fuel lines on top of tank (gas)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> fuel lines on top of tank (gas)
Page: [1] 2   next >   >>
Login
fuel lines on top of tank (gas) - 11/27/2012 11:05 PM
handyman
Score: 111
Last Login: 3/28/2013
Status: offline
looking over some pics and i see set ups with extra fuel lines on top of tanks..........why?
Hide Signatures
       Post #: 1
RE: fuel lines on top of tank (gas) - 11/27/2012 11:18 PM
JohnBuckner
Score: 342
Last Login: 5/19/2013
Status: offline
Could you explain as little further as to what type of airplanes you saw and what kind of engines, were the fuel tanks exposed?
_____________________________
"Keep your controllines tight"
Hide Signatures
(in reply to handyman)
       Post #: 2
RE: fuel lines on top of tank (gas) - 11/27/2012 11:25 PM
flyinwalenda
Score: 156
Status: offline
Perhaps re-post those pics or post links to them.
Brian Ray
Hide Signatures
(in reply to JohnBuckner)
       Post #: 3
RE: fuel lines on top of tank (gas) - 11/28/2012 12:14 AM
dant-RCU
Score: 100
Last Login: 5/18/2013
Status: offline
Most likely it is the tank vent line. A loop at the top prevents fuel from being syphoned from the tank.
Since the vent is open to the atmosphere and not pressurized (as in muffler pressure from a glow engine)
most of us use this method of hook up. Usually the line is then routed out the bottom of the fuse.
Dan
Dan Taylor
American Turf Flyers, Inc.
Hide Signatures
       Post #: 4
RE: fuel lines on top of tank (gas) - 11/28/2012 1:46 AM
Gray Beard
Score: 314
Status: offline
Pretty much what Dan said. It's how I set up the gas tank in my gas powered planes. It just keeps the gas from sloshing out. I usually run about two or three loops on the vent line on the top of the tank then vent out the bottom.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to dant-RCU)
       Post #: 5
RE: fuel lines on top of tank (gas) - 11/28/2012 2:57 AM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: handyman
The reason you see allot of fuel tanks with several loops of vent line is simple; improper setup, you don't see this in full scale and there is a reason. Take a look under most R/C airplanes and you will see a fuel line hanging down and in many cases swayed back from and during flying, this causes the the shaken fuel during flight to be scavenged from the vent line during flight because the air rushing past the aft facing vent line creates a vacuum effect and pulling out whatever fuel it can. Remedy: shorten the flexible vent line or go with a hard line and scarf a 45 degree angle facing forward to the airflow just like we did in the old U-Control Airplane fuel tank days, this will add a slight positive pressure to the vent and take care of the problem and you can leave all that fuel line on the ground while your flying.
Bob
Fly It Like You Stole It!!!
Hide Signatures
       Post #: 6
RE: fuel lines on top of tank (gas) - 11/28/2012 3:37 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: sensei
quote:
ORIGINAL: handyman
Bob
true, but you forget one thing... If your vent line is forward of the fuel tank (for whatever reason) and you nose the airplane over, the fuel will drain out of the vent. Putting a loop of line to go aft of the tank and then to the vent will prevent this from happening.
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to sensei)
       Post #: 7
RE: fuel lines on top of tank (gas) - 11/28/2012 6:37 AM
Ernie Misner
Score: 130
Last Login: 5/17/2013
Status: offline
It's usually a loop around the tank, then down and out for the vent line. This is a vent, no pressure on gasser tanks, and the loop is simply to keep gas from running out and making a dangerous mess when you turn the plane over inverted. That wouldn't be good at all.
Hide Signatures
(in reply to invertmast)
       Post #: 8
RE: fuel lines on top of tank (gas) - 11/28/2012 11:57 AM
sensei
Score: 176
Status: offline
LOL,
I am talking about loosing fuel during flight guys. This loop thing really started from guys flying IMAC and needing all the fuel to get through the double pattern and back on the ground, so they do not wish to loose any fuel in the air. I don't see many 50cc-50% airplanes standing on there noses or laying on their backs, and if for some reason you need to service your airplanes while on the nose or on its back, just remove the fuel. Again this is an issue during flight...
