DX7s new Firmware 1.03    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> DX7s new Firmware 1.03
Page: [1] 2   next >   >>
Login
DX7s new Firmware 1.03 - 11/29/2012 3:16 AM
Rob2160
Score: 183
Last Login: 5/19/2013
Status: offline
Just a question.. my DX7s has 1.01 and works flawlessly in all respects.
I just noticed 1.03 is available with the following changes..
Software Features
Automatically corrects sub-trim and travel for models created in version 1.01 and earlier after prompting the user.
Enabled ability to configure inactivity timer
Enabled dimming control of the orange Spektrum LED for night flying
I have 20 models in my DX7s and 4 CCP helicopters that each use subtrim and some channels reversed...
Can someone explain exactly what is meant by "Automatically correcting sub trim?"
Will I have to re-trim these helicopter sub trims if I upgrade to 1.03?
I wouldn't worry about the upgrade but I like the idea of dimming the LED and changing the inactivity timer...
Any advice appreciated..
_____________________________
..... frakkin cylons...
Hide Signatures
       Post #: 1
RE: DX7s new Firmware 1.03 - 11/29/2012 6:11 AM
Aerocal
Score: 105
Last Login: 5/21/2013
Status: offline
If you go to 1.03 from 1.01 and you choose Update and then Yes on the following screen when prompted you should not have to manually adjust anything.You will only be prompted to update if you have channels that are reversed.The prompt (if applicable) will be triggered when you use Model Select to change models.
Hide Signatures
(in reply to Rob2160)
       Post #: 2
RE: DX7s new Firmware 1.03 - 11/29/2012 12:51 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: Aerocal
Thanks.. maybe I am missing something or reading too much into it.... What does Automatically correct Sub Trim mean?
I do have channels that are reversed on all my helicopter models and also subtrim on most of those channels....
What will happen if I upgrade to 1.03?
Hide Signatures
(in reply to Aerocal)
       Post #: 3
RE: DX7s new Firmware 1.03 - 11/29/2012 2:10 PM
AndyKunz
Score: 116
Status: offline
With 1.02 we made some changes that bring the DX7s/DX8 code up to match the DX10t/DX18/DX18QQ in some functions.
When we did that, it caused problems for the sub-trim values.
Users complained about doing it manually.
We made 1.03 which does it automatically if you let it. If you had done the changes under 1.02 manually, then you could tell it to skip the updating.
Andy
Andy Kunz - AMA 46063
Spektrum Development Team
Hide Signatures
       Post #: 4
RE: DX7s new Firmware 1.03 - 11/30/2012 1:24 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: AndyKunz
Andy
Ok, that makes sense...  just one question and sorry to be pedantic...
I have 1.01 in my DX7s.. One helicopter model for example, has elevator reversed and 10U on the subtrim...
If I upgrade now to 1.03, will it affect anything?  Will I have to manually reset the subtrims...
Thanks again for your advice.
Hide Signatures
(in reply to AndyKunz)
       Post #: 5
RE: DX7s new Firmware 1.03 - 11/30/2012 8:23 AM
Rob2160
Score: 183
Status: offline
Ok, so I bit the bullet and did the 1.03 Upgrade.
I wrote down all model memories that used subtrim...
Prior to Update they are..
Memory 9  (Helicopter) ELEV REV 10U on Sub Trim
Memory 16 (Helicopter)  AIL 28L  ELEV 22U PITCH 10+
Memory 17 (Aircraft) Subtrim AIL 20L
Post Update.
Memory 9 - no change
Memory 16 - AIL now 28R, ELEV 22D PITCH 10-
Memory 17 Subtrim now AIL20R
I am away from home now and can't check how this has affected my models...    Why has it reversed all the subtrims?   I Just curious... Any advice greatly appreciated..
All other models are either 4 channel aircraft or BNF small eflite helis and none of them used subtrim..
