Teflon liner question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> Teflon liner question Page: [1]
Login
Teflon liner question - 11/28/2012 5:26 AM
Hp88
Score: 100
Last Login: 3/30/2013
Status: offline
Do you guys run your Teflon liner into your strut or stop it at the stuffing tube?
Hide Signatures
       Post #: 1
RE: Teflon liner question - 11/28/2012 8:10 AM
martno1fan
Score: 221
Last Login: 6/19/2013
Status: offline
My brass tube runs into the strut or stinger.
_____________________________
waveridermouldings
Hide Signatures
(in reply to Hp88)
       Post #: 2
RE: Teflon liner question - 11/28/2012 10:09 AM
Hp88
Score: 100
Status: offline
quote:
ORIGINAL: martno1fan
My stuffing tube want fit in the strut, just the the flex shaft and liner.
Hide Signatures
(in reply to martno1fan)
       Post #: 3
RE: Teflon liner question - 11/28/2012 1:08 PM
martno1fan
Score: 221
Status: offline
Ok just put the liner in there should be fine,i think most struts are made to accept shaft tubes but the ones with a liner are a tad bigger,Just checked the ones i sell they fit inside the stinger fine in fact theyre loose but too big for the strut but the liner fits pretty snug so i think thats how id do it just run the liner into the strut.
Mart
waveridermouldings
Hide Signatures
(in reply to Hp88)
       Post #: 4
RE: Teflon liner question - 11/28/2012 8:20 PM
Dan S
Score: 115
Last Login: 5/7/2013
Status: offline
I don't run Teflon liners in any of my boats.
Dan.
F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
Futaba FASST
Hide Signatures
       Post #: 5
RE: Teflon liner question - 11/28/2012 11:15 PM
Hp88
Score: 100
Status: offline
Mart
Cheers mate, yeh the liner fits nice and snug and will allow for some angle and up, down adjustment of the strut.
Hide Signatures
       Post #: 6
RE: Teflon liner question - 12/8/2012 6:07 AM
area51fe
Score: 100
Last Login: 6/18/2013
Status: offline
this is what i do,i cut a portion of the brass tubing that will fit into the stinger,run the teflon tubing into the cut brass tubing.the tubing should look like 2 pieces of brass tubing on eachside of the teflon but the shortest brasss tubing that you cut for the stinger will be placed into the stinger and the other portion should run through the hull leaving the teflon portion coming out of the transom just a bit where adjustability wont be compromised.
the brass tubing coming out of the transom should be epoxied at the exit hole of the transom where only the teflon should be exposed coming out. this works for me where i dont need to do any crazy modification.this will allow the stinger or strut to mve freely up and down easily without the brass tubing playing a stiff role in your setup. pm me for pics. i can show you what i done
Hide Signatures
(in reply to Hp88)
       Post #: 7
RE: Teflon liner question - 12/8/2012 9:05 AM
martno1fan
Score: 221
Status: offline
Never epoxy or permenantly fix a stuffing tube at the transom or you wont have much if any adjustability.The way to do it is first make the hole a slot up and down to allow full adjustment then use silicone to seal the hole,this holds the tube and still allows some up and down movement,fixing it permenatntly is not a good idea ,some boats liike the stinger or strut position as low as possible some like it as much as 3/4" up and you wont know untill youve tested it so if its fixed your screwed.
waveridermouldings
Hide Signatures
(in reply to area51fe)
       Post #: 8
RE: Teflon liner question - 12/8/2012 1:09 PM
Hp88
Score: 100
Status: offline
Thats what i am going to do with my stuffing tube, it just makes sense that you need a stuffing tube that has some movement other wise you get very little up and down adjustment.
Hide Signatures
       Post #: 9
RE: Teflon liner question - 12/8/2012 1:51 PM
martno1fan
Score: 221
Status: offline
Also use the next size up tubing to semi fix in place and slide your flex tube into this means you can remove the tube easy if needed and less mess.By the way a better sealant i found is polycarbonate sealer its seems stronger than silicone.
Mart
waveridermouldings
Hide Signatures
(in reply to Hp88)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
