full 8 channels and is relatively easy to program. I have a couple of 2.4 GHz TXs. one I use for ground stuff and one I'm planning on using for planes. My biggest beef about 2.4 GHz rigs is the expensive receivers and limited model memory. I have over 20 airplanes. The biggest advantage to the 2.4 GHz band, besides no frequency pins, is the short antennas both on the TX and RX. They're great for EDF models.
oldflyer
Hide Signatures
(in reply to TFF)
       Post #: 9
RE: My hobby back from the dead ! - 11/26/2012 12:30 AM
nickpetri
Score: 100
Status: offline
wow! thats cheap, i was under the impression they would be very expensive!  I just bought a 9c and then a hitec module for it. Was that a good idea?  thanks for sharing!
Hide Signatures
(in reply to prichiuso)
       Post #: 10
RE: My hobby back from the dead ! - 11/26/2012 12:59 AM
coriolan
Score: 100
Last Login: 5/21/2013
Status: offline
The Futaba 9C is still an excellent Tx and it work just fine with an Hitec module, it is negative shift only so will work only with Futaba/Hitec receivers or autoshift. Only the Hitec Eclipse-7 and Airtronics RD8000 can chose negative/positive shift in the Tx beside the Polk Tracker III and all are now discontinued and available only as used. But the 9C being modular can be adapted cheaply to 2.4 Ghz when you chose to do so as there is many third party products in that format.
Hide Signatures
       Post #: 11
RE: My hobby back from the dead ! - 11/26/2012 1:56 AM
dirtybird
Score: 173
Status: offline
That Polk Transmitter is a good one but with the low use of the 72mhz that frequency scanner is not much use anymore.
If you are afraid of getting shot down go to 2.4. You don' need a scanner there.
Polk is selling their transmitters cheap because not many want them anymore. Parts may become hard to get for them.
Futaba has been around for more than 40 years. I expect they will be around for many more years.
Hide Signatures
(in reply to coriolan)
       Post #: 12
RE: My hobby back from the dead ! - 11/26/2012 2:24 AM
nickpetri
Score: 100
Status: offline
I think i have only 2 JR recievers. I have mostly hitec focus 4 and 6 tx;'x and they all have rcd 3500 rx's. I bet i have 12 of these. We used to fly all the time on 72 and i cant say i ever had one problem. I would remeber guys crashing and saying they got hit or something, but, what i saw was a crash i believe. One other guy had a plane fly away and when we found it the battery wire had come out of the rx. im pretty excited about this new tx, this technology, in the 90s, if it was around, we could never afford one. Its nice that just about anyone on any income can get into it. Even arf kits, they were so expensive when they came out it was unreal.
I just bought a vista 2-meter glider for $50!! Its built so nice. The only thing was the incidence was so far off, I dont even think it would have flown the way it came! but still its nice! I got a cheapo detrum 400 speed brushless motor and speed controller, wow is that awesome! I chopped the nose offf the vista and stuck it on the front with a folding prop. I fly this with my 4 year old across the street from my house in a big feild. I have it on 72mhz witha old beatup focus 4, i take that plane so high if you blink you wont find it again, you cant tell if it has a tail or not! I kept it in the air for 41 minutes on one 1500 yks mah battery i bought on ebey 2 for $12 shipped! The technology is crazy now, for so damn cheap!!
One thing that really changed is everything is electric! That i cant understand. To me, there is nothing better than a g62 or a surpass 1.20 with no muffler on knife edging by. i guess its just cleaner.
I got a couple of planes ready to today a fourstar 40 i built when i was 16, im now 36, an extra 300 1.60 glow twin fourstroke, i ran them, but i need to get some new rx batteries and my new tx.
I thank you all for the tips!
Hide Signatures
       Post #: 13
RE: My hobby back from the dead ! - 11/26/2012 2:27 AM
nickpetri
Score: 100
Status: offline
I think the futaba is the way to go. I had a hard time finding info on the tracker, makes me wonder if they would support it or push a new product. People seem to still want to buy the 9c.
Thanks again, im looking forward to getting it!
Hide Signatures
(in reply to dirtybird)
       Post #: 14
RE: My hobby back from the dead ! - 11/28/2012 12:04 AM
jrlingrel
Score: 100
Status: offline
Hobby King now carries some 2.4 receivers that are compatible with Hitec transmitters.  I am going to order one and will report here how it works in a few weeks,   Think it has to come from their international warehouse.
John
Take offs are optional, landings are mandatory.
Hide Signatures
(in reply to BuschBarber)
       Post #: 15
RE: My hobby back from the dead ! - 11/28/2012 1:38 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: jrlingrel
John
Sounds like a plan.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to jrlingrel)
       Post #: 16
RE: My hobby back from the dead ! - 11/28/2012 5:29 PM
pilotpete2
Score: 120
Status: offline
if this is the one you want, no need to go to Hobby Kong
http://www.alofthobbies.com/radio-gear/hitec-compatible.html
To paraphrase a new Gieco commercial. How happy are Futaba/Spek and Hitec users with FrSky receivers? Happier than an Antelope with night vision goggles
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
       Post #: 17
RE: My hobby back from the dead ! - 11/28/2012 10:02 PM
Scar
Score: 126
Status: offline
Would that be as happy as Gallagher at a farmer's market?
As a slinky on an escalator?
Dave Olson
Hide Signatures
(in reply to pilotpete2)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
