charger    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> charger
Page: [1]
Login
charger - 11/26/2012 4:41 AM
alis902
Score: 100
Last Login: 4/7/2013
Status: offline
 Hi
What are the parent of the power is used to charge the battery when outdoors?
Hide Signatures
       Post #: 1
RE: charger - 11/26/2012 5:07 AM
ArchNemesis
Score: 100
Last Login: 5/20/2013
Status: offline
Honda eu1000i
http://powerequipment.honda.com/generators/models/eu1000i
_____________________________
Mark Atwood
Team Airtronics | Castle Creation | F3A Unlimited | YS Parts and Service
Hide Signatures
(in reply to alis902)
       Post #: 2
RE: charger - 11/26/2012 6:13 AM
alis902
Score: 100
Status: offline
 Hi
Do not use the (marine) battery rather than a generator?
Hide Signatures
(in reply to ArchNemesis)
       Post #: 3
RE: charger - 11/26/2012 11:42 AM
cmoulder
Score: 106
Last Login: 5/16/2013
Status: offline
The generator is much more convenient for field charging than the marine battery, which itself is another battery to charge.
This seems to be the consensus opinion by a very wide margin. There may be exceptions, but I don't recall seeing a marine battery at all last year at the various events I attended.
I also use the Honda 1kw unit and feel it is perfect for our (pattern) purpose, as is the 2kw unit if you need more capacity for multiple charge stations. Even with the 1kw unit the recharges are so quick (depending on what charger you use) that it can easily serve 2 or 3 pilots all day long.
Bob
Hide Signatures
       Post #: 4
RE: charger - 11/26/2012 2:54 PM
ArchNemesis
Score: 100
Status: offline
The Generator is lighter.  Easier to transport.  Provides unlimited power with only a little gas.   Will last for many many years too.
A marine battery is very heavy to transport and move.  Provides a limited amount of charging before it must be recharged.  And will only last a few years before needing to be replaced.  Much cheaper though.
Mark Atwood
Hide Signatures
(in reply to cmoulder)
       Post #: 5
RE: charger - 11/27/2012 4:25 AM
alis902
Score: 100
Status: offline
 Hi
Is not the noise problem?
I think the price is expensive.
Hide Signatures
       Post #: 6
RE: charger - 11/27/2012 4:48 AM
VerneK
Score: 100
Status: offline
The Honda EU-1000i is very quiet at 56db. To further reduce the sound, many of us place the generator at the front of our vehicles which are backed into the pit area and use an extension cord. The distance and natural sound barrier provided by our vehicles turn the already low noise level into a mere hum. One rule I personally follow is to pack up the generator immediately after I've charged my last battery lest I forget about it and run over it when I leave. Seen it happen and even named the rule after the guy that did it to his (nobody any of you know). BTW, my Honda just completed its 9th flying season and I decided to treat it with its first new spark plug even though it still runs great. I change the oil halfway through each flying season and then again at the end. The spark plug is the first part I ever bought for it.
Verne
quote:
ORIGINAL: alis902
Β Hi
Hide Signatures
       Post #: 7
RE: charger - 11/27/2012 12:12 PM
cmoulder
Score: 106
Status: offline
This protocol works very well to keep noise to a bare minimum. The addition of a little 3-sided shield would reduce it to almost nil. One of the fields where I fly has very low environmental/human-made sounds (aside from the flying models!) but the sound is so low one forgets that a generator is running.
Expensive? Yes, a bit, but when the convenience and cost amortization over 10 years are taken into account, it is a pretty good deal. I got my 1000-wattter from wisesales.com for around $735USD, which included shipping.
Bob
Hide Signatures
(in reply to VerneK)
       Post #: 8
RE: charger - 11/27/2012 3:52 PM
jgg215
Score: 105
Status: offline
If cost is the major problem then you can get a two-stroke generator from Harbor freight for 90-130 dollars depending on current sale price that will get the job done. Of course it is not as attractive, noisier, you need to add the oil to your gas and the output is not as well regulated. On the other hand, it is about as light as a Honda and cheaper to replace than repair. Did I say it was noisy?
At the other end of the price spectrum, the Yamaha EF1000is is comparable to the Honda. Get the one with a better sale price.
Best solution is to join a club with electric power.
John
Hide Signatures
       Post #: 9
RE: charger - 11/27/2012 4:04 PM
ArchNemesis
Score: 100
Status: offline
I think the person asking the original question is using an online translator, so I've been trying to keep the answers simple.
The Honda Generator is VERY quiet.   It is expensive because it is quiet.  It's a big investment, but I think it is the very best option.
Mark Atwood
Hide Signatures
(in reply to jgg215)
       Post #: 10
RE: charger - 11/27/2012 4:40 PM
rcpattern
Score: 100
Last Login: 5/21/2013
Status: offline
After doing a bunch of research, look at the Yamaha generator's as well. They are just as light, if not lighter than the Honda's and they are actually rated quieter than the Honda's. Both are excellent value's, but after seeing them both, I went with the Yamaha. They aren't any cheaper, but they are just as nice as the Honda.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
       Post #: 11
RE: charger - 11/27/2012 9:45 PM
jeffk464
Score: 100
Status: offline
quote:
ORIGINAL: ArchNemesis
Honda eu1000i
If your going to mess around with a small gas engine why not just put one in your plane?
Hide Signatures
       Post #: 12
RE: charger - 12/6/2012 12:07 AM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
Hyundai 2000 watts generator.
24 Volt power supply
Charge 10-16 amps
Cheap at Walmart $399 on Sale
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to jeffk464)
       Post #: 13
RE: charger - 12/6/2012 11:10 PM
vquick
Score: 105
Status: offline
Also you need a Vquick Custom Charging Box to complete your setup they come in 12v or 24v
Click to see fullsize image.
Click for fullsize
Click for fullsize
2010 2011 2012 D3 Advance Champion
HAIYIN Batt. Sponsored Pilot
Hide Signatures
(in reply to Flyer88)
       Post #: 14
RE: charger - 12/7/2012 6:35 PM
KGSS28
Score: 100
Status: offline
Wish I had a nice box.
Hide Signatures
(in reply to vquick)
       Post #: 15
RE: charger - 12/7/2012 8:11 PM
Flyer88
Score: 100
Status: offline
I think they dock you points if you don't have a nice box ! β˜ΊπŸ˜‰
Hide Signatures
(in reply to KGSS28)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
