New Digital Gear System Failsafe    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> New Digital Gear System Failsafe
Page: [1]
Login
New Digital Gear System Failsafe - 11/27/2012 7:47 PM
lov2flyrc
Last Login: 5/17/2013
Status: offline
Our new digital Gear System Failsafe is now available!!
Our new Digital Failsafe is a must have device if you are using Pneumatic driven landing gear. This small apparatus monitors air pressure, and should it fall below a user preset value (30-90psi), the landing gear are automatically lowered before all the air bleeds out of the system. The Failsafe will work with servo driven retract valves as well as electronic valves. Installation is a snap with simple, intuitive programming. Absolutely the finest Gear Failsafe available!
Features:
● 16mm x 10mm LCD Display Screen
● Accurate Air Pressure Display
● Programmable Failsafe Trigger Value
● Compatible with 2.4 Ghz Radio System
● Intuitive and simple programming
● Four Pressure Unit Selection PSI / Kg-cm2 / BAR / Kpa
Specification:
● Operating voltage: 4.8~7.4 Volts DC
● Operating pressure range: 0~125psi
● Air Pressure accuracy: ± 1 %
● Temperature range: -10 to +75 °C
● Dimensions: L 64 x W 30 x H 14 mm
● Weight: 29 g. (incl. mounting plate)
Includes:
Digital Failsafe Module
6" Male to Male Radio Lead
M3 Barbed Airline Fitting
Instruction Sheet
< Message edited by lov2flyrc -- 11/28/2012 2:55 PM >
_____________________________
Todd Witkoff
Dreamworks Model Products LLC
www.dreamworksrc.com
Your Source For RC Jet Accessories!
Hide Signatures
       Post #: 1
RE: New Digital Gear System Failsafe - 11/28/2012 1:59 AM
KFX450
Last Login: 5/7/2013
Status: offline
Love it..I'll be ordering one when I figure out what my next winter project is..
Hide Signatures
(in reply to lov2flyrc)
       Post #: 2
RE: New Digital Gear System Failsafe - 11/28/2012 3:21 AM
smchale
Last Login: 5/18/2013
Status: online
Todd,
How does something like this handle landing gear doors? Ie. if your doors are set up on a separate system (its own tank, valve, etc) with a sequencer does it detect the pressure in the retracts and then send a signal to the sequencer to start the normal deployment sequence?
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to KFX450)
       Post #: 3
RE: New Digital Gear System Failsafe - 11/28/2012 4:36 AM
DiscoWings
Status: offline
more than likely it simply sends a signal to the channel ie. deploy the gear so I don't think it matters what complicated gear door mech or gears you may have setup.
E.G. pressure falls below 50 psi, send signal to RX to deploy the gear.
So basicaly you wire it like this;
1, Gear Signal wire from your servo or electronic valve goes into the dreamworks air fail safe input.
1, Output from the dreamworks air fail safe goes into the Gear channel on your rx.
This basically sets it so that the air fail safe controls the gear channel
"Hi,You are 100% correct but are also 100% wrong... "
- rcflip
Hide Signatures
(in reply to smchale)
       Post #: 4
RE: New Digital Gear System Failsafe - 11/28/2012 4:45 AM
husafreak
Status: offline
Sweet. Great product. I have a prototype electronic gearsafe with digital readout in my Electra, maybe it will be released for sale maybe not. I will refrain from posting the brand out of respect. But suffice it to say I will be using a low pressure gear safe from now on having experienced its usefulness on flight 30. If you ever retract your gear only to see it pop back down a few seconds later it will have paid for itself!
Hide Signatures
       Post #: 5
RE: New Digital Gear System Failsafe - 11/28/2012 6:12 AM
CARS II
Status: offline
Love it! price is good too, I will be getting one for the airplane I'm building ( winter project )
CARS II
Go fly a Jet today.
Hide Signatures
(in reply to husafreak)
       Post #: 6
RE: New Digital Gear System Failsafe - 11/28/2012 1:37 PM
lov2flyrc
Status: offline
quote:
ORIGINAL: smchale
Todd,
This unit goes between your RX and whatever device you wish to control failsafe on; be it a valve, servo or sequencer. I will simply trigger a gear down signal when pressure falls below the user preset value.
Todd
Todd Witkoff
Hide Signatures
       Post #: 7
RE: New Digital Gear System Failsafe - 11/28/2012 2:23 PM
ela
Status: offline
It's a pity many of us will need to buy two, one for the doors an one for the retracts. And if it will work when using two will propably wary.
For the second generation we would like it in be a two channel failsafe with a slight delay betwen the two. Just some thoughts :-)
But of course its better to ruin some gear doors than other things on the plane :-)
Ela
Hide Signatures
       Post #: 8
RE: New Digital Gear System Failsafe - 11/28/2012 2:30 PM
sailing1
Status: offline
I know it isn't the proper order but won't the gear just push the doors out of the way when coming down under failsafe. I don't have any jets with complicated doors but on my F-16 that is what happens.
Hide Signatures
(in reply to ela)
       Post #: 9
RE: New Digital Gear System Failsafe - 11/28/2012 2:48 PM
lov2flyrc
Status: offline
Not sure I follow Gentleman...
