DX7s throttle reversed, trim wont work    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> DX7s throttle reversed, trim wont work
Page: [1] 2   next >   >>
Login
DX7s throttle reversed, trim wont work - 11/28/2012 3:32 AM
MikeEast
Score: 115
Last Login: 3/29/2013
Status: offline
Hi all,
I just bought a new DX7s and for some reason the trottle trim works perfectly when the throttle action is normal, but when I reverse the throttle action in the transmitter, the throttle trim does not work, not at all. I need to be able to reverse the throttle to get what I need in my setup. All due respect I am very experienced at setting up planes and I am familiar with RC electronics, so I dont need any additional help. Im just curious if anyone else has experienced and solved this little glitch that I cannot figure out in the transmitter. I called horizon and they could not explain it or offer a solution.
Thanks in advance for your insight.
Mike
_____________________________
Mike East
AMA 793948
Back to square one . :)
Hide Signatures
       Post #: 1
RE: DX7s throttle reversed, trim wont work - 11/28/2012 5:14 AM
A.T.
Score: 181
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: MikeEast    Hi all,
I called horizon and they could not explain it or offer a solution.   Thanks in advance for your insight.  Mike
"I am familiar with RC electronics, so I dont need any additional help"
Given that you do not want a response with explanation on this forum,
suggest you correspond with the Spekrum TX firmware designer direct:
Andy Kunz
or you may find an explanation under sub section:
"Radio Systems, Accessories, Alterations and FAQ"   below
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
R/C hobby consultant for various companies
Hide Signatures
(in reply to MikeEast)
       Post #: 2
RE: DX7s throttle reversed, trim wont work - 11/28/2012 5:18 AM
alan0899
Score: 100
Last Login: 5/12/2013
Status: offline
G'day Mike,
What I get from your question is that you reversed the throttle action, so full throttle, is all the way DOWN, & Idle is all the way UP.
In this configuration, throttle trim would also be reversed, so slower idle would be full UP on the trim.
Is that correct?
Is this what you wanted to do?
Or did you just want to reverse the throttle servo?
Cheers
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
Allan.
Hide Signatures
       Post #: 3
RE: DX7s throttle reversed, trim wont work - 11/28/2012 6:38 AM
BuschBarber
Score: 104
Status: online
quote:
ORIGINAL: MikeEast
Hi all,
Mike
Throttle Trim only works near Idle(when the Throttle Stick is closer to the bottom of the Tx) and not over the entire range of the Throttle Stick movement. The physical position of the Throttle Stick affects the Throttle Trim, not the direction of the servo. If you Reverse the channel such that Idle is set when the Throttle Stick is pushed Up towards the Tx antenna, the Throttle Trim has no affect at that end.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 4
RE: DX7s throttle reversed, trim wont work - 11/28/2012 2:05 PM
AndyKunz
Score: 116
Last Login: 5/23/2013
Status: online
quote:
ORIGINAL: MikeEast
Hi all,
Mike
Since you're experienced, you know that throttle trim only works on the lower half of throttle travel, and that it is added in as a function of its displacement from center.
That should be all the non-help you need to understand why your change doesn't work as you expected.
Andy
Andy Kunz - AMA 46063
Spektrum Development Team
Hide Signatures
       Post #: 5
RE: DX7s throttle reversed, trim wont work - 11/28/2012 5:04 PM
pilotpete2
Score: 120
Status: offline
Mike,
Are you saying that you want the the throttle channel to be at idle with the throttle stick at the full up position?
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
       Post #: 6
RE: DX7s throttle reversed, trim wont work - 11/28/2012 7:35 PM
BarracudaHockey
Score: 280
Status: offline
No, sounds like he reversed the throttle channel and the trim quit working.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to pilotpete2)
       Post #: 7
RE: DX7s throttle reversed, trim wont work - 11/28/2012 8:34 PM
rmh
Score: 252
Status: online
Place yer bets
Libby is still watching you
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 8
RE: DX7s throttle reversed, trim wont work - 11/28/2012 9:15 PM
pilotpete2
Score: 120
Status: offline
Reason I asked was because some folks do fly with the throttle stick reversed. The Futaba computer radios I've owned have that option in the system menu, but it also reverses the trim, so the trim works when the stick is fully up for idle and all mixing and curves work normally. Futaba calls it reverse throttle.
Pete
Hide Signatures
       Post #: 9
RE: DX7s throttle reversed, trim wont work - 11/28/2012 9:26 PM
daytonarc
Score: 100
Status: online
quote:
ORIGINAL: AndyKunz
[Since you're experienced, you know that throttle trim only works on the lower half of throttle travel, and that it is added in as a function of its displacement from center.
Andy
Hide Signatures
(in reply to AndyKunz)
       Post #: 10
RE: DX7s throttle reversed, trim wont work - 11/28/2012 10:18 PM
MikeEast
Score: 115
Status: offline
Lol, I knew it, you guys are a trip still after a few years away
I went into the tx servo setup for throttle and changed the Norm/rev option to Rev. Simple basic throttle setup decision in the radio. Ive had 10 different computer radios and I have had lots of planes where I had to set the throttle to reverse in the tx so that the throttle opens when you push up onthe stick.. The trim has never failed to function in my old DX7 or any of my other JR or Futaba computer radios.Regardless of whether normal or reverse setting. For some reason In this DX7s, after selecting reverse, The trim no longer worked.
Mike East
AMA 793948
Hide Signatures
(in reply to daytonarc)
       Post #: 11
RE: DX7s throttle reversed, trim wont work - 11/28/2012 10:23 PM
MikeEast
Score: 115
Status: offline
quote:
ORIGINAL: BarracudaHockey
Right.
