Back for the first time    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Twist 3D 40 (less Rx) - RTF
Seller:  stuk_at_work
Details:   $250.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> IMAC >> Back for the first time
Page: [1]
Login
Back for the first time - 11/26/2012 5:16 AM
Fear2722
Score: 100
Last Login: 5/5/2013
Status: offline
Hey all!
Probably 10-12 years ago I belonged to IMAC, and attended one JR IMAC Challenge in Rantoul, IL as a spectator. Hell it was probably 12-14 years ago now that I think of it.
Anyway, Looking to get in to it this next year, naturally starting off in the basic class. The only "scale" bird I have for the moment is my Hangar 9 Christen Eagle II. I am confident in my abilities with this aircraft, but never have flown a "Routine".
Aside from re-joining IMAC, where do I begin? Will the CE be good enough for the first year while I'm getting the hang of it? Any tips/advice are appreciated. I'm in the North Central region.
Thanks!
Donivan
Hide Signatures
       Post #: 1
RE: Back for the first time - 11/26/2012 1:39 PM
pe reivers
Score: 646
Last Login: 5/20/2013
Status: offline
Visit an IMAC event, and look at what you like best. That should get you back on track real fast.
_____________________________
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Fear2722)
       Post #: 2
RE: Back for the first time - 11/27/2012 1:06 AM
speedracerntrixie
Score: 189
Status: offline
Go to the IMAC website and take a gander at the rules:  Mini-IAC.com
The first thing is that for Basic Class a scale airplane is not required. Personally I would love to see someone show up and fly a CE though, major cool factor IMO. While on the IMAC site download and print out a copy of the basic sequence. Most guys are capable of  "Flying" every manuver on the sequence. Notice what I did there? There is a huge difference between flying  a Cuban eight and "performing" a cuban eight so that it scores well. The first thing you will need to do is set up your CE so that it will fly the sequence easily. For most guys this means reducing the rates, fine tuning the CG, get the engine thrust set correctly and making sure it is 100% reliable. Then comes the practice. For new aerobatics pilots, I suggest just going out and practice strait lines with turn around manuvers at each end. Almost everyone then realizes just how difficult that is. The goal is to position the airplane about 150' from the dead line and keep it there, with wings level while doing 1/2 cubans, humpty bumps or sharks tooth turn arounds. Practice this until you can keep the box depth, then start in on the sequence. Keep a relitive slow pace between manuvers, rushing the judges always ends up in poor scores.
Hide Signatures
       Post #: 3
RE: Back for the first time - 11/27/2012 4:57 PM
underdw
Score: 100
Status: offline
Find a mentor who can fly with you frequently!
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 4
RE: Back for the first time - 11/27/2012 11:24 PM
FlyinTiger
Score: 105
Last Login: 5/18/2013
Status: offline
While it may be getting cold and not very fun to fly at your local field you can still get in some practice. There's probably someone in your local area that is also an IMAC member and chances are they would love to get together over a cup of your favorite hot beverage and chat about the rules, walk you through the basic sequence using a stick plane and talk about common downgrades.
Biggest thing is to capitalize on your previous experience and not be shy about getting to know others. Attend a judging school in your region this coming Spring and be sure to read the rules...others have mentioned this, but it is so important. Several guys who flew IMAC in years past showed up at a contest I CD'd last year and hadn't read the current rules...it took a lot of time to help them during the contest and was a distraction. There were five guys like this who hadn't read the rules or practiced...don't be that guy!
Good luck! I'd love to be at the contest where the CE flies...it would be neat to see a classic aerobat be put through the paces.
Albert Hibpshman
Hide Signatures
(in reply to underdw)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
