Changing Battery Packs    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Changing Battery Packs
Page: [1]
[Poll]
one year
  6% (6)
two years
  26% (26)
three years
  34% (33)
unknown
  32% (32)
Total Votes : 97
(last vote on : 12/2/2012 3:05 AM)
(Poll will run till: -- )
Login
Changing Battery Packs - 11/26/2012 8:13 PM
E.N.T.
Score: 100
Last Login: 5/23/2013
Status: online
When do you consider the best time to change your battery packs
aside of finding a non functioning cell. Even though seems to be working
well.
Just to be on the safe side of flying.
E.N.T.
Hide Signatures
       Post #: 1
RE: Changing Battery Packs - 11/26/2012 8:21 PM
gunradd
Score: 120
Status: online
Using A123s when the capacity seems to start dropping I change them. Got one now thats holding much less then the 2300mah it is supposed to hold.
Using lipos same with capacity and I also watch for high cell (IR) Internal resistance.
_____________________________
Loving my Kingtech Turbine!
Hide Signatures
(in reply to E.N.T.)
       Post #: 2
RE: Changing Battery Packs - 11/26/2012 8:25 PM
jason
Score: 111
Status: online
quote:
ORIGINAL: gunradd
I've never seen a 2300 A123 hold 2300. All mine are about 1900 on a 1 amp discharge.
Jason
Hide Signatures
(in reply to gunradd)
       Post #: 3
RE: Changing Battery Packs - 11/26/2012 8:45 PM
gunradd
Score: 120
Status: online
quote:
ORIGINAL: jason
quote:
ORIGINAL: gunradd
Jason
Its holding about 300 mah and its a 2300 pack
Hide Signatures
(in reply to jason)
       Post #: 4
RE: Changing Battery Packs - 11/26/2012 9:10 PM
jason
Score: 111
Status: online
Oh right, i'd say that was knackered
Hide Signatures
       Post #: 5
RE: Changing Battery Packs - 11/26/2012 9:12 PM
Dr Honda
Score: 100
Status: offline
Even with my Tx's... I use a cycler of some kind when I charge... so I have a good idea of the capacity, and the general health of the pack. I voted Unknown since I change them when I notice a loss of capacity.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to jason)
       Post #: 6
RE: Changing Battery Packs - 11/26/2012 9:19 PM
jetnuno
Score: 105
Status: offline
Hi
I have Kokam lipos that I am using for 4 years. They hold fine and charge for 90% of their capacity after 150 flights - 50 cycles in the lipos
I also have some Rhinos that I don't thrust that much. I would say every 2 years for lipos. Our rx system and turbines don't demand too much from them
Regards
Nuno
Hide Signatures
(in reply to Dr Honda)
       Post #: 7
RE: Changing Battery Packs - 11/26/2012 9:20 PM
Kevin_W
Score: 105
Status: offline
When I was running Nicad's and NiMH's I stopped using packs when their actual capacity dropped to less than 90% of their rated capacity.
I switched to A123's last year and have not needed to change out a pack so far. I will be interested in what the consensus is in this thread on when to dump old A123 packs though.
Kevin Whitlow
Texas Jetcat rep
Hide Signatures
       Post #: 8
RE: Changing Battery Packs - 11/26/2012 9:45 PM
BaldEagel
Score: 118
Status: offline
I have some A123's that have been in use for five years and still hold full capacity, mind you I do not change them above 0.5amps and always balance them.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to Kevin_W)
       Post #: 9
RE: Changing Battery Packs - 11/26/2012 10:49 PM
Jgwright
Score: 101
Status: online
I too have some packs that are 5 years old. They still hold a full charge, but mind you I have always been careful to charge at 4 amps and never without a balancer.
John
John Wright
Hide Signatures
(in reply to BaldEagel)
       Post #: 10
RE: Changing Battery Packs - 11/26/2012 11:06 PM
Edgar Perez
Score: 100
Status: offline
Use a cycler... more than 20% loss and they go to non-flying duties.
Hector: get them to me and I can test them for you
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to Jgwright)
       Post #: 11
RE: Changing Battery Packs - 11/27/2012 11:13 AM
pmerritt
Score: 167
Status: offline
I try to change mine once I find them at a crash site.