Hide Signatures
       Post #: 6
RE: DX7s new Firmware 1.03 - 11/30/2012 2:41 PM
rmh
Score: 252
Status: offline
try each model before flying - you may find a reversed throw -
I found none
Libby is still watching you
Hide Signatures
       Post #: 7
RE: DX7s new Firmware 1.03 - 11/30/2012 3:56 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: rmh
I found none
Thanks, yes I will do that for sure..
I have been experimenting since upgrading and one thing I don't understand..
Assume a standard 4 channel aircraft,
Aileron Channel is reversed...  Left Stick gives Left Roll on the aircraft..   IE Left Aileron moves up, Right moves down...
But Applying LEFT Subtrim now creates a RIGHT Roll Effect.  IE, the SUB TRIM now seems to ignore the fact that the channel is reversed?
And the logic for this is???
Hide Signatures
(in reply to rmh)
       Post #: 8
RE: DX7s new Firmware 1.03 - 11/30/2012 5:04 PM
rmh
Score: 252
Status: offline
Ask Andy
Hide Signatures
       Post #: 9
RE: DX7s new Firmware 1.03 - 11/30/2012 5:46 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: rmh
Ask Andy
Dear Andy...
What rmh said...
Hide Signatures
(in reply to rmh)
       Post #: 10
RE: DX7s new Firmware 1.03 - 11/30/2012 6:12 PM
mighty9
Score: 106
Status: offline
The logic is there is no way to know for sure what side of the servo arm will be used to control the surface.Rob was it that way before the update?
Hide Signatures
       Post #: 11
RE: DX7s new Firmware 1.03 - 11/30/2012 6:24 PM
AndyKunz
Score: 116
Status: offline
quote:
ORIGINAL: Rob2160
Because how it interprets sub trim was reversed, to make it more like the DX18 and fix some issues in helicopters and in the trainer system.
It reversed them because it had to to keep the servo output in the same position.
Andy
Hide Signatures
       Post #: 12
RE: DX7s new Firmware 1.03 - 11/30/2012 6:35 PM
rmh
Score: 252
Status: offline
And Bob's yer uncle!
Hide Signatures
       Post #: 13
RE: DX7s new Firmware 1.03 - 11/30/2012 6:36 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: mighty9
Yes, I can see that if you centre the servos before installation.. I never do that on helicopters though.. I set up Reverses first to get all moving the same direction with collective.. then Swash to give correct roll and pitch response.. then I set subtrims to ensure the swash is level at 50%....
I am pretty sure it wasn't that way before the update.. the subtrim adjustment was the same as the stick movement.. IE Left or right reversed or normal, the subtrim moved in the same orientation as stick movement..
it won't make any real difference to me in a new set up, was just curious why it was changed.
Hide Signatures
(in reply to mighty9)
       Post #: 14
RE: DX7s new Firmware 1.03 - 11/30/2012 6:42 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: AndyKunz
quote:
ORIGINAL: Rob2160
Andy
Thanks Andy..
Makes sense..
I have one aircraft with two aileron servos on a Y splitter to the Aileron channel..  I have that channel reversed for correct response.
I used the subtrim to make sure both servo arms were perfectly lined up before connecting the pushrods.. This ensures equal up down movement on both ailerons..
I think \reversing the sub trim response will throw out my trim.
No Biggie, its easy to fix, was just curious..
Thanks again.
Hide Signatures
       Post #: 15
RE: DX7s new Firmware 1.03 - 11/30/2012 7:30 PM
AndyKunz
Score: 116
Status: offline
It should automatically correct for that, too.
Andy
Hide Signatures
       Post #: 16
RE: DX7s new Firmware 1.03 - 12/1/2012 4:45 AM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: AndyKunz
Andy
Thanks, I will let you know when I get home and test it.. (Unfortunately that's not until late Dec, the joys of being a corporate pilot)
Hide Signatures
       Post #: 17
RE: DX7s new Firmware 1.03 - 12/1/2012 2:41 PM
jefflangton
Score: 101
Status: offline
Spektrum is blowing smoke where the sun dont shine!!! Theyre not updates, they're still trying to get the signal right. Spek users need to pick up a quality futaba, youll never look back!!!!
