Saginaw lake freighter    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> Saginaw lake freighter
Page: [1]
Login
Saginaw lake freighter - 11/26/2012 3:56 AM
aircoffee
Score: 100
Last Login: 1/21/2013
Status: offline
Beginning construction on a scratch built 1/72 scale lake freighter. The goal is to make this ship fully operational.
Posted a couple of pictures in my gallery. Can't seem to upload them on the thread.
< Message edited by aircoffee -- 12/2/2012 5:14 AM >
Hide Signatures
       Post #: 1
RE: Saginaw lake freighter - 12/2/2012 1:35 PM
keysguy
Score: 100
Last Login: 4/28/2013
Status: offline
would love to see pictures of this build
Hide Signatures
(in reply to aircoffee)
       Post #: 2
RE: Saginaw lake freighter - 12/2/2012 4:02 PM
aircoffee
Score: 100
Status: offline
I tried posting pictures here, but ran into some kind of technical problem. If you go to my profile, I was able to upload a couple of pictures to my gallery.
Hide Signatures
(in reply to keysguy)
       Post #: 3
RE: Saginaw lake freighter - 12/3/2012 1:50 PM
udave
Score: 100
Last Login: 5/11/2013
Status: offline
Hi All
Here's some pictures of my laker
                                         Dave U
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4
RE: Saginaw lake freighter - 12/3/2012 6:00 PM
aircoffee
Score: 100
Status: offline
How long is your ship? The one I'm building will be 106" long and 12" wide.
Hide Signatures
(in reply to udave)
       Post #: 5
RE: Saginaw lake freighter - 12/3/2012 8:43 PM
udave
Score: 100
Status: offline
Hi
My Ship 7 feet 3inches long and 12 inches wide.and built out of fiber glass going to have 10 gear boxes to run the water pumps and auger and run the boom.
any more info I can think of I will let you ok  It's a scale model of Algoma  Captain Henry Jackman
Click for fullsize
Hide Signatures
       Post #: 6
RE: Saginaw lake freighter - 12/3/2012 9:22 PM
aircoffee
Score: 100
Status: offline
Sounds fantastic! I've got pictures that I took of Algosoo up at Duluth earlier this year. I'm planning to use Arduino micro controllers to handle the self unloader operation. Thinking about using an ultrasonic range sensor to activate the fog horn when another boat or duck crosses in front of the ship. I'm guessing a year or two before mine is operational.
Hide Signatures
(in reply to udave)
       Post #: 7
RE: Saginaw lake freighter - 12/3/2012 9:29 PM
udave
Score: 100
Status: offline
I am planning to use an  Arduino micro controllers as well to run radar and bow thruster and other things.
< Message edited by udave -- 12/3/2012 10:02 PM >
Hide Signatures
       Post #: 8
RE: Saginaw lake freighter - 12/3/2012 11:26 PM
aircoffee
Score: 100
Status: offline
Are you building to 1/96 scale?
Hide Signatures
(in reply to udave)
       Post #: 9
RE: Saginaw lake freighter - 12/4/2012 12:00 AM
udave
Score: 100
Status: offline
I think it's 1/100
Hide Signatures
       Post #: 10
RE: Saginaw lake freighter - 12/5/2012 12:03 AM
keysguy
Score: 100
Status: offline
both are very nice thanks for sharing Keep us posted on the build as it goes along
Hide Signatures
(in reply to udave)
       Post #: 11
RE: Saginaw lake freighter - 12/10/2012 1:37 AM
aircoffee
Score: 100
Status: offline
So, here's a question for everyone. My Great Laker is 106" long, 12" wide, and has a single 4 blade screw. I'm planning on using a 4 blade 3" prop that I already have on hand. I'm hoping to use a "Battlers Connection gear drive", two motors into one shaft. I'm planning on using two 550 motors at 12 volts. Do you think this would be enough to drive the ship at scale speeds? I'm thinking that when the ship is at the water line, she'll be over 200lbs, possibly 300 lbs (I'm planning on having ballast tanks to add weight to the ship in the water). Looking for all thoughts and opinions on this. Thanks!!
Hide Signatures
       Post #: 12
RE: Saginaw lake freighter - 12/11/2012 1:31 AM
Apismelifera
Score: 100
Last Login: 2/21/2013
Status: offline
You could build a test stern nothing fancy no need to sand, only paint it, just a couple quick coats of primer, no rudder needed. Mount your motor gear box and propeller like it would be in your model. Then you can run it in your test tank. You only need to do this for a few seconds. just long enough to get an accurate current measurement. The whole idea is to simulate the prop load to find out if your motors are drawing to much current.
If you're motors are pulling the same or nearly same current that the manufacturer quotes for max efficiency then you're good. Less is ok, that would let the motors run cooler. If its higher you need to gear down more or get a smaller prop.
Or if do not have an amp meter, just run it for 60 seconds then stop. Gently and briefly touch the motor case. If it's cool enough to hold your finger on it then the motor is not too hot.
When you do this test the more accurate the shape of the motor test platform, or stern the better. Also the depth of prop in the water.
Doing this now will let you evaluate your drive line choices before mounting it in the full size model. Unless you have a test tank big enough to hold the full size model?
You do realize too that even with a perfect drive line the model will take a while to accelerate to scale speed. And also it will take a while to stop.
Sounds like a fun project. Good luck!
_____________________________
John KaBang
Hide Signatures
       Post #: 13
RE: Saginaw lake freighter - 12/11/2012 4:32 AM
aircoffee
Score: 100
Status: offline
Thanks!! That is a great idea!! I currently use a setup like this to power a 40 lbs, 6ft long model of the Bismarck. Definitely have to give it a little time to build up speed and stop.
Hide Signatures
(in reply to Apismelifera)
       Post #: 14
RE: Saginaw lake freighter - 12/11/2012 4:17 PM
udave
Score: 100
Status: offline
Hi All
My plan is to use two gear boxes on a controlable pitch prop I'm working on as we speak
The reason for two gear boxes is simple HI GEAR and Low gear I beleive the the ESC will do the speed control for me.
With the pitch being controled I think that should get her up to speed without burning out an motor
Well it looks good on paper but if it works? I will let you know
                                                          Have a good Day
        Dave U
Hide Signatures
       Post #: 15
RE: Saginaw lake freighter - 12/31/2012 5:28 AM
aircoffee
Score: 100
Status: offline
A few pictures of my progress on the Saginaw.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: Saginaw lake freighter - 1/2/2013 3:30 PM
udave
Score: 100
Status: offline
Hi Aircoffee
I just want to let know abt a new type of micro controller it's called Raspbarry Pi
it offers more an the Arduino check it out let me know what you think Later
        Dave U
P.S Pictures are the sea trials last summer
Click for fullsize
Click for fullsize
< Message edited by udave -- 1/3/2013 11:50 PM >
Hide Signatures
       Post #: 17
RE: Saginaw lake freighter - 1/16/2013 7:26 PM
aircoffee
Score: 100
Status: offline
 According to boatnerd the Saginaw is in your back yard.
Hide Signatures
(in reply to udave)
       Post #: 18
RE: Saginaw lake freighter - 1/17/2013 12:36 AM
udave
Score: 100
Status: offline
Hi
Yes it is It's unloading right now I hope it gets out of the harbour later before the winds starts up
Have a good one
                                                              Dave U
Hide Signatures
       Post #: 19
RE: Saginaw lake freighter - 1/19/2013 12:56 AM
aircoffee
Score: 100
Status: offline
Been working on the unloading conveyor.  Too cold to work in the garage.
Hide Signatures
(in reply to udave)
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