Bob
< Message edited by sensei -- 11/28/2012 12:34 PM >
Hide Signatures
(in reply to Ernie Misner)
       Post #: 9
RE: fuel lines on top of tank (gas) - 11/28/2012 6:08 PM
handyman
Score: 111
Status: offline
saw it in a few pics on here,,,,seems to be a long loop across the top of the tank
Hide Signatures
       Post #: 10
RE: fuel lines on top of tank (gas) - 11/28/2012 7:24 PM
BarracudaHockey
Score: 280
Status: offline
Its been said correctly a few times, it keeps the vent pipe which is at the top of the taank, from draining the tank while the plane is flying inverted.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 11
RE: fuel lines on top of tank (gas) - 11/28/2012 7:50 PM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: sensei
LOL,
Bob
Allot/most of the 1/5 50cc warbirds have a one piece wing and are routinely on the nose or backs for servicing/installation, and for those who still use a bulb pump, they may decide not to remove the fuel from there tanks at the end of the day. For me, i personally like to keep a bit of fuel in the tank and lines to gravity feed to the carb to keep the diaphragms most. That may or may not be happening, but it gives me a lil piece of mind
For turbines, its not as easy to remove the fuel at the end of the day every time, and since we typically run external start and taxi tanks to maximize flight time, we need to be able to get to the vent fitting. On some models (eurofighters, rafale's, etc) its not feasible to put the vent fitting aft of the tanks bc then you could not get to it to hook up and remove the external tank.
So to say it is (generally) a improper setup isnt completely true for every case.
Thomas W.
Hide Signatures
       Post #: 12
RE: fuel lines on top of tank (gas) - 11/28/2012 8:11 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: sensei
quote:
ORIGINAL: handyman
Bob
Hey guy, I don't see many full scale airplanes flying inverted do you? Worse yet, flying inverted and pushing significant g's. That will force fuel out the vent and into the air, every time. Full scale airplanes that do fly that way, for example aerobats and military, are set-up differently than your average common Cessna.
We don't set-up our tanks improperly; we demand that the fuel stay put regardless of what attitude we place the model in
To the OP, we are beginning to see more and more water bottle gas tanks fitted with fittings rather than a stopper, to avoid leaking stoppers. Fittings, like the types I sell, are installed at the top of the water bottle in addition to the cap of the bottle....the cap takes the carb feed line, aka, the clunk line, and the one or two fittings on the top of the tank are the vent and the fill fittings...Hope that helps
Regards,
MattK
Hide Signatures
       Post #: 13
RE: fuel lines on top of tank (gas) - 11/28/2012 10:30 PM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: BarracudaHockey
Or held by the stab and being pushed to the flight or start up area. As for scavenging fuel out the line? I haven't seen it happening to any of my RC planes but it could happen.
Just another little thing not to dwell on or over think. The looped vent line is just something most people do but I like the idea sensei brought up. If nothing else it would be a cleaner look.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 14
RE: fuel lines on top of tank (gas) - 11/28/2012 10:47 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: sensei
quote:
ORIGINAL: handyman
Bob
I run my vent lines on the top of my clear tanks and then out the fuse on the bottom and I have never had an issue with the fuel vacuum effect. As a matter of fact, all the guys I fly gas with have similar vent setups without the above mentioned issue. My setup works great and I don't have a problem with siphoning fuel through the vent. Maybe some guys are plumbing the setup wrong or something.
Hide Signatures
       Post #: 15
RE: fuel lines on top of tank (gas) - 11/28/2012 11:00 PM
sensei
Score: 176
Status: offline
quote:
ORIGINAL: MTK
quote:
ORIGINAL: sensei
quote:
ORIGINAL: handyman
Bob
I have seen guys use up to 18" of line looping it around, and everything adds weight so when I made the statement of improper setup; if your adding extra weight to correct another problem then to me... But that is just me, I will always search for the lightest functional option I can go with as a solution. Now once again when you 45 degree forward scarf the the vent line the fuel does not come out even inverted as long as the airplane is moving forward because there is positive pressure on the line. Anyway do as you please.
