Servos for 20cc profile?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Twist 3D 40 (less Rx) - RTF
Seller:  stuk_at_work
Details:   $250.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Servos for 20cc profile?
Page: [1]
Login
Servos for 20cc profile? - 11/28/2012 6:31 AM
Ernie Misner
Score: 130
Last Login: 5/17/2013
Status: offline
What's the best servo (20cc profile or 90-120 size plane) for the buck these days? I was looking at the Hitec 7975 but there might be something cheaper? I'll be using them on a 20cc profile I think.
Thanks loads,
Ernie Misner
Hide Signatures
       Post #: 1
RE: Servos for 20cc profile? - 11/28/2012 2:00 PM
ahicks
Score: 669
Last Login: 5/19/2013
Status: offline
Somebody asked the same question about a 20cc powered 70" Revolver a few days ago, some info came up that might interest you?
http://www.rcuniverse.com/forum/m_9143970/mpage_242/key_/tm.htm
Hide Signatures
(in reply to Ernie Misner)
       Post #: 2
RE: Servos for 20cc profile? - 11/28/2012 10:24 PM
acerc
Score: 221
Status: online
I have had great performance with Futaba 3010's in my 20cc profile.
Click to see fullsize image.
Click for fullsize
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to ahicks)
       Post #: 3
RE: Servos for 20cc profile? - 11/28/2012 11:24 PM
Ernie Misner
Score: 130
Status: offline
Thanks, I'll check those 3010's out. Follow the link above to the Revolver thread and lots more about servos there.
Hide Signatures
(in reply to acerc)
       Post #: 4
RE: Servos for 20cc profile? - 11/28/2012 11:40 PM
acerc
Score: 221
Status: online
I read a little of that thread but when they start talking that kind of cheap I'm done. I learned my lesson the hard way about too cheap. Don't even bother anymore trying to get cheap. I get what's necessary, no more no less.
Robert
Hide Signatures
       Post #: 5
RE: Servos for 20cc profile? - 11/28/2012 11:42 PM
Ernie Misner
Score: 130
Status: offline
Did you check out the Savox's at A Main hobbies?
Hide Signatures
(in reply to acerc)
       Post #: 6
RE: Servos for 20cc profile? - 11/29/2012 2:38 AM
acerc
Score: 221
Status: online
Don't hold me to this but I have heard Savox's don't center very well. Great for land based not so for air.
Robert
Hide Signatures
       Post #: 7
RE: Servos for 20cc profile? - 11/29/2012 4:56 AM
Ernie Misner
Score: 130
Status: offline
I know what you mean about running from the low price spread servos. I use hitec's almost exclusively..... but am going to try the HD 150's ($14 !) or the Savox's on one of my profiles. Will give you a report. Clearly, they are working great for some people. The Savox's are in very high regard around here, being used on gassers set up by Valley View. One thing in their favor is free shipping from Troy Built Models also.
Hide Signatures
(in reply to acerc)
       Post #: 8
RE: Servos for 20cc profile? - 12/6/2012 4:16 PM
CanCanCase
Score: 100
Status: offline
MKS DS1210...
-Case
Green Lightning Laundry
www.GreenLightningLaundry.com
Hide Signatures
       Post #: 9
RE: Servos for 20cc profile? - 12/6/2012 6:06 PM
Ernie Misner
Score: 130
Status: offline
Case, who sells those. Do you have a link?
Hide Signatures
(in reply to CanCanCase)
       Post #: 10
RE: Servos for 20cc profile? - 12/7/2012 1:36 AM
racelikustolit3k
Score: 100
Last Login: 2/21/2013
Status: offline
spectrum a6010.. metal gear train, will hold up to the vibes of the gasser and is plenty strong and quick for a 3d slab
how low can you go !!!
Hide Signatures
       Post #: 11
RE: Servos for 20cc profile? - 12/17/2012 5:47 AM
Ernie Misner
Score: 130
Status: offline
Two of us ordered some of the HD Power servos from Value Hobby along with a couple of the Sabre 56" profiles. We'll give you a report in the future.
Hide Signatures
(in reply to racelikustolit3k)
       Post #: 12
RE: Servos for 20cc profile? - 12/18/2012 12:31 AM
opjose
Score: 280
Status: offline
Yup. I've been using them for close to two years now on 30 and 50cc planes. The Power HD's work great. Great servos.
I've also used the 10kg ( that's 138oz/in @ 4.8v for you non-metric types or about 150+ oz/in @ 6v) HK servos given in the referenced thread link: HK Servos
They have held up very well in my Giant Big Stik w/30cc Syssa Engine, and my 50cc aircraft.
I've never had one fail with close to 40 in use.
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 13
RE: Servos for 20cc profile? - 12/18/2012 4:50 AM
Ernie Misner
Score: 130
Status: offline
Those HK servos are only $8 and they are digital. Wow.
Hide Signatures
(in reply to opjose)
       Post #: 14
RE: Servos for 20cc profile? - 12/18/2012 2:21 PM  1 votes
ahicks
Score: 669
Status: offline
They're the same one's I wrote about when I referred your question to the "Larger Revolver" string above. I have those in 2 planes, one of which has had the tar beaten out of it for the last 3 seasons (1 season in a Funtana, the second 2 in the recently retired gas powered OMP Fusion). No failures yet, though they are digitals, so they're power hungry! They need to double (or triple?) the price of them so they're taken more seriously....
Hide Signatures
       Post #: 15
RE: Servos for 20cc profile? - 12/18/2012 5:40 PM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: ahicks
You're not kidding!
I've taken to putting in dual LiFe 30c packs in parallel to power these servos.
On my Ultimate 50cc ( 8 of these servos, nine total ) I'm using dual 3200mAh packs. Two 5A regulators were not enough to power these servos reliably due to the momentary power drain spikes at startup that glitch the switching transistors on the regulators.
On my 30cc Big Stik ( 7 servos 8 total) I'm using dual 2100mAh packs - These - Click here
Those LiFe packs @ $9.52/ea end up being cheaper than NiCD's and NiMH, though you do need a LiFe capable charger for them.
Hide Signatures
       Post #: 16
RE: Servos for 20cc profile? - 2/17/2013 2:22 PM
CanCanCase
Score: 100
Status: offline
quote:
ORIGINAL: Ernie Misner
I get mine from WrongWayRC. HK used to sell them and still lists them but they're on perma-backorder.
-Case
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
