X-1 Charger    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> X-1 Charger
Page: [1]
Login
X-1 Charger - 11/24/2012 7:59 PM
capitalB
Score: 106
Last Login: 4/29/2013
Status: offline
I just git my new X-1 charger and it displays "input voltage error" It doesn't matter if it is connected to a/c or d/c. I really wanted to go flying..Any help?
_____________________________
The wind was so calm today,it was blowing backwards...Saito club member #703, F22 Driver
Hide Signatures
       Post #: 1
RE: X-1 Charger - 11/24/2012 11:54 PM
JIMF14D
Score: 104
Last Login: 5/20/2013
Status: online
Well I don't have that charger but most of them seem to work the same with the same or similar menus.  Input voltage voltage error means the voltage input at the charger from your DC source or the internal power supply is less than what is set up in the "user set up menu" for "input voltage level".  It usually comes up if your car battery is getting low and you have a large battery on charge. I have never seen it come on with my charger on AC.
it is possible it was set to a high value at the factory maybe.  So turn the charger on, press the main menu button, usually the button on the left to select user input and then the inc/dec button until you see input power power level or cut off menu and the setting there and read the value. if you are running off a car battery it should read close to the car value  (11.5 to 14.5 volts) or so depending if the engine is running or off
. You want the alarm setting to be set to a value lower than your power source level.
I usually set mine to 10 volts or so.  You should set all these user things before you connect any batteries to charge on the charger.
Hope this helps.
Have fun
JIm D.
Hide Signatures
(in reply to capitalB)
       Post #: 2
RE: X-1 Charger - 11/25/2012 12:13 AM
A.T.
Score: 181
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: capitalB     I just git my new X-1 charger and it displays "input voltage error"
What AC & DC Sources? are they capable of delivering a constant 11V to 18V at 8A?
If a large battery is to be charged then the old field SLA (GellCell) starter / charger  battery of 7A are
no longer suitable in most instances.
1.  Input Voltage Error - as per attached extract from Manual.
2.  If a battery to be charged was connected?
X-1 Charger
Manual page 19 = If the voltage of any cell
is abnormal, the X1 will show an error message and forcibly terminate
the program. So if there is battery damage or a disconnection, you can
see the error message and press INC to know which cell is damaged
In need, suggest email/phone service direct:
Hitec Warranty & Service  - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time.  Reach us at 858.748.8440 or
 service@hitecrcd.com any time you have a question"
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Click to see fullsize image.
Click for fullsize
R/C hobby consultant for various companies
Hide Signatures
       Post #: 3
RE: X-1 Charger - 11/25/2012 1:11 AM
JIMF14D
Score: 104
Status: online
Also I think if you have it connected to LIpo  and do not have the right balance lead or balance connection and select the balance mode I think  you will get voltage error. Did you try just charging for a bit in "charge" mode?
Hide Signatures
       Post #: 4
RE: X-1 Charger - 11/25/2012 1:39 AM
capitalB
Score: 106
Status: offline
i realize you have to cover the basics for the newbie......I have been with this hobby for 20yrs. I cannot access any menu functions, whether I am connected to 120v a/c or 13v dc. . The charger on power-up sounds the alarm and screen reads the input voltage error message.
Hide Signatures
(in reply to A.T.)
       Post #: 5
RE: X-1 Charger - 11/25/2012 4:21 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: capitalB    i realize you have to cover the basics for the newbie......I have been with this hobby for 20yrs. I cannot access any menu functions, whether I am connected to 120v a/c or 13v dc. . The charger on power-up sounds the alarm and screen reads the input voltage error message.
As in post #3, given that the power supply is deemed to be adequate,
please  email or phone service direct: Hitec Warranty & Service  - homepage.
Alan Tong.
Hide Signatures
       Post #: 6
RE: X-1 Charger - 11/26/2012 7:53 PM
capitalB
Score: 106
Status: offline
Hi-Tech customer service is the best! That is why I only use their products!
Hide Signatures
(in reply to A.T.)
       Post #: 7
RE: X-1 Charger - 11/26/2012 9:19 PM
JIMF14D
Score: 104
Status: online
So what was the problem and solution?
Jim D
Hide Signatures
       Post #: 8
RE: X-1 Charger - 11/27/2012 12:48 AM
capitalB
Score: 106
Status: offline
I sent it back to Horizon to get a new one.......But they are on global back-order. I bought another brand that is the same, but has a USB to allow software updates
Hide Signatures
(in reply to JIMF14D)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