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
(in reply to Edgar Perez)
       Post #: 12
RE: Changing Battery Packs - 11/27/2012 6:30 PM
phjoker
Score: 100
Last Login: 4/27/2013
Status: offline
quote:
ORIGINAL: Edgar Perez
What type of cycler are you using do discharge??
Pete H
A Happy Jet Central Falcon & Rhino Owner
Hide Signatures
       Post #: 13
RE: Changing Battery Packs - 11/27/2012 6:43 PM
raptureboy
Score: 178
Status: offline
If your using A123 cells then here is some useful info from Hangtimes     http://hangtimes.com/a123_batteries_for_giants_faq.html
Here's an area where A123's are radically different than Nicad or NiMH packs... L
oad Testing A123's in the traditional way is ineffective for determining state of charge... the beasties just don’t 'react' like we expect.. a 1 amp load for 10 seconds will convince somebody not familiar with them that there’s something wrong with the load tester or the pack.. the needle starts to sag after a few seconds with some meters, (resistor impedance values jump up rapidly under the continuous load) and decreasing voltage displayed on the meter usually indicates approaching doom for the resistors, switch & connectors rather than reflecting any useful info on the state of charge for the pack. Continued loading can melt out connectors, meter resistors, switches, etc. ESV 'loading' just doesn't work with A123's in the tried and true sense as the cells are quite happy delivering enough amperage to melt out your gear, even when nearly discharged. Because of the incredibly flat discharge curve and the ability of the cell to deliver massive amounts of current, using a standing voltage level under load to decide when to recharge can lead to a disaster via damage to switches & connectors... Further, when A123's DO go flat, they do so remarkably fast. So, we go to the next question..
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 14
RE: Changing Battery Packs - 11/27/2012 9:06 PM
Edgar Perez
Score: 100
Status: offline
quote:
ORIGINAL: phjoker
FMA PL8
(overkill, but I also got it for high end electric flight)
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to phjoker)
       Post #: 15
RE: Changing Battery Packs - 11/29/2012 9:38 PM
flyinfool1
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Dr Honda
Replacing a perfectly good, and proven pack is actually less safe because you are now introducing an unproven pack that can have a manufacturing flaw just waiting to die.
As long as the cycler says that the battery is doing its job and holding a full charge, it stays in the plane. I have batteries that are over 6 years old and still hold full rated capacity
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 16
RE: Changing Battery Packs - 11/29/2012 10:36 PM
mtnflyer14
Score: 100
Status: offline
Deleted.
< Message edited by mtnflyer14 -- 11/29/2012 11:03 PM >
AW Extra 260/ZDZ Super 80; Elan/K-80; C-ARF Ultra Flash/P-120; YA F-15C/K-140
Hide Signatures
(in reply to flyinfool1)
       Post #: 17
RE: Changing Battery Packs - 11/29/2012 10:53 PM
Dieselman1220
Score: 110
Status: offline
quote:
ORIGINAL: mtnflyer14
What if the age and capacity are okay, but there is a difference in the cells? I have a 6.6v LiFe that shows 3.6v and 3.43v on the cells after charging. My other LiFes are within a couple hundredths. So, is .17v difference between cells too much?
Regards,
Gus
Let em sit on the balancer for a while...I had one doing the same thing 2 hours on the balancer fixed that. Those instructions came from
Andy at electrodynamics.
Joseph K
Hide Signatures
(in reply to mtnflyer14)
       Post #: 18
RE: Changing Battery Packs - 11/29/2012 11:04 PM
mtnflyer14
Score: 100
Status: offline
Thanks, I feel a little stupid here. I am now doing a discharge on the pack to 5.2v and the cells are matched, so I think that a discharge/charge cycle may fix it.
Regards,
Gus
Hide Signatures
(in reply to Dieselman1220)
       Post #: 19
RE: Changing Battery Packs - 11/29/2012 11:30 PM
mr_matt
Score: 116
Status: online
90% capacity and then pitch them.
I use an CBA. This lets you plot the discharge curve over time, lay one curve on the other and you can see the behavior over time.
http://www.westmountainradio.com/product_info.php?products_id=cba4
Works fine for A123 as well.
Matt
Hide Signatures
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