Hide Signatures
       Post #: 18
RE: DX7s new Firmware 1.03 - 12/1/2012 3:16 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: jefflangton
Ok, I know I shouldn't feed the troll.. but I'm bored...
One problem with your theory..
I spend 6 months of each year living in hotels. I take a few small Blade Helis and ultra Micro fixed wings with me..
How am I going to fly them with Futaba?
Show me a Futaba TX with 40 Hours run time?  My DX7s with Lipo goes for a month flying every single day.
Just for the record I have several Futaba, JR and Spektrum radios.. All have been equally reliable. IE pefect.. I have never lost a connection..
My radios below.. plus I now have a DX7s which is my most used radio..  I like Futaba and they are great quality, Spektrum is the same in my experience but they feel nicer to fly with.
Also, in my own testing, I found Spektrum and JR give slightly superior long range performance.
Please post details of how many Spektrum radios you have personally tested with videos that demonstrate your point. .  It will add credibility to your post.
some of my vids and tests.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to jefflangton)
       Post #: 19
RE: DX7s new Firmware 1.03 - 12/1/2012 3:23 PM
BuschBarber
Score: 104
Status: offline
There is no reason for an ignorant Troll to violate a Spektrum thread in this manner. I would not do that to a Futaba thread. No one here is putting down Futaba. Enjoy the brand you prefer and we will as well.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 20
RE: DX7s new Firmware 1.03 - 12/1/2012 3:31 PM  1 votes
rmh
Score: 252
Status: offline
Relax - the clowns who post those threads are simply trying to exercize their ignorance. You will never see worthwhile info in their posts - they simply have none to pass along - Tragic lives - Likely raised by a pack of Ferrets .
Hide Signatures
(in reply to BuschBarber)
       Post #: 21
RE: DX7s new Firmware 1.03 - 12/1/2012 5:15 PM
Rob2160
Score: 183
Status: offline
quote:
ORIGINAL: rmh
+1... I think if someone wants to display their ignorance publicly then we have an obligation to help them...
Hide Signatures
(in reply to rmh)
       Post #: 22
RE: DX7s new Firmware 1.03 - 12/4/2012 1:25 AM
Rob2160
Score: 183
Status: offline
This made me laugh..
I almost posted.. (in jest)  Sell it and buy a SPEKTRUM..
The humor might have been missed...
Futaba breaks sometimes also...
http://www.rcuniverse.com/forum/m_11315804/anchors_11315804/mpage_1/key_/anchor/tm.htm#11315804
Hide Signatures
       Post #: 23
RE: DX7s new Firmware 1.03 - 12/4/2012 2:15 AM
mighty9
Score: 106
Status: offline
Yea best to take the high road anyway Rob. lol
Hide Signatures
       Post #: 24
RE: DX7s new Firmware 1.03 - 12/23/2012 9:42 PM
Rob2160
Score: 183
Status: offline
Just an update...
I arrived back home yesterday and was able to assess the changes in subtrim on one of my 450 helis..
Swash is
AIL +75
ELEV +75
PITCH +65
Firmware 1.01
Aileron 28L
Elev 22U (reversed channel )
Pitch +10 (reversed channel
The helicopter hovered perfectly neutral with these sub trim settings
After upgrading to Firmware 1.03, the swashplate was definately not level, it was pitching forward and to the right significantly
I levelled it again with the subtrims (and test flew it)
Final results were
AIL 40L
ELEV 40D
PITCH -5
I have 20 models in my DX7s and all others were not affected by the update , I have test flown them all.and detected no change
Only Model 16 - the 450 Heli required sub trim corrections after the firmware update..
Not sure why but all is good now and it flies the same as before
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
