High Lift or Not?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> High Lift or Not?
Page: [1]
Login
High Lift or Not? - 11/26/2012 1:45 PM
tbaysal2000
Score: 100
Last Login: 5/6/2013
Status: offline
What type of prop is better for a 48" offshore mono with standard Zen 26cc. High lift or not?
Another question is when 3 blade is preferred to 2 blade?
Tufan
Hide Signatures
       Post #: 1
RE: High Lift or Not? - 11/26/2012 2:32 PM  2 votes
martno1fan
Score: 221
Last Login: 5/18/2013
Status: online
Last thing you want on a mono is a high lift prop,theyre best suited to hydros and riggers,3 blade over 2 it all depends, personally i test dif props till i find the best one for the setup wether that be 2 or 3 even 4 blades.A good prop for your boat and motor would be a 7015/3 this is a very good prop for a mono,the 2 blade version is quicker to hook up but the 3 blader is a better all round prop i find.
Mart
_____________________________
waveridermouldings
Hide Signatures
(in reply to tbaysal2000)
       Post #: 2
RE: High Lift or Not? - 11/26/2012 3:05 PM  1 votes
SS RC Boats
Score: 105
Status: offline
Good posting!
Hide Signatures
(in reply to martno1fan)
       Post #: 3
RE: High Lift or Not? - 11/26/2012 3:17 PM
martno1fan
Score: 221
Status: online
quote:
ORIGINAL: SS RC Boats
Good posting!
Thanks feel free to rate it lol
waveridermouldings
Hide Signatures
(in reply to SS RC Boats)
       Post #: 4
RE: High Lift or Not? - 11/26/2012 4:16 PM
tbaysal2000
Score: 100
Status: offline
quote:
ORIGINAL: martno1fan
Mart
Thanks Mart, I made the same conclusion by logic but then I found the below post which confused me as the owner was finally happy with X460/2, which must be a high lift prop due to "X" rating and 2 blade seemed to be a better choice for him:
http://www.rcuniverse.com/forum/m_11060136/anchors_11060154/mpage_1/key_/anchor/tm.htm#11060154
I have also have a 6717/3 but it is from dasboata with clipped ears for rough water. Owner saw not a big difference with 7015/3 and someone suggested x470/3.
Finally;
I never knew I can rate an answer, so you are the first to get the 5*
Hide Signatures
       Post #: 5
RE: High Lift or Not? - 11/26/2012 5:45 PM  1 votes
w3bby
Score: 120
Last Login: 5/13/2013
Status: offline
Read the post again, X4??/? props are low lift....... Better explanation here.
Ian
Hide Signatures
       Post #: 6
RE: High Lift or Not? - 11/26/2012 6:16 PM  1 votes
martno1fan
Score: 221
Status: online
lol you gave the 5 to ss rc boats wheres mine lol.Props can get confusing ,numbers, letters and all mean dif things from dif prop guys, have fun lol .
Mart
waveridermouldings
Hide Signatures
       Post #: 7
RE: High Lift or Not? - 11/26/2012 7:47 PM
tbaysal2000
Score: 100
Status: offline
quote:
ORIGINAL: w3bby
Yeap, I was totally confused again
And Martno, another 5s for you, I hope I'll get it right this time
Hide Signatures
(in reply to w3bby)
       Post #: 8
RE: High Lift or Not? - 11/26/2012 9:54 PM
martno1fan
Score: 221
Status: online
Better late than never lol.
Did you decide which prop to go with .
waveridermouldings
Hide Signatures
       Post #: 9
RE: High Lift or Not? - 11/26/2012 10:25 PM
tbaysal2000
Score: 100
Status: offline
If 6717/3 and 7015/3 are not big differences, I may try first X460/3.
I remember Randy aka Mistycreekboats building one and he sold it to a customer who won a race after some tune. I'll PM so maybe he can let me know what was the winning combination.
http://www.rcuniverse.com/forum/m_11130559/tm.htm
Hide Signatures
       Post #: 10
RE: High Lift or Not? - 11/27/2012 11:26 AM
MrMikeG
Score: 115
Last Login: 5/19/2013
Status: offline
Never seen a gas boat run a 60mm prop. 65 yes 60 no, (unless it is subsurface)
And I think an X460 anything will have a 3/16th shaft, not 1/4", could be wrong
Hide Signatures
       Post #: 11
RE: High Lift or Not? - 11/27/2012 11:58 AM
tbaysal2000
Score: 100
Status: offline
It was Jackal1983's thread which he confirmed to see the improvement with X460/2:
But suggestions based on logic were as below. So instead of X460, my alternative choice sounds better with X470/3 (by HendricX):
In a 6717 prop (metric-size) the 67 is diameter .. and the 17 is 1.7 pitch-ratio or ;
67 x 1.7 = 113,9mm total throw (moving forward) of the prop.
On the 7015 this is 70 x 1.5 = 105mm total throw.
So your engine will rev higher with the 7015.
Buy a Octura X470/3 (70 x 1.4 = 98mm total throw) and it will even reving higher.
Hide Signatures
(in reply to MrMikeG)
       Post #: 12
RE: High Lift or Not? - 11/27/2012 12:41 PM
martno1fan
Score: 221
Status: online
60 mm is way too small for a gas boat def need 65 and up,for a stock zen id go slightly bigger so a 7015/3,470/3 would work and another would be a 7016/3 and 275/2 .
Mart
waveridermouldings
Hide Signatures
       Post #: 13
RE: High Lift or Not? - 11/27/2012 4:56 PM
goodson
Score: 100
Status: online
I got the best combination of speed and acceleration with a 7015/3 with my WHH M5 Zenoah. The 275 didn't stay as hooked up and the 3 blade carried the bow a little better.
Hide Signatures
       Post #: 14
RE: High Lift or Not? - 11/28/2012 8:55 PM
Jackal1983
Score: 105
Last Login: 5/7/2013
Status: offline
Since i started that thread i will add abit more of an update!
The issue was the engine!!!... It had odd Cases so it was binding up. We sorted this issue and went to the drawing board.
It could turn the x460/2 with ease... it was alot better from standing start to middle of the RPM range but It was a struggle to stop it torque roll with a 2 blader.
So i went to a X460/3 which stopped the roll but still lost the top end!!!
changed to a 6717/3 and i had lots of top end!! But cavatated low down... so we cupped the edges and my god it made a huge diffrence!!!!
I prefer the 3 bladers!
MillPond Models
Hide Signatures
(in reply to goodson)
       Post #: 15
RE: High Lift or Not? - 12/3/2012 3:57 PM
wet a wild
Score: 105
Last Login: 3/8/2013
Status: offline
hi there. trust me on this one. octura x472/2, remove tongue, little back cutt, thinned blades, well b/s and you will have a very good prop for a stock application.
Hide Signatures
(in reply to Jackal1983)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.611RCU1