Mike East
AMA 793948
Hide Signatures
       Post #: 12
RE: DX7s throttle reversed, trim wont work - 11/28/2012 11:15 PM
ira d
Score: 123
Status: online
It is obvious to me that something is wrong with your DX7, I wonder why Horizon and Andy cant see that?
Ira d
Hide Signatures
       Post #: 13
RE: DX7s throttle reversed, trim wont work - 11/28/2012 11:20 PM
larryak
Score: 105
Last Login: 3/24/2013
Status: offline
I,m glad Libby is watching because we sure like her beautiful picture.
Hide Signatures
       Post #: 14
RE: DX7s throttle reversed, trim wont work - 11/28/2012 11:38 PM
MikeEast
Score: 115
Status: offline
quote:
ORIGINAL: ira d
If so that's okay... I just thought maybe someone else had this issue and there is
Something in the TX setup I am overlooking.
Mike East
AMA 793948
Hide Signatures
(in reply to ira d)
       Post #: 15
RE: DX7s throttle reversed, trim wont work - 11/28/2012 11:56 PM
pilotpete2
Score: 120
Status: offline
Mike,
Have you tried an unused model memory, one where everything is at default to see if reversing the throttle servo results in the trim not working?
Pete
Hide Signatures
       Post #: 16
RE: DX7s throttle reversed, trim wont work - 11/29/2012 12:02 AM
MikeEast
Score: 115
Status: offline
quote:
ORIGINAL: pilotpete2
Mike,
Pete
I did. That was also the suggestion I got from the horizon tech rep. We tried it,,,, same problem on a different model with no programming changes except throttle reverse .
Mike East
AMA 793948
Hide Signatures
       Post #: 17
RE: DX7s throttle reversed, trim wont work - 11/29/2012 2:20 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: MikeEast
Hi all,
Mike
I just tested it on my DX7s and the trim works perfectly when the throttle is reversed.  What firmware is your radio? Mine is 1.01.
..... frakkin cylons...
Hide Signatures
       Post #: 18
RE: DX7s throttle reversed, trim wont work - 11/29/2012 2:30 AM
MikeEast
Score: 115
Status: offline
quote:
ORIGINAL: Rob2160
quote:
ORIGINAL: MikeEast
Hi all,
Mike
If you are referring to the number beneath export on the serial number page, it's 1.00.
Mike East
AMA 793948
Hide Signatures
(in reply to Rob2160)
       Post #: 19
RE: DX7s throttle reversed, trim wont work - 11/29/2012 2:37 AM
MikeEast
Score: 115
Status: offline
< Message edited by MikeEast -- 11/29/2012 3:16 AM >
Mike East
AMA 793948
Hide Signatures
       Post #: 20
RE: DX7s throttle reversed, trim wont work - 11/29/2012 3:00 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: MikeEast
quote:
ORIGINAL: Rob2160
Yes, that is the one.
Try updating your firmware.  Just noticed they are up to 1.03 for the DX7s.
This could solve your problem..
PS.. I could be mistaken on exact details but I think my DX8 had an odd trim behaviour when new which was corrected with by a later firmware update.
I'll have to research these latest updates.. I don't really understand what the sub trim changes are.. IE
Automatically corrects sub-trim and travel for models created in version 1.01 and
earlier after prompting the user.
What exactly does it auto correct Andy?
I have 20 models in my DX7s and 4 helis that each use a bit of subtrim..
How much "re trimming" will I need if I update to 1.03 vs 1.01?
The radio works perfectly now but I like the idea of dimming the LED and adjusting inactivity timer...
Hide Signatures
       Post #: 21
RE: DX7s throttle reversed, trim wont work - 11/29/2012 3:15 AM
lourod996
Score: 105
Last Login: 5/9/2013
Status: offline
Sell it get a Futaba.... Youll never have any issues...
Hide Signatures
       Post #: 22
RE: DX7s throttle reversed, trim wont work - 11/29/2012 3:26 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: lourod996
Totally incorrect statement..
I have a Futaba 8FG also, started with Firmware 2.0, upgraded to 3.0, fixed some bugs..
Upgraded to 4.0, which introduced a bug, so 4.1 arrived .
Now up to 5.0 and all seems to be working well..
Like Spektrum the firmware upgrades usually add extra functionality too... which is a good thing.
I have a 6EX Futaba that has developed minor faulty centering on the aileron channel.. Under 200 flights on this radio..
Not to mention the Zero GUID problem (yes I know it was a long time ago.. but just shows Futaba is not Perfect either. )
Info here.. many Futaba radios were recalled and needed fixing..
http://www.rcgroups.com/forums/showthread.php?t=803207
Hide Signatures
(in reply to lourod996)
       Post #: 23
RE: DX7s throttle reversed, trim wont work - 11/29/2012 4:41 AM
Tluu
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: lourod996
Why is it that anytime someone has a question about a problem on their spektrum radio....someone comes in and says get a futaba. I've been flying spektrum and JR system for over 6 year without problem.
Hide Signatures
       Post #: 24
RE: DX7s throttle reversed, trim wont work - 11/29/2012 9:59 AM  1 votes
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: Tluu
quote:
ORIGINAL: lourod996
Because there are people in this world that need constant validation, and doing so makes them feel better about their own individual purchases / choices..
Its the oldest pattern in human psychology.. focus on the faults of others to make you feel better about yourself..
its human nature...
Hide Signatures
(in reply to Tluu)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
