Water in fuel
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Water in fuel
Page: [1]
Login
Water in fuel - 9/12/2003 5:36:57 AM
bfldrcmedic
Status: offline
I am making a new field box. The fuel can that will fit in it is an old Dave Brown metal can. The problem is, that the can was unused for 2-3 years with the cap on but the inlet and outlet tubes were open. Tonight I pumped some fuel from the jug I am using now and mixed it around and dumped it out. It had some water in it. I put more in it and let it set and then when I dumped it out, more water. The jug I took it out of is new. Is there anyway to get the moisture out or do I need to buy a new can?
Also If the can is in the compartment with the battery for my field box and connections for my field charger and panel, what are the chances of the fuel vapors igniting? The can is sealed tight and I will have vent holes cut in the sides of the compartment.
Tim
       Post #: 1
RE: Water in fuel - 9/14/2003 4:23:55 PM
SpaceCase
Status: offline
You should be fine if you slush some fuel around let it sit slosh and dump it out. Methanol absorbs water. Maybe let the can sit out in the sun. On the panel just make sure everthing is hard wired and your not conecting/diconecting right by the can o fuel.
(in reply to bfldrcmedic)
       Post #: 2
RE: Water in fuel - 10/8/2003 10:20:52 AM
Da R/Cer
Status: offline
I reckon you should just buy a new can.
I would!
       Post #: 3
RE: Water in fuel - 10/13/2003 5:34:53 PM
hauckf
Status: offline
How did you determine that the fuel you dumped out of the can had water in it? Just curious.
       Post #: 4
RE: Water in fuel - 10/13/2003 6:48:54 PM
bfldrcmedic
Status: offline
I had disconnected the fuel line from the pump and some siphoned back on the floor. It had no smell and it wouldn't burn. The fuel in the bottom of the jug looked like it was a different color. I pumped out about 1 cup of fuel and it didn't smell or burn either.
Tim
       Post #: 5
RE: Water in fuel - 10/14/2003 1:23:03 AM
Geistware
Status: offline
What I would do is wash it out good with soap and water. Once rinsed, put the can in the oven at 200 degrees for one hour. Nice and dry!
_____________________________
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.922RCU1
