twister xb dont run. make beep sound when press fwd    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> twister xb dont run. make beep sound when press fwd
Page: [1]
Login
twister xb dont run. make beep sound when press fwd - 11/27/2012 12:57 AM
ecologicall
Score: 100
Last Login: 11/30/2012
Status: offline
I buy a twister xb because of the youtube videos and the price.
my cousing use it, I dont know what happend, that the car dont run.
the servo works, the esc looks to be working because the fan is on and have some lights
but, when press fwd or reverse on the controller, the motor instead of moving, it makes a beep sound.
I charge the battery for 4 hours, still nothing
the manual that cames with the car mention nothing about a beep sound
I read several twister xb topics in this forum but none mention the beep sound or motor not working
please advice
Hide Signatures
       Post #: 1
RE: twister xb dont run. make beep sound when press fwd - 11/27/2012 1:16 AM
nitrosportsandrunner
Score: 296
Last Login: 5/24/2013
Status: offline
It kind of sounds like the ESC is not calibrated.
1st, try adjusting the throttle trim on your radio. do this with the buggy turned on, and the wheels off the ground. watch the light on the ESC as you do this. If the throttle trim is not in the right place, then the ESC will not "arm" when turned on.
If adjusting the trim to the right place allows the ESC to arm, then it should begin to function correctly.
If that doesnt help, then you should try to recalibrate the ESC.
Do you have the brushed, or the brushless version? (XB, or XB pro)
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to ecologicall)
       Post #: 2
RE: twister xb dont run. make beep sound when press fwd - 11/27/2012 3:53 AM
ecologicall
Score: 100
Status: offline
is the brushed version
can you point to a link on how to calibrate de esc of a twister?
Iam new in the RC world....
thanks!
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: twister xb dont run. make beep sound when press fwd - 11/28/2012 12:05 AM
ecologicall
Score: 100
Status: offline
the trim in the radio is in the right position, if I move it, then the motor (or something in the car) beeps. When put the trim in the midle again, then the beep stops
Hide Signatures
       Post #: 4
RE: twister xb dont run. make beep sound when press fwd - 11/28/2012 1:44 PM
ecologicall
Score: 100
Status: offline
i found a video on how to calibrate
http://www.youtube.com/watch?v=_OkwkziFWE8
but, the twister esc does not have a button
is lansu brand as same as the control
question 1. how to calibrate it without a button
question 2. do the car supose to move if I pushed with hand? because is not doing it.
question 3. is there a posibiliti the motor is lock up, how to unlocked and if it is covered by waranty?
thanks
Hide Signatures
       Post #: 5
RE: twister xb dont run. make beep sound when press fwd - 11/28/2012 2:57 PM
Score: 296
Status: offline
quote:
ORIGINAL: ecologicall
thanks
the video you found is one I made
But thats for the ezrun brushless ESC.
Usually, if a ESC doesnt have a button, you make it go into calibration mode by holding full throttle when you turn the model on.
Hold full throttle when turning it on...it should beep several times.
Keep holding till it stops beeping, then when the beeps stop, go full brake....wait till it stops beeping and then let go of the throttle trigger...it will beep some more as it locks in neutral.
Wait a few more seconds, then it should be good to go.
I am 90% sure thats the calibration proceedure.
If the motor was locked up...then you wouldnt hear any beeps. The beeping is actually the ESC pullsing the motor.
you say the model will not roll on the ground if you push it? There will be some drag, from a brushed motor. But the wheels should roll when you push the model on the ground.
Are you pushing it with the power on....or off?
If you only recently bought the model, it is warrentied by redcat (all electronic parts anyway)
Hide Signatures
       Post #: 6
RE: twister xb dont run. make beep sound when press fwd - 11/28/2012 11:50 PM
ecologicall
Score: 100
Status: offline
for the waranty, I have to ship the whole car?
i did what you said, press full throttle then turn teh car on, wait about 15 sec the beeps never stops, but the motor heats a lot so I just turn it off again
in the floor, neither on or off, it dont move when pushing it
Hide Signatures
       Post #: 7
RE: twister xb dont run. make beep sound when press fwd - 11/29/2012 12:04 AM
Score: 296
Status: offline
I see. the motor heating up and it not rolling on the ground means there is an issue. Not sure if its the motor or the ESC tho.
Do you have another motor you could plug into the esc? Doing so could show where the problem is.
Sometimes redcat wants the whole model shipped back for warrenty, but if they know based on the issue what the defective part is, then they will sometimes jsut send the part.
If I were there, I could take a spare esc and motor I have and figure out in minutes what the problem is. But over the internet I cant say.
So you should fill out the warrenty form, and describe the issue as you have here...as well as what you have tried to fix it.
warrenty form: http://www.redcatracing.com/Warranty-Form
Hide Signatures
       Post #: 8
RE: twister xb dont run. make beep sound when press fwd - 11/30/2012 4:55 AM
ecologicall
Score: 100
Status: offline
thanks for your help!
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.555RCU1
