The Weirdest use of Glow Engines. is this for real?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> The Weirdest use of Glow Engines. is this for real?
Page: [1] 2 3 4   next >   >>
Login
The Weirdest use of Glow Engines. is this for real? - 11/27/2012 12:25 AM
Flight Risk
Score: 108
Last Login: 6/12/2013
Status: offline
Found this contraption on ebay, and can hardly believe the story is true. What would be the advantage, or thinking behind using glow engines to lower flaps on the space shuttle. Evidently it is supercharged, which would probably be needed at the high altitudes. I wonder if any of this actually carried over onto the actual shuttle. Seems like a failure ready to happen.
http://www.ebay.com/itm/EXTREMELY-RARE-NASA-4-FLAT-CYLINDER-1-20-20cc-MODEL-AIRPLANE-SHUTTLE-ENGINE-O-S-/380520049792?pt=US_Character_Radio_Control_Toys&hash=item5898c32c80
Can you think of any other weird uses of model engines?
Rod S
_____________________________
Just Fly It.
Hide Signatures
       Post #: 1
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 1:26 AM
MJD
Score: 125
Last Login: 6/17/2013
Status: offline
A fine example of overcomplexity and gross expenditure to solve a problem that could be dealt with by other means!
I tried to find the car engine powered cordless screwdriver from Tool Time on the 'net with no luck. (I think it was a driver.. been a while).
I try to be pessimistic, but why bother?
Hide Signatures
(in reply to Flight Risk)
       Post #: 2
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 1:31 AM
controlliner
Score: 100
Last Login: 6/18/2013
Status: offline
I call BS. anyone can put NASA stickers on a "machinist project". Why would NASA release such an item? they would have destroyed it rather than let someone have it that easy. It has a walbro carb which probably will not work well with glow fuel. It doesn't have a starting system. how would you turn it over? It would be like trying to push start a car in first gear with the clutch engaged. The RGB would be geared down quite a bit.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
       Post #: 3
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 2:45 AM
Ram-bro
Score: 156
Status: online
well it sold for 4495.00
Hide Signatures
(in reply to controlliner)
       Post #: 4
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 2:56 AM
TFF
Score: 148
Last Login: 6/19/2013
Status: offline
Weird uses? Some WW2 emergency raft ditching equipment had a kite to fly an emergency radio antenna high up so the signal could be heard farther away. For calm days they had a provision, use an ignition model engine mounted to the kite to "blow" it up in the air. Not very successful.
Hide Signatures
(in reply to Ram-bro)
       Post #: 5
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 3:30 AM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
quote:
ORIGINAL: Ram-bro
Not really - apparently, several potential buyers offered 4495 but both were declined. Em, think that the "offers" were from friends of the seller to bait the trap?
Hide Signatures
       Post #: 6
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 3:37 AM
Ram-bro
Score: 156
Status: online
one reason I dont do ZEbay anymore...to many scams
Hide Signatures
(in reply to SeamusG)
       Post #: 7
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 6:05 AM
Flight Risk
Score: 108
Status: offline
I don't know if it's an actual NASA item or not, but it seems well machined. Why in the world use glow engines? Too unreliable, especially vibrating at Mach one or two. A couple good outrunners and lipos would do the job.
Just Fly It.
Hide Signatures
       Post #: 8
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 12:24 PM
earlwb
Score: 599
Status: online
NASA probably did have that engine built to fly a drone at high altitudes for some project they had going on. The supercharger is the key to it as you would need a supercharger to help feed the engine air at higher altitudes.  The supercharger is also difficult to machine as it has to be very tight on the tolerances and rotors inside too.  Using glow plugs is not a problem as they can simply use a onboard glow ignitor system to ensure the glow plugs stay heated up as needed.  Glow plugs wouldn't have the RFI noise emitted off of them like spark plugs and ignition systems would have and thus they would have a more clean radio signal for sending commands and having the drone return data too.
The trick is that NASA wouldn't just build one engine for a project, but they would have several made. So there ought to me more of them out there too.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 9
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 4:09 PM
blw
Score: 655
Status: offline
I saw a Jett 030 where only 4 were made for a research project.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to earlwb)
       Post #: 10
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 4:23 PM
bogbeagle
Score: 148
Status: offline
Lipos ... if available back then... could they handle the low pressure and temperature?
Anyway, that lump looks genuine, to me.
Isn't Nitromethane a sort of "chemical oxygen" ? (is that tautologous?)
That could be handy for an engine in a low-pressure environment.
Hide Signatures
       Post #: 11
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 4:48 PM
Flight Risk
Score: 108
Status: offline
A drone would make more sense than something to do with flaps. But, 20cc to fly a drone? With $20 "toy" engines (1970's)? For the effort they put into this, they could have machined their own engine. I agree running on glow could have some advantages with receiving a clearer signal from a drone, and four engines may keep vibration down. They did have small chainsaw type engines back then which would be easier to modify, and could be run on glow.
