Can you fix a bent crank in a DLE111?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Can you fix a bent crank in a DLE111?
Page: [1]
Login
Can you fix a bent crank in a DLE111? - 11/26/2012 1:59 PM
Jagthack
Score: 100
Last Login: 5/19/2013
Status: offline
Hey Guys I have a DLE 111 that has a slight bend in the crank. As I turn to engine over the prop hub moves in and out about 2mm. Is this something that can be fixed or do I have to buy a new crank?
Thanks!
Hide Signatures
       Post #: 1
RE: Can you fix a bent crank in a DLE111? - 11/26/2012 2:30 PM  1 votes
Cyberwolf
Score: 655
Status: offline
Do you mean the crankshaft is moving back and forth 2mm or going up and down 2 MM? Either way it should be able to be fixed, but a person needs to know what there trying to fix first.
_____________________________
If you can''t fix it with a hammer, you''ve got an electrical problem.
Hide Signatures
(in reply to Jagthack)
       Post #: 2
RE: Can you fix a bent crank in a DLE111? - 11/26/2012 2:51 PM
flyinwalenda
Score: 156
Status: offline
If it's moving "in&out" (forwards & backwards) then it may not be  a bent crank but excessive end play(bad bearing, worn case). Does it move in & out if you pull or push on the prop/crank ?  A bent crank typically shows movement "up and down" (runout) while rotating. A bent crank can be fixed but it takes some time and practice to get it right.
Brian Ray
Hide Signatures
(in reply to Cyberwolf)
       Post #: 3
RE: Can you fix a bent crank in a DLE111? - 11/27/2012 12:20 PM
Jagthack
Score: 100
Status: offline
Sorry, it moves up and down. If you pick a spot on the block and watch it as you turn the engine over you can see the gap in that one spot get slightly biger then smaller as it rotates.
Who fixes this kind of thing?
Thank you!
Hide Signatures
(in reply to flyinwalenda)
       Post #: 4
RE: Can you fix a bent crank in a DLE111? - 11/27/2012 1:07 PM
Cyberwolf
Score: 655
Status: offline
PM sent.
Hide Signatures
       Post #: 5
RE: Can you fix a bent crank in a DLE111? - 11/27/2012 1:11 PM
flyinwalenda
Score: 156
Status: offline
There is a moderator on this board (Dave?) who used to straighten crankshafts for glow engines. Not sure if he still does it or would do a larger gas engine.
Brian Ray
Hide Signatures
       Post #: 6
RE: Can you fix a bent crank in a DLE111? - 11/27/2012 4:46 PM
earlwb
Score: 584
Status: offline
Well yes you can usually straighten a crankshaft out.  Usually the method involves using some V-blocks on a press. You first note the high point on the crank. You then clamp the crank down in the V-blocks then use the press to push down on the high spot some, Then retest and repeat as needed.  I do remember some guys using a big brass hammer to straighten a crank end  too. I remember some mnechanics doing this with big Harley engine cranks befgore.  But that requires something to protect the threads on the end and more care of course. With a twin engine, you have a extra long crank that you have to be careful with so that you don't bend it in the middle someplace.
Now then some cranks may be hardened quite a bit and when you go to give it a tweak the end breaks off. Or the threaded part snaps off. But if you have a new crank on order it isn't a tramatic event. So if you can manually straighten out your bent crank it is a big plus and a good feeling you did something good too. So it doesn't really  hurt anything to try to straighten it out.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 7
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Can you fix a bent crank in a DLE111?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
