low bucks 6x6 vacation build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> low bucks 6x6 vacation build
Page: [1]
Login
low bucks 6x6 vacation build - 11/26/2012 12:56 PM
nitro stan
Score: 100
Last Login: 5/24/2013
Status: offline
i had no clue or direction when i started this thing.i didnt even plan to build it, just happen to come across a set of axial axles cheap a few days before my vacation.
i got the axles last tuesday and started building
then tore done my ax10 i hardly ever run.laid everything out and bent up some 3/8's square tube,and made some shock hoops out of 3/16th brake line
built a 4 line truss for the rear axle
ended up wasting a day and a half and a tank of gas running around looking for a body. then a internet search netted me some pics of 6x6 land rovers. so i cut a dingo body in half
a lack of styrene skills lead to a steel/tube flat bed truggy kinda mix
flex shots
i still have to figure out bumpers and some mounts for the cab. i got a dual motor mount on the way for this pig. gonna run dual 55's in it.
the rest of the electronics are a sidewinder esc,hobbyking HV mg servo and a single integy 65t(some to be replaced) and a old futaba 2pl i had on the ax10.
so far im still under 200 bunks into this thing
Hide Signatures
       Post #: 1
RE: low bucks 6x6 vacation build - 11/26/2012 11:06 PM
nitrosportsandrunner
Score: 296
Last Login: 5/25/2013
Status: offline
dude, thats awsome!
Ive seen many 6x6's on the web, but they all look like huge money pits.
Nice to see one built with a low budget in mind.
And your previous experince with frame making for the venom show on this build. It looks great!
The body is coming along nicely as well. Inspiring me to continue on my 1/5 build!
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to nitro stan)
       Post #: 2
RE: low bucks 6x6 vacation build - 11/27/2012 1:39 AM
SyCo_VeNoM
Score: 626
Status: offline
love the chassis I've been thinking of doing a similar one for my 6wd WK just I suck at welding
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 3
RE: low bucks 6x6 vacation build - 11/27/2012 2:28 AM
Score: 296
Status: offline
quote:
ORIGINAL: SyCo_VeNoM
dont HAVE to weld syco. The welded shock mounts look better, but I used stock SCX10 shock towers on my custom 1/5 chassis. Just bolt them right on.
I didnt know you have a 6wd WK. If you need one, I have a good trans!
Nitro stan, after seeing your second chassis now, I wish I had done my 1/5 with sold square stock. I think the solid bends nicer than the tubular sqaure stock I used for my 1/5.
Keep the build pics comming.
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 4
RE: low bucks 6x6 vacation build - 11/27/2012 2:43 AM
SyCo_VeNoM
Score: 626
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
ehh never saw it? Lil over a year ago I bolted 2 pieces of aluminum onto the back of the WK's TVP's to add another axle and shock mounts. Worked quite well but due to the WK's massive travel the rear drive shaft likes to pop out if the shocks are decompressed. I think my was was one of the most dirt cheap ways to make a 6X6. I've threw the idea around in my head to go 8X8 as I got another WK axle laying around that is meant for another project
In all honesty on part (outside the stock WK) I think I spent $30 for the axle, and $8 for the parts bag to get the linkages from HPI, and a piece of scrap aluminum I had from when I made a chassis plate for another RC.
Just realised I never made a build thread for it prolly cause of how fast it was to do. I think spent like 20-25 mins total making it (from drawing, and cutting the TVP extension to bolting it on)
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 5
RE: low bucks 6x6 vacation build - 11/27/2012 4:40 AM
nitro stan
Score: 100
Status: offline
thanks guys
both chassis iv done are square tube, not solid. i hacked up a couple metal things that hang on the wall.
it had to be cheap to do it this close to christmas.
parts breakdown
used ax10 basket case-$40(used everything off it,even parts of the chassis)
sidewinder esc-given to me
hot racing steel tranny gears,ebay-$26
motor plate and extra pinion-$21
pair of used axles for pass through-$55
hobbyking HV servo and horn-$35
hardware,tube,all thread from home depot and LHS-$65
i had motors,radio sheel metal for the bed,everything for brazing. did have to buy another bottle of mapp-$10.
$217 total. forgot about the pinion and other bottle of mapp gas
Hide Signatures
       Post #: 6
RE: low bucks 6x6 vacation build - 11/27/2012 4:41 AM
nitro stan
Score: 100
Status: offline
forgot a couple pics
dual motor mount
cab mounted and bed painted
Hide Signatures
       Post #: 7
RE: low bucks 6x6 vacation build - 11/27/2012 3:28 PM
Apachy
Score: 100
Last Login: 2/8/2013
Status: offline
outstanding build !
Hide Signatures
       Post #: 8
RE: low bucks 6x6 vacation build - 11/28/2012 2:54 AM
nitro stan
Score: 100
Status: offline
got my front bumper built. paint drying now. nothing fancy, just a piece of 1/2" tube,a hoop on top and shackle mounts
Hide Signatures
(in reply to Apachy)
       Post #: 9
RE: low bucks 6x6 vacation build - 12/1/2012 6:16 PM
jmz6
Score: 100
Last Login: 4/13/2013
Status: offline
Nice job on keeping the build price low
Hide Signatures
       Post #: 10
RE: low bucks 6x6 vacation build - 12/2/2012 2:36 PM
nitro stan
Score: 100
Status: offline
bumper done, i found some steel mesh scraps to play with and got some body posts for the rear of the cab
Hide Signatures
(in reply to jmz6)
       Post #: 11
RE: low bucks 6x6 vacation build - 12/5/2012 7:17 PM
t9dragon
Score: 328
Status: offline
Looks good... Nice build..
Hide Signatures
       Post #: 12
RE: low bucks 6x6 vacation build - 12/6/2012 3:35 AM
nitro stan
Score: 100
Status: offline
rebuilding the bed
Hide Signatures
(in reply to t9dragon)
       Post #: 13
RE: low bucks 6x6 vacation build - 2/2/2013 11:42 PM
gueroaero
Score: 100
Status: offline
Very nice build .
Hide Signatures
       Post #: 14
RE: low bucks 6x6 vacation build - 2/4/2013 1:06 PM
nitro stan
Score: 100
Status: offline
thanks. it works better than i though it would
Hide Signatures
(in reply to gueroaero)
       Post #: 15
RE: low bucks 6x6 vacation build - 2/5/2013 9:38 PM
rnemovr
Score: 100
Status: offline
Very sweet build. Nice fab work.
If you ain''t Cav...
Hide Signatures
       Post #: 16
RE: low bucks 6x6 vacation build - 2/8/2013 4:01 AM
TheBennyB
Score: 105
Status: offline
Fantastic build!  Now go get it dirty!!
AAF # 111284-25
A.C.E. member
Hide Signatures
(in reply to rnemovr)
       Post #: 17
RE: low bucks 6x6 vacation build - 2/11/2013 1:14 PM
nitro stan
Score: 100
Status: offline
been dirty and broke already
Hide Signatures
(in reply to TheBennyB)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
