What is it?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> What is it?
Page: [1]
Login
What is it? - 11/24/2012 6:15 PM
JollyPopper
Score: 158
Last Login: 5/24/2013
Status: offline
I have been in nitro powered RC for quite awhile but now I want to dabble into electric power. I am looking at a Scorpion 2205-36 motor. What does that mean? What kind of power will that deliver in terms of how much airplane will it handle comfortably? What size battery do I need to power it? How big an ESC do I need to operate it? What size nitro engine would that equate to and how do I know that from the 2205-36 designation? Any help will be appreciated.
_____________________________
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
       Post #: 1
RE: What is it? - 11/25/2012 12:10 AM
gaRCfield
Score: 156
Last Login: 5/23/2013
Status: offline
First, you should read through this - I learned a lot from it:
http://www.rcuniverse.com/forum/m_7100376/tm.htm
Electric motors are usually named by their size - (diameter+length and rpm rating). So, the 2205-36 has a 22mm stator diameter, 5mm stator thickness, and 36 wire turns (which equates to 1670kV). Some brands will use the actual kV value for the last number (ie Scorpion 4035-250 which has a 40mm stator that is 35mm thick, and spins 250 rpm per volt).
The best thing you can do is find someone running that motor successfully and copy their setup. Then you can try changing props or batteries from there.
Electric power is a full system - all of the components matter when setting up the plane. So you need to consider prop size, batteries, etc. when making your decisions. It is difficult to say what kind of power or rpm you will get since changing one part of the system will impact everything.
Joe Marri
Enjoying all things aviation.
Hide Signatures
(in reply to JollyPopper)
       Post #: 2
RE: What is it? - 11/25/2012 2:25 AM
JollyPopper
Score: 158
Status: offline
WOW!!!!!!!!!!!!!!!! There is a lot of information in that article. It will take some time for my old brain to get around all that info, but it certainly reads as if it were worth it. I think I'll print it and try to digest it a bit at a time. Thanks for the link.
Hide Signatures
(in reply to gaRCfield)
       Post #: 3
RE: What is it? - 11/25/2012 4:16 AM
gaRCfield
Score: 156
Status: offline
You're welcome. Once you get through it, let us know what questions you have - there will be at least a few
Joe Marri
Hide Signatures
       Post #: 4
RE: What is it? - 11/28/2012 4:47 AM
jdetray
Score: 115
Last Login: 5/20/2013
Status: offline
Here are the specifications for the Scorpian S-2205-36 motor.
http://www.scorpionsystem.com/catalog/discontinued/motor/s22/S-2205-36T/
Some of the highlights:
Max Continuous Current: 10 Amps
Max Continuous Power: 110 Watts
Max Lipo Cell: 3s
- Jeff
My other hobby: www.AstronomyBoy.com
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
