Aileron hinging    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Combat >> Aileron hinging
Page: [1]
Login
Aileron hinging - 11/24/2012 4:30 PM
blindfaithnogod
Score: 100
Last Login: 5/18/2013
Status: offline
I use a "S" type hinge for my ailerons. Here is what I do:
first I make 12 small strips of strapping tape
then i over lap 2 strips 1/4" and stick together sticky side to sticky side
then i tape one to the bottom of the wing and one to the top right next to each other, I do this at 3 spots on each aileron
lastly I set the aileron inbetween and press the tape down
and there you have a nice never come loose aileron hinge!
now how do you do your hinges?
Hide Signatures
       Post #: 1
RE: Aileron hinging - 11/24/2012 9:00 PM
midair02
Score: 100
Last Login: 5/14/2013
Status: offline
I use basically the same technique. I don't put all the tape on the wing and have to fuss with sliding the the aileron in bewteen the "fingers."
Masking tape was used for illustration only!!! Use Bi-Directional Tape or Regular Strapping Tape. I personally use 1.5 inch Bi-Di for the hinges.
Take 2 pieces and put the sticky sides together overlapping a quarter inch. Each hinge requires two of these. 3 hinges per aileron are recommended. One on each tip of the aileron and one in the middle. 3 hinges are good for SSC, Limited B and Scale 2948. I would go with at least 4 for Open B.
Line up the tape so that the overlap will be at the trailing edge. Note one piece on top of wing and the other on top of aileron. Do this for all the hinges on the aileron.
Lay aileron upside down on wing and line up the hinges.
Fold over all of the pieces of tape onto the aileron.
Fold over all of the pieces of tape onto the wing.
With the aileron at a 30 degree angle downward, add a strip of tape over the top of each hinge, making sure you keep the aileron tight to the wing. This helps keep it really tight.
CLICK TO DOWNLOAD 2 PAGE PDF
_____________________________
William Drumm - RCCA North Central Rep
RCCA - No Cuts, No Glory!!!
Hide Signatures
(in reply to blindfaithnogod)
       Post #: 2
RE: Aileron hinging - 11/24/2012 10:30 PM
DaneMcGee
Score: 100
Last Login: 3/27/2013
Status: offline
Paul,thanks for posting this very important construction tip.
The over-under method is exactly what I use.
Very strong, very tight and zero flutter...............the aileron will fail before the hinge
Dane "Mad Max" McGee,
RC Combat Assoc Vice President
Hide Signatures
(in reply to midair02)
       Post #: 3
RE: Aileron hinging - 11/25/2012 11:38 PM
j.duncker
Score: 121
Last Login: 5/19/2013
Status: offline
Hey guys PLEASE USE THE RCU PHOTO UPLOADER.
Copy large pics into thread makes it sllooooooooow to load. Esp for those on slow connections.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to DaneMcGee)
       Post #: 4
RE: Aileron hinging - 12/4/2012 11:36 PM
DaneMcGee
Score: 100
Status: offline
quote:
ORIGINAL: j.duncker
Thx for the heads up however a slap on the hands to those who contribute to this thread from a moderator is better handled via private message.
We do welcome however any constructive exchange of information about the topic.
< Message edited by DaneMcGee -- 12/5/2012 1:07 PM >
Hide Signatures
(in reply to j.duncker)
       Post #: 5
RE: Aileron hinging - 12/4/2012 11:41 PM
DaneMcGee
Score: 100
Status: offline
Paul, thx for starting this thread..... good information.
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