Bob
< Message edited by sensei -- 11/28/2012 11:45 PM >
Hide Signatures
(in reply to MTK)
       Post #: 16
RE: fuel lines on top of tank (gas) - 11/28/2012 11:07 PM
lrglnman
Score: 100
Last Login: 2/11/2013
Status: offline
Most weedeaters use a 1 way valve to prevent extra gas from coming out. there is a supply line to the carb, a return and a vent. why cant we use the vent like on most weedeaters ? u can turn a weedeater upside down with no ill results.
The Large Lineman
James Smith
Hide Signatures
       Post #: 17
RE: fuel lines on top of tank (gas) - 11/28/2012 11:12 PM
handyman
Score: 111
Status: offline
i thought the same thing,,air gos in and gas wont come out if turned up-side-down
Hide Signatures
(in reply to lrglnman)
       Post #: 18
RE: fuel lines on top of tank (gas) - 11/29/2012 12:59 AM
FlyinTiger
Score: 105
Status: offline
You'll need an open vent of some kind if you ever fly during a temperature change (everyone does). As it warms up throughout the day (or in your trailer/shop/storage area) and you don't have a vent line that allows air OUT of the tank you'll pop a stopper, tank seam or the cap off the threads of a water bottle tank. Weed eaters have vent lines or vented caps that allow atmospheric changes to relieve the pressure in tanks.
Some portion of your fuel line needs to be higher than the highest point in the tank, or you will siphon fuel out onto the ground after your tank is full. Loop of fuel tubing or just a little rise in the line before going down and out of the bottom of the fuselage.
Fuel all over the ground is not good for the pavement/grass at your field, nor for flying...you might run out of gas before you think. This has caused several dead sticks at events in the heat of the Summer.
Albert Hibpshman
Hide Signatures
       Post #: 19
RE: fuel lines on top of tank (gas) - 11/29/2012 1:15 AM
warbird addict
Score: 159
Status: offline
Speaking of one way valves , I picked up a 33% extra from a guy and he had installed a really nice aluminum check valve on the vent line, I subsequently raped the gear out of that plane and installed it in my big H-9 pawnee along with that check valve and it works awsome, I stood the plane on it's nose with a full tank and it never lost a drop thru the vent
Don't know who makes the check valve or where to get it LOL the only concern I have with it is if it ever gets stuck shut it will be some bad Joo Joo for sure LOL
"Q" If you could have one super power what would it be?
"A" The ability to leap tall blondes without them screaming
Hide Signatures
       Post #: 20
RE: fuel lines on top of tank (gas) - 11/29/2012 1:42 AM
sensei
Score: 176
Status: offline
For my style of flying I don't think I would want to have a one way check valve in my vent line, too me it is another critical point of failure waiting to happen at the wrong time, slow low, and maybe vertical with 0 airspeed. Have you ever had a one way check valve stick on you in any application before? It happens from time to time and all it needs is a tiny piece of junk in the fuel/gas to make it stick.
Bob
Hide Signatures
(in reply to warbird addict)
       Post #: 21
RE: fuel lines on top of tank (gas) - 11/29/2012 2:20 AM
Gray Beard
Score: 314
Status: offline
All YS engines use a check valve and you can get them from Central Hobbies or YS Service. A one way valve will need to be removed before filling the gas tank. Sounds like more work then useful.
Hide Signatures
       Post #: 22
RE: fuel lines on top of tank (gas) - 11/29/2012 2:59 AM
sensei
Score: 176
Status: offline
I know they do but I still would never put one in any of my big gassers. Maybe it's just me.
Bob
Hide Signatures
(in reply to Gray Beard)
       Post #: 23
RE: fuel lines on top of tank (gas) - 11/29/2012 4:33 AM
Gray Beard
Score: 314
Status: offline
That was a reply to post 21 and no one is asking you to.
Hide Signatures
       Post #: 24
RE: fuel lines on top of tank (gas) - 11/29/2012 5:03 AM
DGrant
Score: 140
Last Login: 5/11/2013
Status: offline
Wow.. record thread on a little vent line question. I had no idea there was so much info on ..... wait.... what was the question again?
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