If you have gear doors, then you have a sequencer driving the timing. The failsafe would be placed between the RX and the sequencer. Should a failsafe trigger occur, the gear down signal is sent to the sequencer and your normal gear/door down sequence is activated. No need for two units!?
Todd Witkoff
Hide Signatures
(in reply to sailing1)
       Post #: 10
RE: New Digital Gear System Failsafe - 11/28/2012 2:58 PM
lov2flyrc
Status: offline
Just a correction;
Operating voltage is from 4.8~7.4V.
We upped the voltage on the production model, 6.8V max was prototype voltage.
Todd Witkoff
Hide Signatures
       Post #: 11
RE: New Digital Gear System Failsafe - 11/28/2012 3:06 PM
HarryC
Status: online
quote:
ORIGINAL: lov2flyrc
Not if you use sequencing in the tx or rx or powerbox etc etc. Most of my models use sequencing in the tx driving 2 separate channels, though my programmable rx can also do sequencing using 1 channel from tx and splitting it out to 2 servos. I believe some powerbox products can do the same.
Hide Signatures
       Post #: 12
RE: New Digital Gear System Failsafe - 11/28/2012 7:39 PM
essyou35
Status: offline
if a power box does sequencing, then you have an TX channel going IN to the power box, the failsafe plugs into the powerbox INPUT and then the TX channel into the Failsafe.
If you use the radio to do your sequencing, which I think only 1 or 2 radios can do that... so you will have to buy two thought not sure if that is wise given they wont sequence.
Personally using a seuqencer is the best option as you can control the doors and gears on 1 channel.
I personally use the UP3 valve. Much better valve than the robart type stuff.
At $82 these are a good deal, a pressure transducer alone is over $60 from my research of building my own, otherwise I would of.
I am currently running my jet without one and will be adding this ASAP. I saw a jet land with gears up on the runway, perfect landing and it still messed it all up.
Hide Signatures
(in reply to HarryC)
       Post #: 13
RE: New Digital Gear System Failsafe - 11/28/2012 11:52 PM
mr_matt
Status: offline
Digikey has freescale pressure sensors about 10 bucks each. Even if you rigged this yourself it would cost almost as much overall and be 5x the size and 1/10 the reliability!
Matt
Hide Signatures
(in reply to essyou35)
       Post #: 14
RE: New Digital Gear System Failsafe - 12/17/2012 11:58 AM
phantom_najd
Last Login: 5/16/2013
Status: offline
Great product Todd and reasonable price. Just ordered 3 ... Thanks man!
Azzam
Hide Signatures
(in reply to mr_matt)
       Post #: 15
RE: New Digital Gear System Failsafe - 12/17/2012 2:12 PM
Carsten Groen
Status: offline
quote:
ORIGINAL: essyou35
Not if you use SBUS (serial) receivers directly into one of Powerbox's SRS products
Carsten Groen
Hide Signatures
       Post #: 16
RE: New Digital Gear System Failsafe - 12/18/2012 3:00 AM
S HARRIS
Last Login: 5/14/2013
Status: online
Hey guys this thing works but you should be cautious when installing. Ablsolutley have your retract servo disconnected when programming (unless travel is equal on both sides). Also it will only program in one direction (gear down lower pw and up is higher) so you may have to replumb or flip linkage around. Otherwise works flawslessly!! I'll make video if enough interest on programming it. Thanks Todd! Wish I would have had one on my bandit . Scott
< Message edited by S HARRIS -- 12/18/2012 4:05 AM >
If it works use it,USA JWM TEAM MEMBER
Hide Signatures
(in reply to Carsten Groen)
       Post #: 17
RE: New Digital Gear System Failsafe - 12/18/2012 7:33 AM
phantom_najd
Status: offline
quote:
ORIGINAL: S HARRIS
A video would be great Thanks in advance.
Azzam
Hide Signatures
(in reply to S HARRIS)
       Post #: 18
RE: New Digital Gear System Failsafe - 12/19/2012 4:17 AM
S HARRIS
Status: online
I'll see what I can do. Scott
Hide Signatures
(in reply to phantom_najd)
       Post #: 19
RE: New Digital Gear System Failsafe - 12/19/2012 5:31 PM
RSO
Status: online
Would appreciate a video also Scott.
Jerry
Hide Signatures
       Post #: 20
RE: New Digital Gear System Failsafe - 1/21/2013 12:45 PM
SkyKnight
Status: offline
I just bpught one of theswe units.  Any field updates or videos yet?
SK
~JetCat USA Rep.
Hide Signatures
(in reply to RSO)
       Post #: 21
RE: New Digital Gear System Failsafe - 1/21/2013 2:03 PM
phantom_najd
Status: offline
quote:
ORIGINAL: SkyKnight
I have one installed on my jet and luckily I didn't need the fail-safe feature yet
I, however, have tested it on the bench and it works flawlessly. Setting it up is really very easy. All you need to do is set the travel on your radio (if it is a servo) then hook this unit between the servo lead and the receiver. You then follow the (very clear) instruction paper that comes with the unit to set it up. The device reads the pulse width rate of the gears switch on the DOWN and UP positions (just like the ECU learn feature).
Azzam
Hide Signatures
(in reply to SkyKnight)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.314RCU1