Just Fly It.
Hide Signatures
       Post #: 12
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 5:15 PM
ARUP
Score: 144
Status: offline
I can see it now... after the shuttle lands a fella comes out with a bottle of spray cleaner and paper towels (the $50,000 dollar ones) then cleans the castor oil 'goo' off! lol
This reminds me of the story of the high dollar ink pens developed to function in zero gravity. The Russians used pencils... Don't get me wrong for I'm really 'into' this kind of stuff but sometimes you wonder what those nerds are thinking!
Hide Signatures
       Post #: 13
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 5:24 PM
Ram-bro
Score: 156
Status: online
thats why they are called nerds....always thinking about something
Hide Signatures
(in reply to ARUP)
       Post #: 14
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 6:24 PM
Kmot
Score: 168
Status: offline
I have followed this seller on eBay for years. He has had some of the most amazing collectible engines for sale. I am always stunned by his collection he has sold off over the years. If it's from ToysTopHobby I totally believe it.
~Tom~
Hide Signatures
       Post #: 15
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 6:42 PM
Sport_Pilot
Score: 233
Status: offline
IMO its the supercharger that tells me it is a scam.  Just doesn't work with a two stroke engine.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 16
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 6:45 PM
Sport_Pilot
Score: 233
Status: offline
Pencils writing can be erased and smeared.  NASA wanted to review all notes and writing and did not want them to erase it!
Hide Signatures
(in reply to ARUP)
       Post #: 17
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 6:49 PM
Justaddwata
Score: 217
Last Login: 6/16/2013
Status: offline
Chances of this being incorporated into the shuttle as a backup system are somewhere between zero and none. Can only imagine it an april fools joke (maybe at NASA since the listing on e-bay is not April).
Does not take an rocket scientist to see this is about as useless an option as any for any system on any space vehicle. Any other flight control system you know of in space (or aviation) using an internal combustion motor over say, hydraulic, pneumatic, electric, or cable?
One of the better gas boat picture sites - http://imageevent.com/justaddwata
Hide Signatures
       Post #: 18
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 8:40 PM
Flight Risk
Score: 108
Status: offline
quote:
ORIGINAL: Sport_Pilot
There's definately a supercharger on that thing, and I have seen superchargers sold for 2-stroke model engines. In this case it would be needed to bring pressure up to normal ground levels. And there is too much expensive engineering in it to be a scam.
Just Fly It.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 19
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 10:19 PM
Johnny_Zero
Score: 105
Status: offline
Don't really care if it is fake. It is too cool not to like it.
Carl Goldberg Ultimate Brotherhood # 60.
Hide Signatures
       Post #: 20
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 11:08 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: Flight Risk
Just because they sell superchargers for 2-stroke model engines (Namely the RB Innovations unit for RC Cars) doesn't mean they actually work. It might work on a 4-stroke, but probably not likely to work on a 2-stroke this small.
The NASA engine does look cool, but I too doubt it was really made to be used on any space vehicle or anything beyond a model airplane.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 21
RE: The Weirdest use of Glow Engines. is this for real? - 11/27/2012 11:16 PM
jrlingrel
Score: 100
Status: offline
With the budget that NASA has, I can't see them using something as unreliable as a glow engine on a multi million dollar space shuttle,  And, I don't think the shuttle had flaps, only elevons and a split rudder that also acted as a speed brake when it split.  Correct me if I am wrong.
John
Take offs are optional, landings are mandatory.
Hide Signatures
       Post #: 22
RE: The Weirdest use of Glow Engines. is this for real? - 11/28/2012 12:15 AM
flycatch
Score: 118
Status: offline
Engine did not sell according to Ebay records.
Hide Signatures
       Post #: 23
RE: The Weirdest use of Glow Engines. is this for real? - 11/28/2012 1:10 AM
blw
Score: 655
Status: offline
Fancy scientists! We wrote aircraft logbook entries in pencil in the Army. Then again, I always was suspicious of that.
Did the shuttle have flaps?
Coach Pat Dye
Hide Signatures
       Post #: 24
RE: The Weirdest use of Glow Engines. is this for real? - 11/28/2012 2:03 AM
earlwb
Score: 599
Status: online
NASA has built hundreds if not thousands of radio controlled model aircraft over the years. It is much cheaper to flight test a model than a real plane with a pilot inside. NASA also crashed a lot of radio controlled planes too.
AMA # 928076
Hide Signatures
(in reply to blw)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> The Weirdest use of Glow Engines. is this for real?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.422RCU1
